Square to round transition
edwilliams16
Re: Square to round transition
Post by edwilliams16 »
Gui isn't my forte, but I managed to figure out how to get the inputs into the Macro:
"""Create rectangular to circular metal transition
Author: Ed Williams (@edwilliams16)
Copyright: 2022
Licence: CC BY-NC-ND 4.0 IT
import numpy as np
import Part, Mesh, MeshPart
import math
import flatmesh
from PySide import QtGui, QtCore
# UI Class definitions
class TransitionGuiClass(QtGui.QDialog):
    def __init__(self):
        super(TransitionGuiClass, self).__init__()
        self.initUI()
    def initUI(self):
        self.inches = True
        self.result = userCancelled
        # create our window
        # define window		xLoc,yLoc,xDim,yDim
        self.setGeometry(	250, 250, 400, 350)
        self.setWindowTitle("Rectangle to circle transition")
        self.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
        # create some Labels
        self.labelRectangle = QtGui.QLabel("        Rectangle", self)
        self.labelRectangle.setFont(QtGui.QFont("Times", 16, QtGui.QFont.Bold))
        self.labelRectangle.move(20, 20)
        self.labelLengthX = QtGui.QLabel("LengthX", self)
        self.labelLengthX.move(20, 55)
        self.labelLengthX.setFont('Courier') # set to a non-proportional font
        self.labelLengthY = QtGui.QLabel("LengthY", self)
        self.labelLengthY.move(20, 80)
        self.labelLengthY.setFont('Courier')
        self.labelCircle = QtGui.QLabel("        Circle", self)
        self.labelCircle.setFont(QtGui.QFont("Times", 16, QtGui.QFont.Bold))
        self.labelCircle.move(20, 110)
        self.labelRadius = QtGui.QLabel("Radius", self)
        self.labelRadius.move(20, 140)
        self.labelRadius.setFont('Courier')
        self.labelCenterXYZ = QtGui.QLabel("CenterXYZ", self)
        self.labelCenterXYZ.move(20, 170)
        self.labelCenterXYZ.setFont('Courier')
        self.labelRotAxis = QtGui.QLabel("Rot Axis", self)
        self.labelRotAxis.move(20, 200)
        self.labelRotAxis.setFont('Courier')
        self.labelRotAngle = QtGui.QLabel("Rot Angle", self)
        self.labelRotAngle.move(20, 230)
        self.labelRotAngle.setFont('Courier')
        self.noSegments = QtGui.QLabel("Number of Segments", self)
        self.noSegments.move(20, 260)
        self.noSegments.setFont('Courier')
        # set up lists for scale pop-up
        self.popupItems1 = ("inches","mm")
        # set up pop-up menu
        self.popup1 = QtGui.QComboBox(self)
        self.popup1.addItems(self.popupItems1)
        self.popup1.setCurrentIndex(self.popupItems1.index("inches"))
        self.popup1.activated[str].connect(self.onPopup1)
        self.popup1.move(210, 20)
        # numeric input fields
        self.lengthX = QtGui.QLineEdit(self)
        self.lengthX.setValidator(QtGui.QDoubleValidator())
        self.lengthX.setText("40.00")
        self.lengthX.setFixedWidth(70)
        self.lengthX.move(100, 50)
        self.lengthY = QtGui.QLineEdit(self)
        self.lengthY.setValidator(QtGui.QDoubleValidator())
        self.lengthY.setText("45.00")
        self.lengthY.setFixedWidth(70)
        self.lengthY.move(100, 75)
        self.radius = QtGui.QLineEdit(self)
        self.radius.setValidator(QtGui.QDoubleValidator())
        self.radius.setText("15.00")
        self.radius.setFixedWidth(70)
        self.radius.move(100, 135)
        self.centerX = QtGui.QLineEdit(self)
        self.centerX.setValidator(QtGui.QDoubleValidator())
        self.centerX.setText("0.0")
        self.centerX.setFixedWidth(70)
        self.centerX.move(100, 165)
        self.centerY = QtGui.QLineEdit(self)
        self.centerY.setValidator(QtGui.QDoubleValidator())
        self.centerY.setText("0.0")
        self.centerY.setFixedWidth(70)
        self.centerY.move(180, 165)
        self.centerZ = QtGui.QLineEdit(self)
        self.centerZ.setValidator(QtGui.QDoubleValidator())
        self.centerZ.setText("15.00")
        self.centerZ.setFixedWidth(70)
        self.centerZ.move(260, 165)
        self.axisX = QtGui.QLineEdit(self)
        self.axisX.setValidator(QtGui.QDoubleValidator())
        self.axisX.setText("1.0")
        self.axisX.setFixedWidth(70)
        self.axisX.move(100, 195)
        self.axisY = QtGui.QLineEdit(self)
        self.axisY.setValidator(QtGui.QDoubleValidator())
        self.axisY.setText("0.0")
        self.axisY.setFixedWidth(70)
        self.axisY.move(180, 195)
        self.axisZ = QtGui.QLineEdit(self)
        self.axisZ.setValidator(QtGui.QDoubleValidator())
        self.axisZ.setText("0.0")
        self.axisZ.setFixedWidth(70)
        self.axisZ.move(260, 195)
        self.angle = QtGui.QLineEdit(self)
        validator = QtGui.QDoubleValidator()
        #validator.setRange(-90, 90, 1)
        self.angle.setValidator(validator)
        self.angle.setText("0.0")
        self.angle.setFixedWidth(70)
        self.angle.move(100, 225)
        self.segments = QtGui.QLineEdit(self)
        self.segments.setText('8')
        self.segments.setValidator(QtGui.QIntValidator())
        self.segments.setFixedWidth(30)
        self.segments.move(180, 255)
        # cancel button
        cancelButton = QtGui.QPushButton('Cancel', self)
        cancelButton.clicked.connect(self.onCancel)
        cancelButton.setAutoDefault(True)
        cancelButton.move(150, 280)
        # OK button
        okButton = QtGui.QPushButton('OK', self)
        okButton.clicked.connect(self.onOk)
        okButton.move(260, 280)
        # now make the window visible
        self.show()
    def onPopup1(self, selectedText):
        if selectedText == 'mm':
            self.inches = False
        else:
            self.inches = True
    def onCancel(self):
        self.close()
    def onOk(self):
        self.result			= userOK
        self.close()
# Constant definitions
userCancelled = "Cancelled"
userOK = "OK"
# code ***********************************************************************************
def printVertices(vs):
    App.Console.PrintMessage('Template Vertices\n')
    if useInches:
        App.Console.PrintMessage('Inch units\n')
    else:
    for i, v in enumerate(vs):
        App.Console.PrintMessage(f'{i}:  ({v.x:.2f},{v.y:.2f})\n')
def flattenMesh(obj):
    #https://github.com/FreeCAD/FreeCAD/blob/0d0bd1168bb96ded8dfe5ab3ca60588dec5d2949/src/Mod/MeshPart/Gui/MeshFlatteningCommand.py
    points = np.array([[i.x, i.y, i.z] for i in obj.Mesh.Points])
    faces = np.array([list(i) for i in  obj.Mesh.Topology[1]])
    flattener = flatmesh.FaceUnwrapper(points, faces)
    flattener.findFlatNodes(5, 0.95)
    boundaries = flattener.getFlatBoundaryNodes()
    wires = []
    for edge in boundaries:
        pi = Part.makePolygon([App.Vector(*node) for node in edge])
        wires.append(Part.Wire(pi))
    return wires
doc = App.ActiveDocument
V3 = App.Vector
#get inputs from Gui
form = TransitionGuiClass()
form.exec_()
if form.result==userOK:
    useInches = form.inches
    if useInches:
        scale = 25.4
    else:
        scale = 1.
    rectX = float(form.lengthX.text()) * scale
    rectY = float(form.lengthY.text()) * scale
    height = float(form.centerZ.text()) * scale
    xoffset = float(form.centerX.text()) * scale
    yoffset = float(form.centerY.text()) * scale
    circleRotationAngle = float(form.angle.text())
    circleRotationAxis = V3(float(form.axisX.text()), float(form.axisY.text()), float(form.axisZ.text()))
    nSides = int(form.segments.text())
    eps =1e-6
    sV = [0.5*V3(*v) for v in [(rectX,0,0), (rectX, rectY, 0), (0, rectY, 0),(-rectX,rectY,0),
    (-rectX, 0, 0), (-rectX, -rectY, 0), (0, -rectY, 0), (rectX,-rectY, 0), (rectX*(1-eps),0,0)]]
    # sv[3]      sV[2]      sV[1]
    # sv[4]      O          sV[0], sv[8] seam
    # sv[5]     sV[6]       sV[7]
    # 4N-sided quarter circle
    thetas = [2 * math.pi * j/(4 * nSides) for j in range(4*nSides + 1)]
    thetas[-1] -= eps #seam
    #create and locate circle
    cV2 = [V3(radius * math.cos(t), radius * math.sin(t), 0) for t in thetas]
    pl = App.Placement(V3(xoffset, yoffset, height), App.Rotation(circleRotationAxis, circleRotationAngle))
    cV = [pl.multVec(v) for v in cV2]
    faceList = []
    for k in range(4):
        face = Part.Face(Part.makePolygon([sV[2*k], cV[nSides*k], sV[2*k + 1], sV[2*k]]))
        #Part.show(face)
        faceList.append(face)
        face = Part.Face(Part.makePolygon([sV[2*k + 1], cV[nSides*(k + 1)], sV[2*k + 2], sV[2*k + 1]]))
        #Part.show(face)
    for k in range(4):
        for j in range(nSides):
            f = Part.Face(Part.makePolygon([sV[2*k +1], cV[nSides*k +j], cV[nSides*k + j+1], sV[2*k +1]]))
            #Part.show(f)
            faceList.append(f)
    shell = Part.Shell(faceList)
    qshell = Part.show(shell, "QuarterShell")
    qshell.Visibility = False
    mesh = doc.addObject('Mesh::Feature','Mesh')
    mesh.Mesh=MeshPart.meshFromShape(Shape=shell, LinearDeflection=0.1, AngularDeflection=0.523599, Relative=False)
    mesh.Label="QuarterShell (Meshed)"
    wires = flattenMesh(mesh)
    doc.removeObject(mesh.Name)
    template = Part.show(wires[0], "Template") #only one outline here
    #change origin and orientation centering bottom edge along x-axis
    newOrigin = template.Shape.Vertexes[4].Point
    edgedir = template.Shape.Edges[3].Curve.Direction
    rot = App.Rotation(-edgedir, V3(),V3(0, 0, 1), 'XZY')
    template.Placement = App.Placement(newOrigin, rot).inverse()
    doc.recompute()
    templateVertices = [v.Point/scale for v in template.Shape.Vertexes]
    printVertices(templateVertices)
if form.result==userCancelled:
    pass
Put it in your Macro folder and execute. It does rectangular to tilted offset circles.
jfc4120
Post by jfc4120 »
@edwilliams16 got an error:
<class 'NameError'>: name 'radius' is not defined
I tried to assign a radius:
    radius = 10
But got unexpected results.
edwilliams16
Still works for me - despite the bug. There must be a radius variable around from earlier executions. I need to find out how to force a clean Macro environment... Anyhow
"""Create rectangular to circular metal transitions
Copyright: 2022
import numpy as np
import math
import flatmesh
    def __init__(self):
        self.initUI()
    def initUI(self):
        self.inches = True
        # create our window
        # cancel button
        # OK button
        self.show()
            self.inches = False
        else:
            self.inches = True
    def onCancel(self):
        self.close()
    def onOk(self):
        self.close()
userOK = "OK"
    if useInches:
    else:
    wires = []
    return wires
def makeTemplate(form):
        if useInches:
            scale = 25.4
        else:
            scale = 1.
        radius = float(form.radius.text()) * scale
        eps =1e-6
        # sv[3]      sV[2]      sV[1]
        # sv[5]     sV[6]       sV[7]
        faceList = []
        for k in range(4):
            #Part.show(face)
            #Part.show(face)
        for k in range(4):
                #Part.show(f)
                faceList.append(f)
        doc.recompute()
        pass
V3 = App.Vector
form.exec_()
makeTemplate(form)
should fix it.
EDIT: made the active code into a function to try to immunize against this sort of error
jfc4120
Post by jfc4120 »
A compare, mine and yours: One is both on top of each other.
radius 5,l=20, w=7, h=15
Edit: I'm catching on to basic variable usage, but much of the other python stuff is way over my head.
edwilliams16
Looks good by eyeball.
jfc4120
Post by jfc4120 »
I will do a couple of other random sizes and zoom in any problems I will get back with you.
edwilliams16
I’m thinking we might want to tweak the circle radius to make the perimeter of its approximating polygon the same as that of the nominal circle. The larger the number of sections the smaller the tweak. You agree?
jfc4120
Post by jfc4120 »
Hard to say because in real life if it's a huge Square to round you use more sections anyway I've seen as many as 48 used but for smaller fittings 12 to 16 in many cases is close enough.
I experimented once with the actual Arc Length versus straight and it's been years but if I remember correctly the difference was negligible.
edwilliams16
It's a small error for many segments, but it's a one-liner to fix. For 2 segments (one crease) per quarter, it's visible:
Screen Shot 2022-07-21 at 7.16.38 PM.png (32.24 KiB) Viewed 927 times
So might as well include.
Copyright: 2022
import numpy as np
import math
import flatmesh
    def __init__(self):
        self.initUI()
    def initUI(self):
        self.inches = True
        # create our window
        # cancel button
        # OK button
        self.show()
            self.inches = False
        else:
            self.inches = True
    def onCancel(self):
        self.close()
    def onOk(self):
        self.close()
userOK = "OK"
    if useInches:
    else:
    wires = []
    return wires
        if useInches:
            scale = 25.4
        else:
            scale = 1.
        radius *= (math.pi/(4 * nSides * math.sin(math.pi/(4 * nSides)))) #correct perimeter discretization
        eps =1e-6
        # sv[3]      sV[2]      sV[1]
        # sv[5]     sV[6]       sV[7]
        faceList = []
        for k in range(4):
            #Part.show(face)
            #Part.show(face)
        for k in range(4):
                #Part.show(f)
                faceList.append(f)
        doc.recompute()
        pass
V3 = App.Vector
form.exec_()
makeTemplate(form)
jfc4120
Post by jfc4120 »
@edwilliams16 Some compares, and got one error:
File "C:/Users/Owner/AppData/Roaming/FreeCAD/Macro/rect_round_trueearc.FCMacro", line 163, in printVertices
if useInches:
<class 'NameError'>: name 'useInches' is not defined
Images attached.
