FreeCAD is able to make similar thing found in OCCT documentation?
Hello
I've read some interesting documentation about OCCT, I'm speaking of this page:
https://dev.opencascade.org/doc/occt-7. ... algos.html
Around half of the document there is this code:
Changing radius
void CSampleTopologicalOperationsDoc::OnEvolvedblend1()
    TopoDS_Shape theBox  = BRepPrimAPI_MakeBox(200,200,200);
    BRepFilletAPI_MakeFillet  Rake(theBox);
    ChFi3d_FilletShape  FSh = ChFi3d_Rational;
    Rake.SetFilletShape(FSh);
    TColgp_Array1OfPnt2d  ParAndRad(1, 6);
    ParAndRad(1).SetCoord(0.,  10.);
    ParAndRad(1).SetCoord(50.,  20.);
    ParAndRad(1).SetCoord(70.,  20.);
    ParAndRad(1).SetCoord(130.,  60.);
    ParAndRad(1).SetCoord(160.,  30.);
    ParAndRad(1).SetCoord(200.,  20.);
    TopExp_Explorer  ex(theBox,TopAbs_EDGE);
    Rake.Add(ParAndRad, TopoDS::Edge(ex.Current()));
    TopoDS_Shape  evolvedBox = Rake.Shape();
It is possible to make similar thing in FreeCAD?
TheMarkster
Re: FreeCAD is able to make similar thing found in OCCT documentation?
Post by TheMarkster »
Werner recently added this evolve feature. This snippet is from the source code:
import PartEnums
v = App.Vector
profile = Part.makePolygon([v(0.,0.,0.), v(-60.,-60.,-100.), v(-60.,-60.,-140.)])
spine = Part.makePolygon([v(0.,0.,0.), v(100.,0.,0.), v(100.,100.,0.), v(0.,100.,0.), v(0.,0.,0.)])
evolve = spine.makeEvolved(Profile=profile, Join=PartEnums.JoinType.Arc)
Then:
Part.show(evolve)
There is also a Solid keyword for a solid.
static char* kwds_evolve[] = {"Profile", "Join", "AxeProf", "Solid", "ProfOnSpine", "Tolerance", nullptr};
Tanks but it is a different thing.
I have seen evolve and I have some problems (due to my old brain) to catch the inner working.
I have to study it more in details.
This thing if you see the image in OCCT docs, will permit to makeca fillet specifing a different radius "evolution" along the edge.
TheMarkster
Okay, yes this is different from what I was thinking of. No, I think the only fillets possible have either 1 or 2 radii defined per edge.
