When I load my QT UI file created in QT designer into FreeCAD it opens in the Tasks panel of the Combo View with the code below.
self.form = Gui.PySideUic.loadUi(path_to_ui)
def create(obj_name):
obj = App.ActiveDocument.addObject("Part::FeaturePython", obj_name)
box(obj)
print(str(obj.Lengte) + "-" + str(obj.Binnendiameter) + "-" + str(obj.Diktebuis))
panel = BoxTaskPanel(obj)
Gui.Control.showDialog(panel)
ViewProviderBox(obj.ViewObject)
return obj
class BoxTaskPanel():
def __init__(self, obj):
self.fp = obj
""" set the values of the taskpanel with the current object values"""
self.form.TubeLength.setValue(obj.Lengte)
self.form.TubeThickness.setValue(obj.Diktebuis)
self.form.TubeInnerDia.setValue(obj.Binnendiameter)
def accept(self):
d = self.pipeDictList[self.form.sizeList.currentRow()]
self.fp.Lengte = self.form.TubeLength.value()
self.fp.Diktebuis = self.form.TubeThickness.value()
self.fp.Binnendiameter = self.form.TubeInnerDia.value()
if (self.fp.Lengte == 0) or (self.fp.Diktebuis == 0) or (self.fp.Binnendiameter == 0):
print("error, values have to be > 0")
return
Gui.Control.closeDialog()
return self.fp
openBrain wrote: ↑Sat Nov 20, 2021 10:32 am This line specifically shows in the Task panel.When I disable code above, it solves my problem but now my connections don't work anymore which are in my init def from my panel.Code: Select all
# signal/connection self.form.typeWidget.itemClicked.connect(self.changeRating) self.form.lineEdit_filter_sizeList.textEdited.connect(self.updateSizelist) self.form.sizeList.itemClicked.connect(self.updateSpinbox)
your suggestion above is probably the correct way to do it, but looking at your example doesn't give ME a lot of clues ...If you want a dedicated panel, you have to open your UI in a QDialog or QDockWidget whose parent is Gui.getMainWindow()
relevant code in link:openBrain wrote: ↑Sat Nov 20, 2021 10:34 am You can find example of non modal QDialog here : https://github.com/0penBrain/FreeCAD-ma ... og.FCMacro
def __init__(self, parent=Gui.getMainWindow()): # Important for widgets to handle kinship to get consistent behavior
super().__init__(parent, QtCore.Qt.Tool) # Using the Tool flag will keep widget on top of parent while not locking operation
self.setAttribute(QtCore.Qt.WA_DeleteOnClose, True) # So widget object is deleted when closed, not just hidden (memory friendly)
self.setAttribute(QtCore.Qt.WA_WindowPropagation, True) # So font is propagated from parent to self (needed for windowed widgets)
self.setObjectName("MyDialog") # Always a good idea to set an object name if one need to find the widget programatically
class BoxTaskPanel(QtWidgets.QDialog):
def __init__(self, obj, parent=Gui.getMainWindow()):
super().__init__(parent)
self.form.setWindowTitle("Choose Tube")
self.form.setModal(False)
self.form.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
self.fp = obj
def show(self):
self.form.show()
panel.show()
Actually nothing so bad, just you should use 'QtCore.Qt.Tool' flag rather than 'StaysOnTopHint'.
self.form.setParent(self)
self.fp = obj
Works like a charm thanks.Actually nothing so bad, just you should use 'QtCore.Qt.Tool' flag rather than 'StaysOnTopHint'.
When I call the show function on my object without overwriting it, I get a blank dialogAlso yu don't need to redefine the 'show' method.
panel.show()
