Accessing PythonOCC in FreeCAD 0.20
Zoltan
Post by Zoltan »
My script relies on PythonOCC. Now,
import OCC
does not work any more in version 0.20 and the (currently) latest weekly build either.
On the other hand, the Part.__toPythonOCC__ and Part.__toPythonOCC__ functions are still present. Note that __toPythonOCC__ throws the following error when a Part.Shape object is passed:
Part.OCCError: SWIG: Cannot find type information for requested type: TopoDS_Shape *
I could not find the OCC package on the usr/lib/python3.10/site-packages/ path (after extracting the Appimage), so I guess it is not packaged with conda any more. Is there a FreeCAD binary distribution that still contains PythonOCC? If not, I need to install it by myself into the conda virtual environment. In that case, which PythonOCC should I install, which is compatible with FreeCAD 0.20?
Gift
Re: Accessing PythonOCC in FreeCAD 0.20
Post by Gift »
You need the conda build
Zoltan
Post by Zoltan »
Gift wrote: Thu Jun 23, 2022 6:44 pm You need the conda build
Thank you, but that AppImage does not contain PythonOCC either. Same import error. The packages.txt file in the root of the extracted AppImage also lacks the OCC package.
Gift
Post by Gift »
looo wrote: Ping
Do you have any idea?
looo
Post by looo »
I excluded pythonocc from the bundles as I wanted to update to occt7.6 and pythonocc is not ready for occt7.6. Also I did not know others were relying on pythocc.
What functionality do you need from pythocc. Maybe you can make a feature request so Freecad-developers can add this functionality.
Zoltan
Post by Zoltan »
looo wrote: Fri Jun 24, 2022 9:39 am What functionality do you need from pythocc. Maybe you can make a feature request so Freecad-developers can add this functionality.
I use it in the following code for my most important project:
from OCC.Core.BRepProj import BRepProj_Projection
from OCC.Core.gp import gp_Dir
def project(curve, surface, direction):
        """Cylindrical projection of a curve onto a surface.
        Parameters
        curve : Part.Wire
            Curve to be projected.
        surface : Part.Face
            Surface to project onto.
        direction : tuple of float
            Direction vector of the projection, tuple of three numbers.
        Returns
        Part.Compound
            A compound object, containing the parts of the projected curve.
        Raises
        Exception
            If the projection algorithm of OpenCASCADE fails. This typically happens if the
            projected curve would not lie on the surface.
        Notes
        This function is a wrapper around the cylindrical projection functionality available in
        OpenCASCADE. For details, see its documentation:
        https://dev.opencascade.org/doc/refman/html/class_b_rep_proj___projection.html
        curve = Part.__toPythonOCC__(curve)
        surface = Part.__toPythonOCC__(surface)
        projection_direction = gp_Dir(*direction)
        proj = BRepProj_Projection(curve, surface, projection_direction)
        if not proj.IsDone():
            raise Exception('Projection failed.')
        return Part.__fromPythonOCC__(proj.Shape())
I have other, less important, projects where I use OCC here and there. It would be nice if it was shipped with FreeCAD, so the users would not need to manually compile it or fetch the binaries from conda.
Zoltan wrote: Fri Jun 24, 2022 10:08 am
This could not be achieved using Geom2D things:
https://forum.freecadweb.org/viewtopic.php?f=22&t=65844
looo
Post by looo »
Ok I will try to add it back in the next couple of days. But anyway it would be nice if you try to make a feature request for the necessary stuff so we can use this functionality directly in freecad.
Zoltan
Post by Zoltan »
I am not against making a feature request, but this is Python code. On the other hand, this basic functionality (projection) fits to the Part module, which is coded in C++, with which I have no familiarity.
Zoltan
Post by Zoltan »
onekk wrote: Fri Jun 24, 2022 10:26 am This could not be achieved using Geom2D things:
OK, I will look into it soon.
