Set label of Solid
drmacro
Set label of Solid
Post by drmacro »
It's always a riddle with the internals, it it a shape, or shell, or solid... :roll:
But, the real question here is in the code below the 'cube' shows up in the tree view with a label 'Shape'
But, the object 'cube' in the code doesn't have a Label property. And, of course, cube.Label fails.
import Part
# vector 1
v1 = FreeCAD.Vector(0,0,0)
# vector 2
v2 = FreeCAD.Vector(1,0,0)
# edge between v1 and v2
edge = Part.makeLine(v1,v2)
# Face
face = edge.extrude(FreeCAD.Vector(0,1,0))
# Cube
cube = face.extrude(FreeCAD.Vector(0,0,1))
cube.Label='anothercube'
Part.show(cube)
drmacro
Re: Set label of Solid
Post by drmacro »
Never mind, got it. :oops:
import Part
# vector 1
# vector 2
# Face
# Cube
thing=Part.show(cube)
thing.Label='MyLabel'
TheMarkster
Post by TheMarkster »
Just be aware Part.show() did not return the object until fairly recently and will not do so in 0.19. An alternative is:
thing = doc.addObject("Part::Feature","Shape")
thing.Shape = cube
thing.Label = "MyLabel" #or name the object with addObject()
drmacro
Post by drmacro »
TheMarkster wrote: Sun May 08, 2022 3:12 pm Just be aware Part.show() did not return the object until fairly recently and will not do so in 0.19. An alternative is:
thing.Shape = cube
Yes, I did indeed see that. Thanks.
No problem for me in 0.20. But the guy I was talking with was using 0.19.
Hello in the first try object cube was a TopoShape and only DocumentObjects have a Name and a Label property.
So until created or "promoted" to a TopoShape with one of the methods shown in other posts object is simply a "shape". has no "Name" and "Label" properties.
Only to explain why objects had no "Name" or "Label", mostly for "future readers".
:D
Roy_043
Post by Roy_043 »
I don't think that is correct. Aren't Shape and TopoShape synonymous?
Roy_043 wrote: Mon May 16, 2022 6:45 am I don't think that is correct. Aren't Shape and TopoShape synonymous?
What is not correct?
The key point of my answer is the difference between a TopoShape that is a "solid", but has no Name and Label (and Label2 if applicable) and a DocumentObject, from my post:
Usually "Shape" property of a DocumentObject is a TopoShape (in FC terms), I put "usually" as I don't know if there are other object that could go in the "Shape" property.
Probably one of the most "not well explained" things about FC is the 3 levels of Objects, Curves (Geometries), TopoShapes and DocumentObjects. (not counting the Geom2D things)
I don't know other CADs, but this seems to me a logic things, but probably to some peoples this is not true, or it is managed differently from other "mainstream" CADs.
Roy_043
Post by Roy_043 »
onekk wrote: Mon May 16, 2022 7:02 am What is not correct?
onekk wrote: Mon May 16, 2022 4:55 am So until created or "promoted" to a TopoShape with one of the methods shown object is simply a "shape".
A shape already is a TopoShape.
Ok see the redundancy, I'm correcting the post.
