For this:
dir(FreeCAD.ActiveDocument.getObjectsByLabel("MyCube")[0].Shape.Face4)
['Area', 'BoundBox', 'CenterOfMass', 'CompSolids', 'Compounds', 'Content', 'Edges', 'Faces', 'Length', 'Mass', 'Matrix', 'MatrixOfInertia', 'MemSize', 'Module', 'Orientation', 'OuterWire', 'ParameterRange', 'Placement', 'PrincipalProperties', 'ShapeType', 'Shells', 'Solids', 'StaticMoments', 'SubShapes', 'Surface', 'Tag', 'Tolerance', 'TypeId', 'Vertexes', 'Volume', 'Wire', 'Wires', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__setstate__', '__sizeof__', '__str__', '__subclasshook__', 'addWire', 'ancestorsOfType', 'check', 'childShapes', 'cleaned', 'common', 'complement', 'copy', 'countElement', 'curvatureAt', 'curveOnSurface', 'cut', 'cutHoles', 'defeaturing', 'derivative1At', 'derivative2At', 'distToShape', 'dumpContent', 'dumpToString', 'exportBinary', 'exportBrep', 'exportBrepToString', 'exportIges', 'exportStep', 'exportStl', 'extrude', 'findPlane', 'fix', 'fixTolerance', 'fuse', 'generalFuse', 'getAllDerivedFrom', 'getElement', 'getFacesFromSubelement', 'getTolerance', 'getUVNodes', 'globalTolerance', 'hashCode', 'importBinary', 'importBrep', 'importBrepFromString', 'inTolerance', 'isClosed', 'isCoplanar', 'isDerivedFrom', 'isEqual', 'isInfinite', 'isInside', 'isNull', 'isPartOfDomain', 'isPartner', 'isSame', 'isValid', 'limitTolerance', 'makeChamfer', 'makeFillet', 'makeHalfSpace', 'makeOffset', 'makeOffset2D', 'makeOffsetShape', 'makeParallelProjection', 'makePerspectiveProjection', 'makeShapeFromMesh', 'makeThickness', 'makeWires', 'mirror', 'multiFuse', 'normalAt', 'nullify', 'oldFuse', 'optimalBoundingBox', 'overTolerance', 'project', 'proximity', 'read', 'reflectLines', 'removeInternalWires', 'removeShape', 'removeSplitter', 'replaceShape', 'restoreContent', 'reverse', 'reversed', 'revolve', 'rotate', 'rotated', 'scale', 'scaled', 'section', 'sewShape', 'slice', 'slices', 'tangentAt', 'tessellate', 'toNurbs', 'transformGeometry', 'transformShape', 'transformed', 'translate', 'translated', 'validate', 'valueAt', 'writeInventor']
You click the tree item and You see what is there inside?
I want to get color but I also looking for something useful and this is the most annoying part of coding at FreeCAD.
EDIT:
I made one here: https://github.com/dprojects/scanObjects
