Find angle between adjacent faces
sliptonic
Post by sliptonic »
I want to calculate the angle between two selected faces that have a common edge. For example face 2 and 3 in this image.
But since both faces 1 and 3 have the same normal, selecting either 1 and 2 or 2 and 3 yields 120 degrees. How can I distinguish between these cases?
I would expect 2,3 to be 60 degrees and 1,2 to be 300 degrees.
import math
f1 = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0]
f2 = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[1]
v1 = f1.normalAt(0,0)
v2 = f2.normalAt(0,0)
print(math.degrees(v2.getAngle(v1)))
edwilliams16
Re: Find angle between adjacent faces
Post by edwilliams16 »
To make the problem well-defined mathematically, I think you are asking for the angle between the face planes measured exterior to the object. Convex intersections would be returned > 180 deg and concave < 180 deg? Is that correct? I'm not seeing another way to resolve the inherent ambiguity.
With the angle alone you cannot distinguish between the two cases. As already mentioned you have to distinguish between a convex area (face 1+2) and a concave area (face 2+3).
Now all what you need is e.g. a point that lies on one face but not on the adjacent face, i.e. the point must not be part of the common edge. Compute the distance of this point with the adjacent face.
If the distance is negative you have the convex case like face 1+2.
If the distance is positive you have the concave case like face 2+3.
If the distance is zero the two planes are co-planar.
sliptonic
Re: Find angle between adjacent faces (and other experiments)
Post by sliptonic »
Here's another one. In case it isn't obvious, I'm trying to figure out some of the issues related to cutting dovetails on a milling machine. Ultimately I'm offsetting the red line (common edge). Now that I have the angle between the faces, I need to figure out the Width of Cut (base of blue triangle) and Depth of Cut (height)
As an intermediate step, I think I need to find the pink line segment. It lies on plane of the green face and passes through the midpoint of the common edge and is perpendicular to the common edge.
edwilliams16
I made the assumption that the red edge is straight and the green face is planar and that you can already access these. I get them by selection.
#select edge then face - assumed straight and planar
sel = Gui.Selection.getSelectionEx()[0]
edge, face = sel.SubObjects
edgeCenter = edge.CenterOfGravity
fsp =face.Surface.parameter(edgeCenter)
faceNormal = face.normalAt(*fsp)
pinkLine = Part.Line() #temporary infinite line
pinkLine.Direction = faceNormal.cross(edge.Curve.Direction)
pinkLine.Location=edgeCenter
#find where pinkLine crosses the face edges
intersections = [pinkLine.intersect(faceEdge.Curve, 1e-7) for faceEdge in face.Edges if len(pinkLine.intersect(faceEdge.Curve, 1e-7)) >0]
#print(f'start = {edgeCenter}  {intersections}')
ends = [App.Vector(pa[0].X, pa[0].Y, pa[0].Z) for pa in intersections]
pinkLine = Part.LineSegment(*ends)  #construct line segment
Part.show(pinkLine.toShape())
EDIT: fixed script bug that made it look like it worked when it didn't...
dtay
Post by dtay »
I'm not so good at python or math, but I figured I'd give this puzzle a try :)
The code below assumes that the adjacent edge of the blue triangle points up in Z and only the undercut is selected.
import math
a = f1.BoundBox.XMax-f1.BoundBox.XMin
b = f1.BoundBox.ZMax-f1.BoundBox.ZMin
ang = math.atan(a/b)
#X/Z start point
x1, z1 = f1.BoundBox.XMax, f1.BoundBox.ZMax
stnum=5
bstp=b/stnum
for stp in range(1,stnum+1):
    x=x1-bstp*stp*math.tan(ang)
    z=z1-bstp*stp
    print("X={} Z={}".format(x,z))
I would be interested in what a more elegant approach might look like...
edwilliams16
dtay wrote: Tue May 17, 2022 10:17 pm
It looks like you've assumed that the dovetail section is in the X-Z plane, which it might not be. And the OP wanted the line to be at the mid-point in Y...
edwilliams16
edwilliams16 wrote: Tue May 17, 2022 10:12 pm I made the assumption that the red edge is straight and the green face is planar and that you can already access these. I get them by selection.
EDIT: fixed script bug that made it look like it worked when it didn't... Added my test file
pinkline.FCStd
(12.18 KiB) Downloaded 13 times
