The first macro is for automatic 2D views generation (with 6 normal projections and one isometric), available at:
https://github.com/PR-DC/PRDC_GenerateViews_FC
The second macro is for automatic drawing generation with 3 normal projections and one isometric (on the custom template), available at:
https://github.com/PR-DC/PRDC_GenerateDrawing_FC
New Macros: GenerateViews and GenerateDrawing
- mpetrasinovic
Re: New Macros: GenerateViews and GenerateDrawing
Nice.
Looking forward for a section view.
Well done thanks.
It is very interesting.
In Arch WB, I created a stair with the Stair tool. Then Generated the drawing.
The Front view is upside down.
Then I tried to Export page as SVG. When open the SVG with MS Edge, it says: "error on line 18 at column 518: Namespace prefix sodipodi on namedview is not defined"
I am new to TechDraw. Just wondering is there a control to not show the points?
Cheers,
John
Cheers,
John
- wandererfan
Perfect. Thank you.
Hi, unfortunately it`s not working on my pc.
Following message occurs:
18:39:14 C:/Users/mfhneu/AppData/Roaming/FreeCAD/Macro\test\PRDC_template_A3.svg
18:39:14 Traceback (most recent call last):
File "C:/Users/mfhneu/AppData/Roaming/FreeCAD/Macro/Autobemassung_Test.FCMacro", line 130, in <module>
template.Template = template_file
<class 'RuntimeError'>: Could not read the new template file
Please find also attached the file. (to reduce the file size I had to delete a few elements. But behaviour is same)
I would be very happy if someone knew a solution.
This is my freecad version:
OS: Windows 10 build 19045
Version: 0.21.1.33668 +26 (Git)
Branch: (HEAD detached at 0.21.1)
Hash: f6708547a9bb3f71a4aaade12109f511a72c207c
* A2plus 0.4.60n
* fasteners 0.5.0
- ArchBehandlungsraum_neu3_Stückliste_reduziert.FCStd
- (785.72 KiB) Downloaded 7 times
