Scripting example and scripting challenge.
Hello, this post is a mix between some thing:
  • A Scritping example, that maybe could became a wiki page.
  • A challenge to produce a complete example with some "real challenging solid"
  • A request for help to other user to see if we could code or model a better solid
Starting from:
Some 2nd and third are courtesy of domad, from https://forum.freecadweb.org/viewtopic. ... 25#p472225 and subsequent posts.
"""test_file.py
   This code was written as an sample code
   for "FreeCAD Scripting Guide"
   Author: Carlo Dormeletti
   Copyright: 2020
   Licence: CC BY-NC-ND 4.0 IT
import math
from math import pi, sin, cos, sqrt
import FreeCAD
from FreeCAD import Placement, Rotation, Vector
import Part
import Draft
DOC_NAME = "engine_wheel"
def activate_doc():
    """activate document"""
    FreeCAD.setActiveDocument(DOC_NAME)
    FreeCAD.ActiveDocument = FreeCAD.getDocument(DOC_NAME)
    FreeCADGui.ActiveDocument = FreeCADGui.getDocument(DOC_NAME)
    print("{0} activated".format(DOC_NAME))
def setview():
    """Rearrange View"""
    DOC.recompute()
    VIEW.viewAxometric()
    VIEW.setAxisCross(True)
    VIEW.fitAll()
def deleteObject(obj):
    if hasattr(obj, "InList") and len(obj.InList) > 0:
        for o in obj.InList:
            deleteObject(o)
            try:
                DOC.removeObject(o.Name)
            except RuntimeError as rte:
                errorMsg = str(rte)
                if errorMsg != "This object is currently not part of a document":
                    FreeCAD.Console.PrintError(errorMsg)
                    return False
    return True
def clear_DOC():
    Clear the active DOCument deleting all the objects
    while DOC.Objects:
        obj = DOC.Objects[0]
        name = obj.Name
        if not hasattr(DOC, name):
            continue
        if not deleteObject(obj):
            FreeCAD.Console.PrintError("Exiting on error")
            os.sys.exit()
        DOC.removeObject(obj.Name)
        DOC.recompute()
if FreeCAD.ActiveDocument is None:
    FreeCAD.newDocument(DOC_NAME)
    print("Document: {0} Created".format(DOC_NAME))
# test if there is an active document with a "proper" name
if FreeCAD.ActiveDocument.Name == DOC_NAME:
    print("DOC_NAME exist")
else:
    print("DOC_NAME is not active")
    # test if there is a document with a "proper" name
    try:
    except NameError:
        print("No Document: {0}".format(DOC_NAME))
        print("Document Created".format(DOC_NAME))
DOC = FreeCAD.getDocument(DOC_NAME)
GUI = FreeCADGui.getDocument(DOC_NAME)
VIEW = GUI.ActiveView
#print("DOC : {0} GUI : {1}".format(DOC, GUI))
activate_doc()
#print(FreeCAD.ActiveDocument.Name)
clear_DOC()
EPS = 0.001
EPS_C = EPS * -0.5
VZOR = Vector(0, 0, 0)
ROT0 = Rotation(0, 0, 0)
As usual there are some Services lines to make thing easier when developing (they simply empty the existing model to avoid a bunch of new file creation, when relaunching the script during testing).
tangent2C, dest_pt, a2p, make_dbg_mk have served me well during some years, and are useful when calculating points, some of their result could be achieved in a different way, maybe someone has better code or some hints. (This is one of the challenge part)
def tangent2C(p1, p2, rad1, rad2):
    """calculate four tangent point to join two circles
        Parameters:
        p1    Vector  Center of circle1
        p2    Vector  Center of circle2
        rad1  float   Radius of circle1
        rad2  float   Radius of circle2
        Return:
        tg1, tg2, tg3, tg4 tangent points.
        Note:
        For make calculation not to raise an error (r0 - r1) must be positive
        if rad1 < rad2  rad1 = r1 and rad2 = r0 (tangent points are inverted)
        But putting cc1 as bigger radius circle (BRC in explication below)
        and cc2 as smaller radius circle (SRC in explication below) will
        not "invert" results, order of drawing is not important.
        With above consideration in mind, think as circles are laying on X axis,
        tg1 = BRC upper tangent points and tg3 = SRC upper tangent point
        while tg2 = BRC bottom tangent point and tg4 = SRC bottom tangent points.
    if rad1 > rad2:
        a = p1.x
        b = p1.y
        c = p2.x
        d = p2.y
        r0 = rad1
        r1 = rad2
        rd = (r0 - r1)
    elif rad1 < rad2:
        a = p2.x
        b = p2.y
        c = p1.x
        d = p1.y
        r0 = rad2
        r1 = rad1
        rd = (r0 - r1)
    else:
        a = p2.x
        b = p2.y
        c = p1.x
        d = p1.y
        r0 = rad2
        r1 = rad1
        rd = 1
    icd = sqrt(pow((c - a), 2) + pow((d - b), 2))
    #print("inter center dist: {}".format(icd))
    if icd < r0:
        raise Exception("Circles are intersecting, no way to calc tangents")
    # point where the tangent meets
    xp = (c * r0 - a * r1) / rd
    yp = (d * r0 - b * r1) / rd
    #xpcn = Part.Vertex(Vector(xp,yp))
    #Part.show(xpcn, "Xcenter")
    # Bigger radius circle tangent points
    xpa = xp - a
    ypb = yp - b
    r02 = pow(r0, 2)
    xyfa = pow(xpa, 2) + pow(ypb, 2)
    xysq = sqrt( xyfa - r02)
    x3 = (r02 * xpa + r0 * ypb * xysq) / xyfa + a
    y3 = (r02 * ypb - r0 * xpa * xysq) / xyfa + b
    x4 = (r02 * xpa - r0 * ypb * xysq) / xyfa + a
    y4 = (r02 * ypb + r0 * xpa * xysq) / xyfa + b
    xp3 = Part.Vertex(Vector(x3, y3, 0))
    Part.show(xp3, "XP3")
    xp4 = Part.Vertex(Vector(x4, y4, 0))
    Part.show(xp4, "XP4")
    # Smaller radius circle tangent points
    xpc = xp - c
    ypd = yp - d
    r12 = pow(r1, 2)
    xyfa = pow(xpc, 2) + pow(ypd, 2)
    xysq = sqrt( xyfa - r12)
    x5 = (r12 * xpc + r1 * ypd * xysq) / xyfa + c
    y5 = (r12 * ypd - r1 * xpc * xysq) / xyfa + d
    x6 = (r12 * xpc - r1 * ypd * xysq) / xyfa + c
    y6 = (r12 * ypd + r1 * xpc * xysq) / xyfa + d
    xp5 = Part.Vertex(Vector(x5, y5, 0))
    Part.show(xp5, "XP5")
    xp6 = Part.Vertex(Vector(x6, y6, 0))
    Part.show(xp6, "XP6")
    return (Vector(x3, y3, 0), Vector(x4, y4, 0), Vector(x5, y5, 0), Vector(x6, y6, 0))
def dest_pt(pt, angle, length):
    """calculate destination point
        Parameters:
        pt    = starting point
        angle =  rad
        length = units
    dpx = pt.x + math.cos(angle) * length
    dpy = pt.y + math.sin(angle) * length
    return Vector(dpx, dpy, pt.z)
def a2p(a, b):
    """Calculate angle given two point in 2d."""
    delta_y = b.y - a.y
    delta_x = b.x - a.x
    return (math.atan2(delta_y, delta_x))
def make_dbg_mk(tgt_pt, anchor, dist, desc):
    """Make a marker to show point position."""
    l0_pos = dest_pt(tgt_pt, math.radians(anchor), dist)
    o_l = Draft.make_label(
        label_type="Custom",
        target_point=tgt_pt,
        placement=l0_pos,
        custom_text=desc
    o_l.ViewObject.ArrowType = "Arrow"
    o_l.ViewObject.ArrowSize = 1
    # o_l.ViewObject.DisplayMode = u"3D text"
    # o_l.ViewObject.TextSize = '2 mm'
[\code]
For now it will produce the hub and the sprocket of the locomotive wheel.
It aims to be parametric so modifying will produce different type of "sprocketed" wheel (Sorry fo the bad term, but finding technical terms on internet is not so easy).
[code]
rim_nrad = 500
rim_hei = 40
rim_thi = 50
hu_rad = 90
hu_irad = 40
hu_lv_rad = 50
hu_lv_irad = 20
hu_lv_ia = 110
hu_thi = 40  # hub thickness
n_sp = 20
The following part make the hub.
def mk_hub():
    hu_cen = Vector(0, 0, 0)
    hu_lv_cen = Vector(0, hu_lv_ia * -1, 0)
    p3, p4, p5, p6 = tangent2C(hu_cen, hu_lv_cen, hu_rad, hu_lv_rad)
    cir1 = Part.makeCircle(hu_rad, hu_cen)
    cir2 = Part.makeCircle(hu_lv_rad, hu_lv_cen)
    tg1 = Part.LineSegment(p3, p4).toShape()
    tg2 = Part.LineSegment(p5, p6).toShape()
    rt1 = Part.LineSegment(p3, p5).toShape()
    rt2 = Part.LineSegment(p4, p6).toShape()
    elist = (tg1, tg2, rt1, rt2)
    e1list = Part.sortEdges(elist)
    wire = Part.Wire(e1list[0])
    cf1 = Part.makeFace(cir1, "Part::FaceMakerSimple")
    cf2 = Part.makeFace(cir2, "Part::FaceMakerSimple")
    wf1 = Part.makeFace(wire, "Part::FaceMakerSimple")
    sf1 = cf1.extrude(Vector(0, 0, hu_thi))
    sf2 = cf2.extrude(Vector(0, 0, hu_thi))
    sf3 = wf1.extrude(Vector(0, 0, hu_thi))
    r_hub = sf3.fuse([sf1, sf2]).removeSplitter()
    hol1 = Part.makeCylinder(hu_irad, hu_thi + EPS)
    hol1.Placement = Placement(Vector(hu_cen.x, hu_cen.y, EPS_C), ROT0)
    hol2 = Part.makeCylinder(hu_lv_irad, hu_thi + EPS)
    hol2.Placement = Placement(Vector(hu_lv_cen.x, hu_lv_cen.y, EPS_C), ROT0)
    hub = r_hub.cut((hol1, hol2)).removeSplitter()
    return hub
It uses tangent2C to find tangenf of two circles and the extrude circles and a solid made using tangents lines and two other line that join tangents to make a unique solid for the hub.
Original shape is slightly different, so another challenge is to obtain curved edges for the lines and joint them to the circle, using code only, that calculate points and generate proper lines.
This part of code model the sprockets:
def mk_sprocket(s_fact):
    spr_len = (rim_nrad - rim_hei) - hu_rad + EPS * 2
    fac = pi * 0.25
    s_len = hu_thi * s_fact
    r_ell = Part.Ellipse(Vector(0, 0, 0), hu_thi * 0.45, hu_thi * 0.25)
    r_arc = Part.ArcOfEllipse(r_ell, pi - fac, pi + fac)
    r_usp = r_arc.StartPoint
    r_up_ep = Vector(r_usp.x + s_len, r_usp.y, r_usp.z)
    up_ln = Part.LineSegment(r_usp, r_up_ep)
    r_lsp = r_arc.EndPoint
    r_lo_ep = Vector(r_lsp.x + s_len, r_lsp.y, r_lsp.z)
    lo_ln = Part.LineSegment(r_lsp, r_lo_ep)
    # Part.show(up_ln.toShape(), "up_ln")
    # Part.show(lo_ln.toShape(), "lo_ln")
    m = FreeCAD.Matrix()
    m.rotateY(math.radians(180))
    prb0 = Part.Parabola()
    prb0.Axis = Vector(0, 0, 1)
    prb0.Focal = 1.5
    # Part.show(prb0.toShape(-5,5), "parab")
    prb0.transform(m)
    edge0 = prb0.toShape(r_lsp.y, r_usp.y)
    c_len = edge0.firstVertex().Point.distanceToPoint(r_lo_ep)
    edge0.translate(Vector(c_len, 0, 0))
    el0 = [r_arc.toShape(), lo_ln.toShape(), up_ln.toShape(), edge0]
    el0s = Part.sortEdges(el0)
    wire0 = Part.Wire(el0s[0])
    return wire0
I have used a portion of ellipse for the rear part, a portion of parabola for the front part and two lines that join the sections, there are some "sharp edges" so another challenge will be to smooth these edges, I have thought to discretize the wire and decimate points, using maybe some check about tangency of adjacent points, but is beyond my mathematical skills.
These part compose the wire on which sections of the sprockets are calculated.
I have cheated a little, as shape resemble the model, but is not the same.
This part is creating the sprocket shape using loft, and cheating a little about the tapering, shape could be tuned modifying side lines length (si_le in the code below).
spr_red = (0.25, 0.20, 0.18, 0.15, 0.12)
pfls = []
for idx, si_le in enumerate(spr_red):
    incr = spr_len / (len(spr_red) - 1)
    pro1 = mk_sprocket(si_le)
    pro1.translate(Vector(0, 0, idx * incr))
    pfls.append(pro1)
    #Part.show(pro1, "profile{}".format(idx))
# print(dir(wire0.BoundBox))
# print(pfls[0].BoundBox.XMin)
loft = Part.makeLoft(pfls, True, True, False)
sp_BB = pfls[0].BoundBox
x_disp = sp_BB.XMin * -1 + (hu_thi - sp_BB.XLength) * 0.5
Note the way to move the sprocket in place, using some BB lengths to determine how much we will move rear part, as front part is varying as parameter s_fact is modifying side lines length, so x_disp (x displacement) variable is used to properly position the sprocket on the hub.
This part will make the proper sprocket spacing them along the radius.
for rot_p in range(0, n_sp):
    ang_adv = 360 / n_sp
    sprock = loft.copy()
    m = sprock.Placement.Matrix
    m.move(Vector(x_disp, 0, 0))
    m.rotateZ(math.radians(-90))
    m.rotateX(math.radians(-90))
    m.move(Vector(0, hu_rad, 0))
    m.rotateZ(math.radians(ang_adv * rot_p))
    sprock.Placement.Matrix = m
    Part.show(sprock, "sprocket{}".format(rot_p))
hub = mk_hub()
Part.show(hub, "hub")
Now the most challenging parts will be.
  1. Cut sprockets at an appropriate length, as the hub is not circular.
  2. make proper filllets as in the images above
Rim is in progress, maybe if someone has some profile to reproduce of a real locomotive rim, we could make something that "resemble the original".
for now we are here:
Hoping to have raised your attention.
This is the code file:
sprocketed_wheel.py
(9.43 KiB) Downloaded 38 times
Fell free to comment the code, and suggest modifications.
heron
Re: Scripting example and scripting challenge.
Post by heron »
Hello, first of all, congratulations and thanks for this very illustrative topic.
onekk wrote: Fri Jan 14, 2022 11:48 am tangent2C, dest_pt, a2p, make_dbg_mk have served me well during some years, and are useful when calculating points, some of their result could be achieved in a different way, maybe someone has better code or some hints. (This is one of the challenge part)
I can't understand the advanced mathematical and geometric calculations that are inside the tangen2C function, so I accepted the one challengue and I have made a function with simpler calculations.
import math
from math import sqrt, pow
doc = App.ActiveDocument
pla = App.Placement
rot = App.Rotation
vec = App.Vector
def findPoint(n, X, Y, R, ang) :
    pt = doc.addObject("Part::Vertex", "Vertex"+str(n))   # Create point and place in the circle center
    pt.X = X
    pt.Y = Y
    pt.Placement = pla(vec(R, 0, 0), rot(vec(0, 0, 1),0))   # move length radius
    pt.Placement = pla(vec(0, 0, 0), rot(vec(0, 0, 1), ang), vec(X, Y, 0)).multiply(pt.Placement)   # Incremental angle rotate
    return pt.Shape.Point
        Parameters:
        Return:
    if p1.x<=p2.x :
        a = p1.x
        b = p1.y
        c = p2.x
        d = p2.y
        r1 = rad1
        r2 = rad2
    else:
        a = p2.x
        b = p2.y
        c = p1.x
        d = p1.y
        r1 = rad2
        r2 = rad1
    ang_inc = math.degrees(math.asin( (d-b) / icd ))
    ang_tan = math.degrees(math.asin( (r1-r2) / icd ))
    ang_pt1_3 = -90 + ang_tan + ang_inc
    ang_pt2_4 = 90 - ang_tan + ang_inc
    tg1 = findPoint(1, a, b, r1, ang_pt1_3)   # Tangency point 1 (circle1)
    tg2 = findPoint(2, a, b, r1, ang_pt2_4)   # Tangency point 2 (circle1)
    tg3 = findPoint(3, c, d, r2, ang_pt1_3)   # Tangency point 3 (circle2)
    tg4 = findPoint(4, c, d, r2, ang_pt2_4)   # Tangency point 4 (circle2)
    doc.recompute()
    return (tg1, tg2, tg3, tg4)
pto = tangent2C(vec(53, -7, 0), vec(-11, -44, 0), 40, 30)
[print(i) for i in pto]
What do you think?
heron wrote: Sat Jan 15, 2022 11:09 pm Hello, first of all, congratulations and thanks for this very illustrative topic.
What do you think?
The complex mathematics was taken from an internet page. I'm not very skilled so when I need something I make some search.
Many thanks, I'm on Mobile so maybe tonight or tomorrow I will have time do study your codr.
edwilliams16
Post by edwilliams16 »
I tried my hand at making a cleaner function:
vec = App.Vector
        Parameters:
        Return:
        [tg1, tg2, tg3, tg4] tangent points.
        If one circle strictly encloses the other or are they are concentric, return []
    l= (p1-p2).Length
    if abs(rad1 - rad2) > l or l == 0:
        return []
    else:
        c = (rad1-rad2)/l
        s = sqrt(1- c*c)
        n = (p2-p1)/l #unit vector along line of centers
        m = vec(0,0,1).cross(n) #orthogonal vector
        vp = c*n + s*m  #unit vectors from center to tangent points
        vm = c*n - s*m
        return [c1 + rad1*vp, c1 + rad1*vm, c2 + rad2*vp, c2 + rad2*vm]
c1 = vec(53, -7, 0)
c2 = vec(-11, -44, 0)
r1 = 40
r2 = 30
pto = tangent2C(c1,c2 ,r1,r2)
for pt in pto:
    print(pt)
It produces the same results, so it's a matter of taste.
Screen Shot 2022-01-20 at 10.12.35 AM.png (31.05 KiB) Viewed 2981 times
Tanks edwiliamd16 this is elegant.
Sadly this post is not having more followers.
Not a problem if contributors will be effective like you.
More to come.
There are some other challenges in such drawing, that are relatively simple using GUI, more dufficult using script as you will havevto select and modify things based on mutual positions.
Thanks and Regards.
Hello, some news:
New version 3 of the drawing:
engine_wheel-v3.py
(10.84 KiB) Downloaded 30 times
  • Integrated "elegant" tangent2c from @edwilliams16, many thanks.
  • Added a rim, with a "decent profile", I have found some dimensions around so I have used these in the parameters. I have found that wheels have a minimal diameter after rectification, so I have used nominal (larger) value for diameter.
  • Used a cut solid to trim sprockets at hub, I've used slightly small diameters to have some join allowance to make a good fusion.
  • Added center reinforcement for main axle.
Some images:
Now it needs to find a way to make fillets for the junctions between sprockets, hub and rim, and add the "counterweight" (is the term correct?).
As usual if someone has a better way to do things, feel free to post some alternative code.
The intention will be to make a good example about Scritpting a "real thing" and "develop" some good "modelling habits", to show FreeCAD capabilities.
Maybe it an utopic goal, but take it "as is".
edwilliams16
        Parameters:
        pt    = starting point
        angle =  rad
        length = units
    #alternatively
    # return App.Placement(pt, App.Rotation(math.degrees(angle), 0, 0)).multVec(App.Vector(length, 0 ,0))
    # This rotates App.Vector(length, 0 ,0) by angle about the z-axis then translates it by pt
Here's a one line alternative to dest_pt The existing code is easier to understand, but commenting on using the FreeCAD Placement might be educational.
edwilliams16 wrote: Sat Jan 22, 2022 1:52 am Here's a one line alternative to dest_pt The existing code is easier to understand, but commenting on using the FreeCAD Placement might be educational.
    """Rrotates App.Vector(length, 0 ,0) by angle about the z-axis then translates it by pt
        Parameters:
        pt    = starting point
        angle =  rad
        length = units
So it will be similar to this?
It was a simple workaround, as my Vector math is not very strong, I know that there will be many elegant solutions to my problems, but haven't found any good text to catch the basis of Vector Math, in a "pratical way", usually I'm lost when explanation say as example, "applying theorem x to ..." etc.
Tanks and Regards .
edwilliams16
I was thinking
    """Rotates App.Vector(length, 0 ,0) by angle about the z-axis then translates it by pt
        Parameters:
        pt    = starting point
        angle =  rad
        length = units
      #return App.Vector(pt.x + math.cos(angle) * length,
      #                          pt.y + math.sin(angle) * length,
      #                          pt.z)
      #or
leaving the original coding to both help understand the intent and show the use of App.Placement
edwilliams16 wrote: Sat Jan 22, 2022 9:00 pm I was thinking
Yes it is an interesting way to show different things, I will incorporate it in the new version, actually the method is slightly different, as I've created intermediate variables, as Line length is way over 79 characters and my editor complains about it.
