Can you share your UI file or a simplified version of it?karim.achaibou wrote: ↑Mon Nov 22, 2021 7:14 pm When I call the show function on my object without overwriting it, I get a blank dialogCode: Select all
panel = BoxTaskPanel(obj) panel.show()
[SOLVED] Open UI panel in standalone window
Re: SOLVED: Open UI panel in standalone window
UI as in created in QT designer?
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
<class>Dialog</class>
<widget class="QDialog" name="Dialog">
<property name="geometry">
<rect>
<x>0</x>
<y>0</y>
<width>426</width>
<height>336</height>
</rect>
</property>
<property name="windowTitle">
<string>Dialog</string>
</property>
<layout class="QGridLayout" name="gridLayout">
<item row="2" column="0">
<widget class="QLabel" name="label">
<property name="text">
<string>Lengte</string>
</property>
</widget>
</item>
<item row="2" column="1">
<widget class="QDoubleSpinBox" name="TubeLength">
<property name="suffix">
<string>mm</string>
</property>
<property name="decimals">
<number>1</number>
</property>
<property name="maximum">
<double>1000.000000000000000</double>
</property>
</widget>
</item>
<item row="5" column="0">
<widget class="QLabel" name="label_2">
<string>Binnen diameter</string>
</property>
</widget>
</item>
<item row="8" column="0">
<widget class="QLabel" name="label_3">
<string>Wanddikte</string>
</property>
</widget>
</item>
<item row="8" column="1">
<widget class="QDoubleSpinBox" name="TubeThickness">
<string>mm</string>
</property>
<number>1</number>
</property>
<double>10.000000000000000</double>
</property>
</widget>
</item>
<item row="5" column="1">
<widget class="QDoubleSpinBox" name="TubeInnerDia">
<string>mm</string>
</property>
<number>1</number>
</property>
</property>
</widget>
</item>
<item row="1" column="0" colspan="2">
<widget class="QListWidget" name="typeWidget"/>
</item>
<item row="0" column="0" colspan="2">
<widget class="QLabel" name="lbl_PType">
<property name="cursor">
<cursorShape>ArrowCursor</cursorShape>
</property>
<string>Type</string>
</property>
<property name="alignment">
<set>Qt::AlignCenter</set>
</property>
</widget>
</item>
<item row="0" column="3">
<widget class="QLineEdit" name="lineEdit_filter_sizeList">
<property name="inputMask">
<string/>
</property>
<string/>
</property>
<property name="placeholderText">
<string>type to filter</string>
</property>
</widget>
</item>
<item row="1" column="3" rowspan="8">
<widget class="QListWidget" name="sizeList">
<property name="acceptDrops">
<bool>false</bool>
</property>
</widget>
</item>
</layout>
</widget>
<tabstops>
<tabstop>typeWidget</tabstop>
<tabstop>sizeList</tabstop>
<tabstop>lineEdit_filter_sizeList</tabstop>
<tabstop>TubeLength</tabstop>
<tabstop>TubeInnerDia</tabstop>
<tabstop>TubeThickness</tabstop>
</tabstops>
<resources/>
<connections/>
</ui>
Yep. OK, this is what I thought. Actually your UI is already a QDialog.
In this case, you should do something like :
class BoxTaskPanel:
def __init__(self, obj, parent=Gui.getMainWindow()):
self.form = Gui.PySideUic.loadUi(path_to_ui)
self.form.setWindowTitle("Choose Tube")
self.form.setWindowFlag(QtCore.Qt.Tool)
self.form.setParent(parent)
self.fp = obj
def show(self):
self.form.show()
Or maybe create Ui by hand, for simple UI (but also for complex and repetitive UI) sometimes is better and more concise than using Qt designer.
