I just installed last official FreeCad-0.19.3-WIN but freecad.exe hang (stop to be responsible) right after opening of GUI on my WIN 7 sp1.
FC version gatered from bin\freecadcwd.exe is (FreeCAD 0.19, Libs: 0.19R24267 +99 (Git))
This happens also with DEV FreeCAD_0.20.26858_Win-LPv12.5.4_vc17.x-x86-64 ;bin\freecadcwd.exe (FreeCAD 0.20, Libs: 0.20R26858 (Git))
I suppose it could be related to binding both with Python 3.8.6+ (heads/3.8-dirty:a12f459ec2, Nov 5 2020, 12:01:10) which is not last official PY 3 version supporting WIN 7. This should be Python 3.8.6 - Sept. 24, 2020 ; at least according to list https://www.python.org/downloads/windows/
I noticed that
Release FC 0.18.16 work verry nicelly using python 3.6.6
and 0.19.24267-wn-conda (FreeCAD 0.19, Libs: 0.19R24267 (Git)), suprisingly also works on win7 using Python 3.8.8 | packaged by conda-forge | (default, Feb 20 2021, 15:50:08) [MSC v .1916 64 bit (AMD64)] on win32 - quid mirum!
I will be appreciated for tips how to start new 0.19.3 o win7, or at least track what is the hunging reason.
btw.
It would be pity if FC eliminate Windows 7 users by using incompatibile python libraries version > 3.8.
PSiedlaczek
FreeCad 0.19.3 not running on WIN7, python 3.x version ?
Re: FreeCad 0.19.3 not running on WIN7, python 3.x version ?
Did you look already at the Known OS specific issues?
Ensure you have the 64 bit version of windows 7. Personally, I would not run software on a computed connected online if it's no longer getting security updates.
chrisb, thanks for suggestion. I ll try to update my little bit old nVidia GT 540M driver. This look promising solution, but can be tricky to do as nVidia not support win7 anymore (at least officially). I ll dig it somwhere.
Meanwhile i run freecad --log-file c:\temp\freecad.log and i noticed that the error is related to QT5 as quited below (from first error line).
As i cannot open GUI to try switching to suggested qt4, I wonder how shoud look *.cfg file that can be used as arg to freecad.exe --user-cfg. Mayby You can point me to an example?
Psieldaczek
Log: Id: 7612: C:\windows\system32\mscms.dll:mscms.dll (000007FEF99A0000), size: 638976 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\mscms.dll', fileVersion: 6.1.7601.24537
Log: Id: 7612: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 000000018006DF22)
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000000018006DF22)
Log: Id: 7612: 000000018006DF22 (ig4icd64): (filename not available): (function-name not available)
Log: Id: 7612: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 000000018006E397)
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000000018006E397)
Log: Id: 7612: 000000018006E397 (ig4icd64): (filename not available): (function-name not available)
Log: Id: 7612: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00000001800F6BC5)
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00000001800F6BC5)
Log: Id: 7612: 00000001800F6BC5 (ig4icd64): (filename not available): (function-name not available)
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED64DA8A8)
Log: Id: 7612: 000007FED64DA8A8 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6D14A2F)
Log: Id: 7612: 000007FED6D14A2F (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6D28533)
Log: Id: 7612: 000007FED6D28533 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6D355B7)
Log: Id: 7612: 000007FED6D355B7 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED833C7C5)
Log: Id: 7612: 000007FED833C7C5 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED7993313)
Log: Id: 7612: 000007FED7993313 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED4E33420)
Log: Id: 7612: 000007FED4E33420 (Qt5WebEngineCore): (filename not available): QWebEngineUrlRequestInfo::QWebEngineUrlRequestInfo
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED79957CF)
Log: Id: 7612: 000007FED79957CF (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED4E10D43)
Log: Id: 7612: 000007FED4E10D43 (Qt5WebEngineCore): (filename not available): QWebEngineUrlRequestInfo::QWebEngineUrlRequestInfo
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6994D38)
Log: Id: 7612: 000007FED6994D38 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED47FDAC3)
Log: Id: 7612: 000007FED47FDAC3 (Qt5WebEngineCore): (filename not available): QtWebEngineCore::JavaScriptDialogController::qt_static_metacall
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6069E75)
Log: Id: 7612: 000007FED6069E75 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6101D0F)
Log: Id: 7612: 000007FED6101D0F (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED61018A1)
Log: Id: 7612: 000007FED61018A1 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED60E4C9D)
Log: Id: 7612: 000007FED60E4C9D (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED610219F)
Log: Id: 7612: 000007FED610219F (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6094D75)
Log: Id: 7612: 000007FED6094D75 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED6098385)
Log: Id: 7612: 000007FED6098385 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FED60606A5)
Log: Id: 7612: 000007FED60606A5 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00000000774D556D)
Log: Id: 7612: 00000000774D556D (kernel32): (filename not available): BaseThreadInitThunk
Log: Id: 7612: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000000007773372D)
Log: Id: 7612: 000000007773372D (ntdll): (filename not available): RtlUserThreadStart
Log: *** Unhandled Exception!
Log: ExpCode: 0xC0000005
Log: ExpFlags: 0
Log: ExpAddress: 0x8006DF22
Psieldaczek
Unfortunately graphic driver update did not fixed FreeCad startup. I run WIN 7 with nVidia GeForce GT 540M updated to newest driver bundle package from nVidia site, ver 391.35 which result in driver ver. 23.21.13.9135. But still FreeCAD 0.19.3 and 0.20 can not start GUI properly. Always 4 sec after GUI show up, FC become irresponsible and crash. I noticed that start page is white, and I suppose its not open. I attach log below, shortened by couple initialisation lines which were ok.
freecad --log-file c:\temp\freecad0.19.3.log :
Msg: FreeCAD 0.19, Libs: 0.19R24267 +99 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
Log: Time = Fri Jan 7 13:58:36 2022
Log: AppDataSkipVendor = true
Log: AppHomePath = C:/Program Files/FreeCAD 0.19/
Log: AppIcon = freecad
Log: AppTempPath = C:\Users\pi\AppData\Local\Temp\
Log: BinPath = C:/Program Files/FreeCAD 0.19/bin\
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git
Log: BuildRevision = 24267 +99 (Git)
Log: BuildRevisionBranch = Branch_0.19.3
Log: BuildRevisionDate = 2021/12/04 20:56:30
Log: BuildRevisionHash = 6530e364184ce05ccff39501e175cf2237e6ee4b
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 19
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
Log: Debug = 0
Log: DocPath = C:/Program Files/FreeCAD 0.19/doc\
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.19
Log: LoggingConsole = 1
Log: LoggingFile = 1
Log: LoggingFileName = c:\temp\freecad1.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Broadcom\Broadcom 802.11 Network Adapter\Driver;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files\dotnet\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Python37\Scripts\;C:\Python37\
Log: PythonSearchPath = C:\Program Files\FreeCAD 0.19\bin\python38.zip;C:\Program Files\FreeCAD 0.19\bin\DLLs;C:\Program Files\FreeCAD 0.19\bin\lib;C:\Program Files\FreeCAD 0.19\bin
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = C:\Users\pi\AppData\Roaming\FreeCAD\system.cfg
Log: UserAppData = C:\Users\pi\AppData\Roaming\FreeCAD\
Log: UserHomePath = C:\Users\pi\Documents
Log: UserParameter = C:\Users\pi\AppData\Roaming\FreeCAD\user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\AddonManager... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Arch... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Tux(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Web... done
Log: Using C:\Program Files\FreeCAD 0.19\Mod as module path!
Log: System path after init:
Log: C:\Program Files\FreeCAD 0.19\bin
Log: C:\Program Files\FreeCAD 0.19\Mod\AddonManager
Log: C:\Program Files\FreeCAD 0.19\Mod\Arch
Log: C:\Program Files\FreeCAD 0.19\Mod\Draft
Log: C:\Program Files\FreeCAD 0.19\Mod\Drawing
Log: C:\Program Files\FreeCAD 0.19\Mod\Fem
Log: C:\Program Files\FreeCAD 0.19\Mod\Idf
Log: C:\Program Files\FreeCAD 0.19\Mod\Image
Log: C:\Program Files\FreeCAD 0.19\Mod\Import
Log: C:\Program Files\FreeCAD 0.19\Mod\Inspection
Log: C:\Program Files\FreeCAD 0.19\Mod\Material
Log: C:\Program Files\FreeCAD 0.19\Mod\Measure
Log: C:\Program Files\FreeCAD 0.19\Mod\Mesh
Log: C:\Program Files\FreeCAD 0.19\Mod\MeshPart
Log: C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD
Log: C:\Program Files\FreeCAD 0.19\Mod\Part
Log: C:\Program Files\FreeCAD 0.19\Mod\PartDesign
Log: C:\Program Files\FreeCAD 0.19\Mod\Path
Log: C:\Program Files\FreeCAD 0.19\Mod\Plot
Log: C:\Program Files\FreeCAD 0.19\Mod\Points
Log: C:\Program Files\FreeCAD 0.19\Mod\Raytracing
Log: C:\Program Files\FreeCAD 0.19\Mod\ReverseEngineering
Log: C:\Program Files\FreeCAD 0.19\Mod\Robot
Log: C:\Program Files\FreeCAD 0.19\Mod\Show
Log: C:\Program Files\FreeCAD 0.19\Mod\Sketcher
Log: C:\Program Files\FreeCAD 0.19\Mod\Spreadsheet
Log: C:\Program Files\FreeCAD 0.19\Mod\Start
Log: C:\Program Files\FreeCAD 0.19\Mod\Surface
Log: C:\Program Files\FreeCAD 0.19\Mod\TechDraw
Log: C:\Program Files\FreeCAD 0.19\Mod\Test
Log: C:\Program Files\FreeCAD 0.19\Mod\Tux
Log: C:\Program Files\FreeCAD 0.19\Mod\Web
Log: C:\Program Files\Common Files\Microsoft Shared\Windows Live
Log: C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live
Log: C:\windows\system32
Log: C:\windows
Log: C:\windows\System32\Wbem
Log: C:\windows\System32\WindowsPowerShell\v1.0\
Log: C:\Program Files\Broadcom\Broadcom 802.11 Network Adapter\Driver
Log: C:\Program Files (x86)\Windows Live\Shared
Log: C:\Program Files\WIDCOMM\Bluetooth Software\
Log: C:\Program Files\WIDCOMM\Bluetooth Software\syswow64
Log: C:\Program Files\dotnet\
Log: C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
Log: C:\Python37\Scripts\
Log: C:\Python37\
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version is: 3.0 (3.0.0 - Build 8.15.10.2253)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init: Searching modules...
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Draft... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Drawing... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Fem... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Idf(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Image... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Import... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Inspection... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Material... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Measure(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Mesh... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\MeshPart... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Part... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\PartDesign... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Path... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Plot... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Points... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Raytracing... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\ReverseEngineering... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Robot... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Show(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Sketcher... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Spreadsheet... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Start... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Surface... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\TechDraw... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Test... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.19\Mod\Tux... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: 3Dconnexion device not attached.
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Id: 7836: SymInit: Symbol-SearchPath: '.;C:\Program Files\FreeCAD 0.19\bin;C:\Program Files\FreeCAD 0.19\bin;C:\windows;C:\windows\system32;SRV*C:\websymbols*http://msdl.microsoft.com/download/symbols;', symOptions: 530, UserName: 'pi'
Log: Id: 7836: OS-Version: 6.1.7601 (Service Pack 1) 0x300-0x1
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\FreeCAD.exe:FreeCAD.exe (000000013FB00000), size: 155648 (result: 0), SymType: '-nosymbols-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCAD.exe', fileVersion: 0.19.0.16100
Log: Id: 7836: C:\windows\SYSTEM32\ntdll.dll:ntdll.dll (0000000077680000), size: 1699840 (result: 0), SymType: '-exported-', PDB: 'C:\windows\SYSTEM32\ntdll.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\kernel32.dll:kernel32.dll (0000000077560000), size: 1175552 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\kernel32.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\KERNELBASE.dll:KERNELBASE.dll (000007FEFD1F0000), size: 421888 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\KERNELBASE.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\FreeCADGui.dll:FreeCADGui.dll (000007FEEB250000), size: 12529664 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCADGui.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\FreeCADApp.dll:FreeCADApp.dll (000007FEEC800000), size: 3080192 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCADApp.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\FreeCADBase.dll:FreeCADBase.dll (000007FEED600000), size: 1269760 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\FreeCADBase.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\xerces-c_3_2.dll:xerces-c_3_2.dll (000007FEEC540000), size: 2875392 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\xerces-c_3_2.dll', fileVersion: 3.2.2.0
Log: Id: 7836: C:\windows\system32\ADVAPI32.dll:ADVAPI32.dll (000007FEFEC70000), size: 897024 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ADVAPI32.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\msvcrt.dll:msvcrt.dll (000007FEFF600000), size: 651264 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\msvcrt.dll', fileVersion: 7.0.7601.17744
Log: Id: 7836: C:\windows\SYSTEM32\sechost.dll:sechost.dll (000007FEFE5C0000), size: 126976 (result: 0), SymType: '-exported-', PDB: 'C:\windows\SYSTEM32\sechost.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\RPCRT4.dll:RPCRT4.dll (000007FEFEA40000), size: 1228800 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\RPCRT4.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\MSVCP140.dll:MSVCP140.dll (000007FEF0460000), size: 577536 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\MSVCP140.dll', fileVersion: 14.28.29910.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140.dll:VCRUNTIME140.dll (000007FEF6D00000), size: 106496 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140.dll', fileVersion: 14.28.29910.0
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-runtime-l1-1-0.dll:api-ms-win-crt-runtime-l1-1-0.dll (000007FEFA310000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-runtime-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\ucrtbase.DLL:ucrtbase.DLL (000007FEEECF0000), size: 999424 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ucrtbase.DLL', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-core-timezone-l1-1-0.dll:api-ms-win-core-timezone-l1-1-0.dll (000007FEFA300000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-core-timezone-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-core-file-l2-1-0.dll:api-ms-win-core-file-l2-1-0.dll (000007FEF9FA0000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-core-file-l2-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-core-localization-l1-2-0.dll:api-ms-win-core-localization-l1-2-0.dll (000007FEF82A0000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-core-localization-l1-2-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-core-synch-l1-2-0.dll:api-ms-win-core-synch-l1-2-0.dll (000007FEF8AF0000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-core-synch-l1-2-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-core-processthreads-l1-1-1.dll:api-ms-win-core-processthreads-l1-1-1.dll (000007FEF6F20000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-core-processthreads-l1-1-1.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-core-file-l1-2-0.dll:api-ms-win-core-file-l1-2-0.dll (000007FEF6310000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-core-file-l1-2-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-heap-l1-1-0.dll:api-ms-win-crt-heap-l1-1-0.dll (000007FEF6CF0000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-heap-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-string-l1-1-0.dll:api-ms-win-crt-string-l1-1-0.dll (000007FEF5D30000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-string-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-stdio-l1-1-0.dll:api-ms-win-crt-stdio-l1-1-0.dll (000007FEF6070000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-stdio-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-convert-l1-1-0.dll:api-ms-win-crt-convert-l1-1-0.dll (000007FEF5B30000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-convert-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140_1.dll:VCRUNTIME140_1.dll (000007FEF5B40000), size: 49152 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\VCRUNTIME140_1.dll', fileVersion: 14.28.29910.0
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-locale-l1-1-0.dll:api-ms-win-crt-locale-l1-1-0.dll (000007FEF5760000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-locale-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-filesystem-l1-1-0.dll:api-ms-win-crt-filesystem-l1-1-0.dll (000007FEF5B20000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-filesystem-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-time-l1-1-0.dll:api-ms-win-crt-time-l1-1-0.dll (000007FEF4B40000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-time-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-environment-l1-1-0.dll:api-ms-win-crt-environment-l1-1-0.dll (000007FEF4B60000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-environment-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-math-l1-1-0.dll:api-ms-win-crt-math-l1-1-0.dll (000007FEF43E0000), size: 20480 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-math-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-utility-l1-1-0.dll:api-ms-win-crt-utility-l1-1-0.dll (000007FEF4B30000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-utility-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\zlib.dll:zlib.dll (000007FEF4080000), size: 110592 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\zlib.dll', fileVersion: 1.2.11.0
Log: Id: 7836: C:\windows\system32\VERSION.dll:VERSION.dll (000007FEFC1F0000), size: 49152 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\VERSION.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Core.dll:Qt5Core.dll (000007FEEBF70000), size: 6053888 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Core.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\windows\system32\MPR.dll:MPR.dll (000007FEF3920000), size: 98304 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\MPR.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\USERENV.dll:USERENV.dll (000007FEFD350000), size: 126976 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\USERENV.dll', fileVersion: 6.1.7601.24535
Log: Id: 7836: C:\windows\system32\profapi.dll:profapi.dll (000007FEFD1D0000), size: 61440 (result: 0), SymType: '-nosymbols-', PDB: 'C:\windows\system32\profapi.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\NETAPI32.dll:NETAPI32.dll (000007FEFAEE0000), size: 90112 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\NETAPI32.dll', fileVersion: 6.1.7601.17887
Log: Id: 7836: C:\windows\system32\netutils.dll:netutils.dll (000007FEFAED0000), size: 49152 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\netutils.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\srvcli.dll:srvcli.dll (000007FEFCC50000), size: 143360 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\srvcli.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\wkscli.dll:wkscli.dll (000007FEFAEB0000), size: 86016 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\wkscli.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\WS2_32.dll:WS2_32.dll (000007FEFE8E0000), size: 315392 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WS2_32.dll', fileVersion: 6.1.7601.23451
Log: Id: 7836: C:\windows\system32\NSI.dll:NSI.dll (000007FEFE870000), size: 32768 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\NSI.dll', fileVersion: 6.1.7601.23889
Log: Id: 7836: C:\windows\system32\ole32.dll:ole32.dll (000007FEFF360000), size: 2093056 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ole32.dll', fileVersion: 6.1.7601.24537
Log: Id: 7836: C:\windows\system32\GDI32.dll:GDI32.dll (000007FEFD720000), size: 421888 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\GDI32.dll', fileVersion: 6.1.7601.24540
Log: Id: 7836: C:\windows\system32\USER32.dll:USER32.dll (0000000077460000), size: 1028096 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\USER32.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\LPK.dll:LPK.dll (000007FEFE660000), size: 57344 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\LPK.dll', fileVersion: 6.1.7601.24537
Log: Id: 7836: C:\windows\system32\USP10.dll:USP10.dll (000007FEFEBA0000), size: 831488 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\USP10.dll', fileVersion: 1.626.7601.24535
Log: Id: 7836: C:\windows\system32\SHELL32.dll:SHELL32.dll (000007FEFD790000), size: 14200832 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\SHELL32.dll', fileVersion: 6.1.7601.24468
Log: Id: 7836: C:\windows\system32\SHLWAPI.dll:SHLWAPI.dll (000007FEFE5E0000), size: 462848 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\SHLWAPI.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\WINMM.dll:WINMM.dll (000007FEFAB90000), size: 241664 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WINMM.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\MSVCP140_1.dll:MSVCP140_1.dll (000007FEF40B0000), size: 36864 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\MSVCP140_1.dll', fileVersion: 14.28.29910.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\python38.dll:python38.dll (000007FEE9380000), size: 4390912 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\python38.dll', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-process-l1-1-0.dll:api-ms-win-crt-process-l1-1-0.dll (000007FEF43D0000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-process-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-conio-l1-1-0.dll:api-ms-win-crt-conio-l1-1-0.dll (000007FEF40A0000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-conio-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\boost_filesystem-vc141-mt-x64-1_67.dll:boost_filesystem-vc141-mt-x64-1_67.dll (000007FEF38F0000), size: 147456 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\boost_filesystem-vc141-mt-x64-1_67.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\boost_system-vc141-mt-x64-1_67.dll:boost_system-vc141-mt-x64-1_67.dll (000007FEF4040000), size: 40960 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\boost_system-vc141-mt-x64-1_67.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\boost_program_options-vc141-mt-x64-1_67.dll:boost_program_options-vc141-mt-x64-1_67.dll (000007FEF03F0000), size: 438272 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\boost_program_options-vc141-mt-x64-1_67.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\boost_regex-vc141-mt-x64-1_67.dll:boost_regex-vc141-mt-x64-1_67.dll (000007FEEB170000), size: 868352 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\boost_regex-vc141-mt-x64-1_67.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Xml.dll:Qt5Xml.dll (000007FEF3940000), size: 221184 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Xml.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\windows\system32\SHFOLDER.dll:SHFOLDER.dll (000007FEF4070000), size: 28672 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\SHFOLDER.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Coin4.dll:Coin4.dll (000007FEE7450000), size: 6365184 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Coin4.dll', fileVersion: 4.0.1.0
Log: Id: 7836: C:\windows\system32\OPENGL32.dll:OPENGL32.dll (000007FEF1140000), size: 1167360 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\OPENGL32.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\GLU32.dll:GLU32.dll (000007FEF24B0000), size: 184320 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\GLU32.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\DDRAW.dll:DDRAW.dll (000007FEF1040000), size: 987136 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\DDRAW.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\DCIMAN32.dll:DCIMAN32.dll (000007FEF24A0000), size: 32768 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\DCIMAN32.dll', fileVersion: 6.1.7601.24537
Log: Id: 7836: C:\windows\system32\SETUPAPI.dll:SETUPAPI.dll (000007FEFE670000), size: 1929216 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\SETUPAPI.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\CFGMGR32.dll:CFGMGR32.dll (000007FEFD370000), size: 221184 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\CFGMGR32.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\OLEAUT32.dll:OLEAUT32.dll (000007FEFED50000), size: 897024 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\OLEAUT32.dll', fileVersion: 6.1.7601.24537
Log: Id: 7836: C:\windows\system32\DEVOBJ.dll:DEVOBJ.dll (000007FEFD3B0000), size: 106496 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\DEVOBJ.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\dwmapi.dll:dwmapi.dll (000007FEFB290000), size: 98304 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\dwmapi.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\api-ms-win-crt-multibyte-l1-1-0.dll:api-ms-win-crt-multibyte-l1-1-0.dll (000007FEF3DB0000), size: 20480 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-crt-multibyte-l1-1-0.dll', fileVersion: 10.0.14393.2990
Log: Id: 7836: C:\windows\system32\HID.DLL:HID.DLL (000007FEFB2B0000), size: 45056 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\HID.DLL', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5PrintSupport.dll:Qt5PrintSupport.dll (000007FEF38A0000), size: 323584 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5PrintSupport.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Widgets.dll:Qt5Widgets.dll (000007FEE6F00000), size: 5509120 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Widgets.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Gui.dll:Qt5Gui.dll (000007FEE6840000), size: 7057408 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Gui.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\windows\system32\d3d11.dll:d3d11.dll (000007FEF31B0000), size: 1921024 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\d3d11.dll', fileVersion: 6.2.9200.16570
Log: Id: 7836: C:\windows\system32\dxgi.dll:dxgi.dll (000007FEF5700000), size: 380928 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\dxgi.dll', fileVersion: 6.2.9200.16492
Log: Id: 7836: C:\windows\system32\UxTheme.dll:UxTheme.dll (000007FEFB670000), size: 352256 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\UxTheme.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\WINSPOOL.DRV:WINSPOOL.DRV (000007FEFB060000), size: 462848 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WINSPOOL.DRV', fileVersion: 6.1.7601.24383
Log: Id: 7836: C:\windows\system32\COMDLG32.dll:COMDLG32.dll (000007FEFE520000), size: 618496 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\COMDLG32.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_a4d981ff711297b6\COMCTL32.dll:COMCTL32.dll (000007FEF84E0000), size: 655360 (result: 0), SymType: '-exported-', PDB: 'C:\windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_a4d981ff711297b6\COMCTL32.dll', fileVersion: 5.82.7601.18837
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Svg.dll:Qt5Svg.dll (000007FEF0610000), size: 344064 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Svg.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5WinExtras.dll:Qt5WinExtras.dll (000007FEF0870000), size: 249856 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5WinExtras.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\pyside2.cp38-win_amd64.dll:pyside2.cp38-win_amd64.dll (000007FEEFA60000), size: 172032 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\pyside2.cp38-win_amd64.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\shiboken2.cp38-win_amd64.dll:shiboken2.cp38-win_amd64.dll (000007FEEF930000), size: 495616 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\shiboken2.cp38-win_amd64.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Qml.dll:Qt5Qml.dll (000007FEE9860000), size: 3608576 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Qml.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Network.dll:Qt5Network.dll (000007FEEB020000), size: 1355776 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Network.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\windows\system32\DNSAPI.dll:DNSAPI.dll (000007FEFC760000), size: 372736 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\DNSAPI.dll', fileVersion: 6.1.7601.24168
Log: Id: 7836: C:\windows\system32\IPHLPAPI.DLL:IPHLPAPI.DLL (000007FEFA6A0000), size: 159744 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\IPHLPAPI.DLL', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\WINNSI.DLL:WINNSI.DLL (000007FEFA5E0000), size: 45056 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WINNSI.DLL', fileVersion: 6.1.7601.23889
Log: Id: 7836: C:\windows\system32\CRYPT32.dll:CRYPT32.dll (000007FEFD3D0000), size: 1495040 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\CRYPT32.dll', fileVersion: 6.1.7601.24542
Log: Id: 7836: C:\windows\system32\MSASN1.dll:MSASN1.dll (000007FEFD1E0000), size: 61440 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\MSASN1.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\IMM32.DLL:IMM32.DLL (000007FEFEB70000), size: 188416 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\IMM32.DLL', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\MSCTF.dll:MSCTF.dll (000007FEFE930000), size: 1093632 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\MSCTF.dll', fileVersion: 6.1.7601.24520
Log: Id: 7836: C:\windows\system32\nvinitx.dll:nvinitx.dll (000007FEFA790000), size: 196608 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\nvinitx.dll', fileVersion: 23.21.13.9135
Log: Id: 7836: C:\Program Files\NVIDIA Corporation\CoProcManager\detoured.dll:detoured.dll (0000000066950000), size: 24576 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\NVIDIA Corporation\CoProcManager\detoured.dll'
Log: Id: 7836: C:\Program Files\NVIDIA Corporation\CoProcManager\nvd3d9wrapx.dll:nvd3d9wrapx.dll (000007FEFA6F0000), size: 229376 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\NVIDIA Corporation\CoProcManager\nvd3d9wrapx.dll', fileVersion: 23.21.13.9135
Log: Id: 7836: C:\Program Files\NVIDIA Corporation\CoProcManager\nvdxgiwrapx.dll:nvdxgiwrapx.dll (000007FEFA4F0000), size: 147456 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\NVIDIA Corporation\CoProcManager\nvdxgiwrapx.dll', fileVersion: 23.21.13.9135
Log: Id: 7836: C:\windows\system32\cryptbase.dll:cryptbase.dll (000007FEFD020000), size: 61440 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\cryptbase.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\CRYPTSP.dll:CRYPTSP.dll (000007FEFC940000), size: 98304 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\CRYPTSP.dll', fileVersion: 6.1.7601.24499
Log: Id: 7836: C:\windows\system32\rsaenh.dll:rsaenh.dll (000007FEFC640000), size: 290816 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\rsaenh.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\dbghelp.dll:dbghelp.dll (000007FEF59F0000), size: 1200128 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\dbghelp.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\platforms\qwindows.dll:qwindows.dll (000007FEE9D50000), size: 1495040 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\platforms\qwindows.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\windows\system32\WTSAPI32.dll:WTSAPI32.dll (000007FEFC380000), size: 69632 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WTSAPI32.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\WINTRUST.dll:WINTRUST.dll (000007FEFD540000), size: 241664 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WINTRUST.dll', fileVersion: 6.1.7601.24542
Log: Id: 7836: C:\windows\system32\ig4icd64.dll:ig4icd64.dll (0000000180000000), size: 19709952 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ig4icd64.dll', fileVersion: 8.15.10.2253
Log: Id: 7836: C:\windows\system32\d3d9.dll:d3d9.dll (000007FEF3B90000), size: 2093056 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\d3d9.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\d3d8thk.dll:d3d8thk.dll (000007FEFB730000), size: 28672 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\d3d8thk.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\nvumdshimx.dll:nvumdshimx.dll (000007FEF5470000), size: 532480 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\nvumdshimx.dll', fileVersion: 23.21.13.9135
Log: Id: 7836: C:\windows\system32\igdumd64.dll:igdumd64.dll (0000000003660000), size: 7520256 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\igdumd64.dll', fileVersion: 8.15.10.2253
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\styles\qwindowsvistastyle.dll:qwindowsvistastyle.dll (000007FEF0D40000), size: 155648 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\styles\qwindowsvistastyle.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qgif.dll:qgif.dll (000007FEF3FB0000), size: 53248 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qgif.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qicns.dll:qicns.dll (000007FEF39E0000), size: 61440 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qicns.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qico.dll:qico.dll (000007FEF3DA0000), size: 53248 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qico.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qjpeg.dll:qjpeg.dll (000007FEEF460000), size: 438272 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qjpeg.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qsvg.dll:qsvg.dll (000007FEF3890000), size: 49152 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qsvg.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qtga.dll:qtga.dll (000007FEF24E0000), size: 49152 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qtga.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qtiff.dll:qtiff.dll (000007FEEBF00000), size: 405504 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qtiff.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qwbmp.dll:qwbmp.dll (000007FEF24F0000), size: 45056 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qwbmp.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\imageformats\qwebp.dll:qwebp.dll (000007FEEAF90000), size: 536576 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\imageformats\qwebp.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\windows\system32\dwrite.dll:dwrite.dll (000007FEF5850000), size: 1671168 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\dwrite.dll', fileVersion: 6.2.9200.22902
Log: Id: 7836: C:\windows\system32\RpcRtRemote.dll:RpcRtRemote.dll (000007FEFD0D0000), size: 81920 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\RpcRtRemote.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\python3.DLL:python3.DLL (000007FEF2450000), size: 61440 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\python3.DLL', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\pivy\_coin.cp38-win_amd64.pyd:_coin.cp38-win_amd64.pyd (000007FEE5A10000), size: 14835712 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\pivy\_coin.cp38-win_amd64.pyd'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_bz2.pyd:_bz2.pyd (000007FEEF910000), size: 94208 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_bz2.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_lzma.pyd:_lzma.pyd (000007FEEF430000), size: 172032 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_lzma.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\shiboken2\shiboken2.cp38-win_amd64.pyd:shiboken2.cp38-win_amd64.pyd (000007FEF2460000), size: 36864 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\shiboken2\shiboken2.cp38-win_amd64.pyd'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\PySide2\QtGui.cp38-win_amd64.pyd:QtGui.cp38-win_amd64.pyd (000007FEE7BF0000), size: 3829760 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\PySide2\QtGui.cp38-win_amd64.pyd'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\PySide2\QtCore.cp38-win_amd64.pyd:QtCore.cp38-win_amd64.pyd (000007FEE9030000), size: 3473408 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\PySide2\QtCore.cp38-win_amd64.pyd'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\PySide2\QtWidgets.cp38-win_amd64.pyd:QtWidgets.cp38-win_amd64.pyd (000007FEE5400000), size: 6332416 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\PySide2\QtWidgets.cp38-win_amd64.pyd'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_ctypes.pyd:_ctypes.pyd (000007FEEF400000), size: 135168 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_ctypes.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\libffi-7.dll:libffi-7.dll (000007FEF0790000), size: 45056 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\libffi-7.dll'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_hashlib.pyd:_hashlib.pyd (000007FEF0780000), size: 53248 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_hashlib.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\libcrypto-1_1.dll:libcrypto-1_1.dll (000007FEE50B0000), size: 3432448 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\libcrypto-1_1.dll', fileVersion: 1.1.1.7
Log: Id: 7836: C:\windows\system32\bcrypt.dll:bcrypt.dll (000007FEFCB00000), size: 139264 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\bcrypt.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_socket.pyd:_socket.pyd (000007FEEECD0000), size: 90112 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_socket.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\select.pyd:select.pyd (000007FEF0600000), size: 36864 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\select.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_ssl.pyd:_ssl.pyd (000007FEEECA0000), size: 159744 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_ssl.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\libssl-1_1.dll:libssl-1_1.dll (000007FEE9CA0000), size: 704512 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\libssl-1_1.dll', fileVersion: 1.1.1.7
Log: Id: 7836: C:\windows\system32\bcryptprimitives.dll:bcryptprimitives.dll (000007FEFCA70000), size: 311296 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\bcryptprimitives.dll', fileVersion: 6.1.7601.23451
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_asyncio.pyd:_asyncio.pyd (000007FEED5E0000), size: 73728 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_asyncio.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\DLLs\_overlapped.pyd:_overlapped.pyd (000007FEF03E0000), size: 53248 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\DLLs\_overlapped.pyd', fileVersion: 3.8.6150.1013
Log: Id: 7836: C:\windows\system32\mswsock.dll:mswsock.dll (000007FEFC8E0000), size: 348160 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\mswsock.dll', fileVersion: 6.1.7601.23451
Log: Id: 7836: C:\windows\System32\wshtcpip.dll:wshtcpip.dll (000007FEFC2C0000), size: 28672 (result: 0), SymType: '-exported-', PDB: 'C:\windows\System32\wshtcpip.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\iconengines\qsvgicon.dll:qsvgicon.dll (000007FEEF900000), size: 57344 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\iconengines\qsvgicon.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\lib\StartGui.pyd:StartGui.pyd (000007FEE4FD0000), size: 901120 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\lib\StartGui.pyd'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\lib\WebGui.pyd:WebGui.pyd (000007FEEBEA0000), size: 348160 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\lib\WebGui.pyd'
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5WebEngineWidgets.dll:Qt5WebEngineWidgets.dll (000007FEED5A0000), size: 258048 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5WebEngineWidgets.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5WebEngineCore.dll:Qt5WebEngineCore.dll (000007FEDECF0000), size: 103616512 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5WebEngineCore.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Quick.dll:Qt5Quick.dll (000007FEDE8F0000), size: 4161536 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Quick.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5QmlModels.dll:Qt5QmlModels.dll (000007FEEAF20000), size: 446464 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5QmlModels.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5WebChannel.dll:Qt5WebChannel.dll (000007FEEAD90000), size: 143360 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5WebChannel.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5Positioning.dll:Qt5Positioning.dll (000007FEEAC70000), size: 327680 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5Positioning.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\windows\system32\ncrypt.dll:ncrypt.dll (000007FEFCB30000), size: 327680 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ncrypt.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\Secur32.dll:Secur32.dll (000007FEFCDC0000), size: 45056 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\Secur32.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\SSPICLI.DLL:SSPICLI.DLL (000007FEFCF90000), size: 151552 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\SSPICLI.DLL', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\WINHTTP.dll:WINHTTP.dll (000007FEF87D0000), size: 462848 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WINHTTP.dll', fileVersion: 6.1.7601.24000
Log: Id: 7836: C:\windows\system32\webio.dll:webio.dll (000007FEF8760000), size: 409600 (result: 0), SymType: '-nosymbols-', PDB: 'C:\windows\system32\webio.dll', fileVersion: 6.1.7601.17725
Log: Id: 7836: C:\windows\system32\dxva2.dll:dxva2.dll (000007FEF9EC0000), size: 135168 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\dxva2.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\dhcpcsvc.DLL:dhcpcsvc.DLL (000007FEFA380000), size: 98304 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\dhcpcsvc.DLL', fileVersion: 6.1.7601.24498
Log: Id: 7836: C:\windows\system32\urlmon.dll:urlmon.dll (000007FEFD590000), size: 1613824 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\urlmon.dll', fileVersion: 11.0.9600.19597
Log: Id: 7836: C:\windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll:api-ms-win-downlevel-ole32-l1-1-0.dll (000007FEFD300000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll', fileVersion: 6.2.9200.16492
Log: Id: 7836: C:\windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll:api-ms-win-downlevel-shlwapi-l1-1-0.dll (000007FEFD580000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll', fileVersion: 6.2.9200.16492
Log: Id: 7836: C:\windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll:api-ms-win-downlevel-advapi32-l1-1-0.dll (000007FEFD320000), size: 20480 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll', fileVersion: 6.2.9200.16492
Log: Id: 7836: C:\windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll:api-ms-win-downlevel-user32-l1-1-0.dll (000007FEFD340000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll', fileVersion: 6.2.9200.16492
Log: Id: 7836: C:\windows\system32\api-ms-win-downlevel-version-l1-1-0.dll:api-ms-win-downlevel-version-l1-1-0.dll (000007FEFD310000), size: 16384 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-downlevel-version-l1-1-0.dll', fileVersion: 6.2.9200.16492
Log: Id: 7836: C:\windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll:api-ms-win-downlevel-normaliz-l1-1-0.dll (000007FEFD330000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll', fileVersion: 6.2.9200.16492
Log: Id: 7836: C:\windows\system32\normaliz.DLL:normaliz.DLL (0000000077820000), size: 12288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\normaliz.DLL', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\iertutil.dll:iertutil.dll (000007FEFF6A0000), size: 2932736 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\iertutil.dll', fileVersion: 11.0.9600.19597
Log: Id: 7836: C:\windows\system32\WININET.dll:WININET.dll (000007FEFEE30000), size: 4898816 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WININET.dll', fileVersion: 11.0.9600.19597
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\bin\Qt5QuickWidgets.dll:Qt5QuickWidgets.dll (000007FEEAF00000), size: 90112 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\bin\Qt5QuickWidgets.dll', fileVersion: 5.15.2.0
Log: Id: 7836: C:\Program Files\FreeCAD 0.19\lib\Start.pyd:Start.pyd (000007FEEAD80000), size: 40960 (result: 0), SymType: '-exported-', PDB: 'C:\Program Files\FreeCAD 0.19\lib\Start.pyd'
Log: Id: 7836: C:\windows\system32\mf.dll:mf.dll (000007FEF5070000), size: 4132864 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\mf.dll', fileVersion: 12.0.7601.24499
Log: Id: 7836: C:\windows\system32\ATL.DLL:ATL.DLL (000007FEFAA50000), size: 102400 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ATL.DLL', fileVersion: 3.5.2284.0
Log: Id: 7836: C:\windows\system32\MFPlat.DLL:MFPlat.DLL (000007FEFA160000), size: 446464 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\MFPlat.DLL', fileVersion: 12.0.7601.24499
Log: Id: 7836: C:\windows\system32\AVRT.dll:AVRT.dll (000007FEFBD50000), size: 36864 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\AVRT.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\ksuser.dll:ksuser.dll (0000000074F30000), size: 24576 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ksuser.dll', fileVersion: 6.1.7601.19091
Log: Id: 7836: C:\windows\system32\msmpeg2vdec.dll:msmpeg2vdec.dll (000007FEF4D20000), size: 2789376 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\msmpeg2vdec.dll', fileVersion: 12.0.9200.17037
Log: Id: 7836: C:\windows\system32\EVR.dll:EVR.dll (000007FEF4FD0000), size: 651264 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\EVR.dll', fileVersion: 6.1.7601.24499
Log: Id: 7836: C:\windows\system32\POWRPROF.dll:POWRPROF.dll (000007FEFBC40000), size: 180224 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\POWRPROF.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\slc.dll:slc.dll (000007FEFA8C0000), size: 45056 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\slc.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\NLAapi.dll:NLAapi.dll (000007FEFAB30000), size: 86016 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\NLAapi.dll', fileVersion: 6.1.7601.24000
Log: Id: 7836: C:\windows\system32\dhcpcsvc6.DLL:dhcpcsvc6.DLL (000007FEFA360000), size: 69632 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\dhcpcsvc6.DLL', fileVersion: 6.1.7601.24498
Log: Id: 7836: C:\windows\system32\CLBCatQ.DLL:CLBCatQ.DLL (000007FEFF560000), size: 626688 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\CLBCatQ.DLL', fileVersion: 2001.12.8530.16385
Log: Id: 7836: C:\windows\system32\WINSTA.dll:WINSTA.dll (000007FEFC4E0000), size: 249856 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WINSTA.dll', fileVersion: 6.1.7601.18540
Log: Id: 7836: C:\windows\System32\MMDevApi.dll:MMDevApi.dll (000007FEFBBF0000), size: 307200 (result: 0), SymType: '-exported-', PDB: 'C:\windows\System32\MMDevApi.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\System32\PROPSYS.dll:PROPSYS.dll (000007FEFB8C0000), size: 1228800 (result: 0), SymType: '-exported-', PDB: 'C:\windows\System32\PROPSYS.dll', fileVersion: 7.0.7601.17514
Log: Id: 7836: C:\windows\system32\mfreadwrite.dll:mfreadwrite.dll (000007FEEABB0000), size: 270336 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\mfreadwrite.dll', fileVersion: 12.0.7601.17514
Log: Id: 7836: C:\windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24483_none_e372d88f30fbb845\comctl32.dll:comctl32.dll (000007FEFB9F0000), size: 2052096 (result: 0), SymType: '-exported-', PDB: 'C:\windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24483_none_e372d88f30fbb845\comctl32.dll', fileVersion: 6.10.7601.24483
Log: Id: 7836: C:\windows\system32\ntmarta.dll:ntmarta.dll (000007FEFACA0000), size: 184320 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ntmarta.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\WLDAP32.dll:WLDAP32.dll (000007FEFE880000), size: 335872 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WLDAP32.dll', fileVersion: 6.1.7601.23889
Log: Id: 7836: C:\windows\system32\WindowsCodecs.dll:WindowsCodecs.dll (000007FEFB0E0000), size: 1445888 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\WindowsCodecs.dll', fileVersion: 6.2.9200.22551
Log: Id: 7836: C:\windows\system32\apphelp.dll:apphelp.dll (000007FEFCFC0000), size: 356352 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\apphelp.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\EhStorShell.dll:EhStorShell.dll (000007FEF2B90000), size: 217088 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\EhStorShell.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\ntshrui.dll:ntshrui.dll (000007FEF2B00000), size: 524288 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\ntshrui.dll', fileVersion: 6.1.7601.17514
Log: Id: 7836: C:\windows\system32\cscapi.dll:cscapi.dll (000007FEF2BE0000), size: 61440 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\cscapi.dll', fileVersion: 6.1.7601.24197
Log: Id: 7836: C:\windows\system32\IconCodecService.dll:IconCodecService.dll (000007FEF2AF0000), size: 32768 (result: 0), SymType: '-nosymbols-', PDB: 'C:\windows\system32\IconCodecService.dll', fileVersion: 6.1.7600.16385
Log: Id: 7836: C:\windows\system32\credssp.dll:credssp.dll (000007FEFC530000), size: 40960 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\credssp.dll', fileVersion: 6.1.7601.24545
Log: Id: 7836: C:\windows\system32\mscms.dll:mscms.dll (000007FEF9D50000), size: 638976 (result: 0), SymType: '-exported-', PDB: 'C:\windows\system32\mscms.dll', fileVersion: 6.1.7601.24537
Log: Id: 7836: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 000000018006DF22)
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000000018006DF22)
Log: Id: 7836: 000000018006DF22 (ig4icd64): (filename not available): (function-name not available)
Log: Id: 7836: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 000000018006E397)
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000000018006E397)
Log: Id: 7836: 000000018006E397 (ig4icd64): (filename not available): (function-name not available)
Log: Id: 7836: ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00000001800F6BC5)
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00000001800F6BC5)
Log: Id: 7836: 00000001800F6BC5 (ig4icd64): (filename not available): (function-name not available)
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE0B9A8A8)
Log: Id: 7836: 000007FEE0B9A8A8 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE13D4A2F)
Log: Id: 7836: 000007FEE13D4A2F (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE13E8533)
Log: Id: 7836: 000007FEE13E8533 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE13F55B7)
Log: Id: 7836: 000007FEE13F55B7 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE29FC7C5)
Log: Id: 7836: 000007FEE29FC7C5 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE2053313)
Log: Id: 7836: 000007FEE2053313 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEDF4F3420)
Log: Id: 7836: 000007FEDF4F3420 (Qt5WebEngineCore): (filename not available): QWebEngineUrlRequestInfo::QWebEngineUrlRequestInfo
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE20557CF)
Log: Id: 7836: 000007FEE20557CF (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEDF4D0D43)
Log: Id: 7836: 000007FEDF4D0D43 (Qt5WebEngineCore): (filename not available): QWebEngineUrlRequestInfo::QWebEngineUrlRequestInfo
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE1054D38)
Log: Id: 7836: 000007FEE1054D38 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEDEEBDAC3)
Log: Id: 7836: 000007FEDEEBDAC3 (Qt5WebEngineCore): (filename not available): QtWebEngineCore::JavaScriptDialogController::qt_static_metacall
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE0729E75)
Log: Id: 7836: 000007FEE0729E75 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE07C1D0F)
Log: Id: 7836: 000007FEE07C1D0F (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE07C18A1)
Log: Id: 7836: 000007FEE07C18A1 (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE07A4C9D)
Log: Id: 7836: 000007FEE07A4C9D (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE07C219F)
Log: Id: 7836: 000007FEE07C219F (Qt5WebEngineCore): (filename not available): GetHandleVerifier
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE0754D75)
Log: Id: 7836: 000007FEE0754D75 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE0758385)
Log: Id: 7836: 000007FEE0758385 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000007FEE07206A5)
Log: Id: 7836: 000007FEE07206A5 (Qt5WebEngineCore): (filename not available): QWebEngineUrlSchemeHandler::qt_metacast
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 000000007757556D)
Log: Id: 7836: 000000007757556D (kernel32): (filename not available): BaseThreadInitThunk
Log: Id: 7836: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00000000776D372D)
Log: Id: 7836: 00000000776D372D (ntdll): (filename not available): RtlUserThreadStart
Log: ExpFlags: 0
Re: FreeCad 0.19.3 not running on WIN7, python 3.x version ?
I DuckDuckGoed ExpCode: 0xc0000005 and found:psiedlaczek wrote: ↑Fri Jan 07, 2022 1:32 pm
Log: ExpFlags: 0
https://www.stellarinfo.com/blog/how-to ... n-windows/
I am presuming you have verified that you have the 64 bit version of windows 7.
I have started FreeCad 0.20 and 0.19.3 on my Win 7 Home x64. But it was real pain to do.
Probably the success is due to combination of all actions below:
- updating nVidia driver
- enabling nVidia acceleration for FreeCad.exe for 0.193 and 0.20 versions instead of default settings which started on bult in IntelGraphics.
- chkdsk, memtest, virus scan ... sanity and caution, but no threads.
- repairing system32/ig4icd64.dll (by copying the larger file to each found location) this was related to ExpCode 0xC0000005 which was found in debug file. Thanks @TheMarkster
- Finally FC started after few experiments with running "FreeCad --dump-config" "FreeCad -u user.cfg" and "FreeCad -t 0",
Now it starting by double-click on icon.
0.20 still throws exceptions on python 3.8.8 when starting Part Design Workbnech:
failed to parse CPythons sys.version: '3.8.8 | packaged by conda-forge | default, Feb 20 2021, 15:50:08) [MSC v.1918 64 bit (AMD64)]'
It is excused, still in dev, but 0.19.3 runs smoothly.
