Actually no, not really enough time for this. But I still think there is something to be improved there.
Position and orientation in the reference frame of a LCS
Re: Position and orientation in the reference frame of a LCS
Hello.
Just to clarify my question. Imagine a simple draft point:
point = Draft.makePoint(X, Y, Z)
then such a point will be at (X,Y,Z) relative to the global reference frame.
Now, imagine a local coordinate system that is at any position and orientation relative to the global coordinate system.
The question is, how can I get the position of the point, but as viewed from the local coordinate system?
I know I can do some simple geometry or a transformed coordinate system for this, but I though FreeCAD may already have this option...
The same applies for the position of the points that define a line.
import FreeCAD as App
import Draft
doc = App.newDocument()
p1 = App.Vector(0, 0, 0)
p2 = App.Vector(1000, 500, 0)
line = Draft.make_line(p1, p2)
place = line.Placement
place.rotate(App.Vector(0, 0, 0), App.Vector(1, 1, 1), 35)
doc.recompute()
global_point = place.multVec(line.Points[1])
print(global_point)
local_point = place.inverse().multVec(global_point)
print(local_point)
Hi, RoyRoy_043 wrote: ↑Sun Jul 17, 2022 2:00 pmCode: Select all
import FreeCAD as App import Draft doc = App.newDocument() p1 = App.Vector(0, 0, 0) p2 = App.Vector(1000, 500, 0) line = Draft.make_line(p1, p2) place = line.Placement place.rotate(App.Vector(0, 0, 0), App.Vector(1, 1, 1), 35) doc.recompute() global_point = place.multVec(line.Points[1]) print(global_point) local_point = place.inverse().multVec(global_point) print(local_point)
How to get the global location of an object in a link group? when the link group move, the placement information of objects in the group is not updated.
Your code should determine the cumulative effect of the placements (see Option 1). Part.getShape can also be used, but is less efficient if you do not need the shape it returns (see Option 2).
import Part
doc = App.ActiveDocument
prt = doc.Part
grp = doc.LinkGroup
lnk = doc.Link
lin = doc.Line
# Option 1
point = lin.Points[1]
for obj in [lin, lnk, grp, prt]:
point = obj.Placement.multVec(point)
print(point)
# Option 2
shape, matrix, obj = Part.getShape(prt, "LinkGroup.Link", needSubElement=True, retType=2)
place = App.Placement(matrix)
point = place.multVec(point)
print(point)
- Placement_Test_LinkGroup.FCStd
- (7.39 KiB) Downloaded 46 times
What is the meaning of this error your file generates when clicking on LinkGroup?
Error adjustedGlobalPlacement
OS: macOS High Sierra (10.13)
Version: 0.20.29177 (Git)
Locale: C/Default (C)
* Curves 0.4.4
* DynamicData 2.46.0
* fasteners 0.3.44
* fcgear 1.0.0
* GDML 1.8.0
* Help 1.0.2
* lattice2 1.0.0
* MeshRemodel 1.8919.0
* toSketch
Version: 0.21.29393 (Git)
Hash: 6820e0a9ec85203a6f342ca72a2ff8fd417beaf1
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
* Curves 0.4.4
* fasteners 0.3.44
* fcgear 1.0.0
* GDML 1.8.0
* Help 1.0.2
* lattice2 1.0.0
* toSketch
I am pretty clueless.edwilliams16 wrote: ↑Fri Jul 22, 2022 11:43 pm What is the meaning of this error your file generates when clicking on LinkGroup?
I don't get the error with V0.20 either BTW.
Branch: releases/FreeCAD-0-20
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
I am doing what I think may be the most efficient way to solve this:
Is this correct?
#Create a placement:
p1 = App.Placement()
#Move to (0,0,1). The "point" is now (0,0,1).
p1.Base = (0,0,1)
#Create a local coordinate system (initially orthonormal to the global coordinate system):
lcs = App.activeDocument().addObject( 'PartDesign::CoordinateSystem', 'LCS' )
#Get the placement of p1 as seen from LCS (same as global placement of p1):
lcs.Placement.inverse().multiply(p1)
#Move and rotate the LCS:
lcs.Placement=App.Placement(App.Vector(0,0,-1), App.Rotation(0,0,90), App.Vector(0,0,0))
#Get the new placement of p1 as seen from the translated and rotated LCS:
Is it documented somewhere? is there any API for that? or this is hidden knowledge borrowed from ancient aliens and posted at forum only for chosen? LOL
Thanks
Darek
github.com/dprojects
