[solved] Goal seek macro
Re: [Help] Goal seek macro
@openbrain If you want to tweak this further, once you have found brackets for the root, you can use Brent's method to find it. https://en.wikipedia.org/wiki/Brent%27s_method It combines the certainty of finding the root you get with bisection with the faster convergence of the secant method. The weakness of the faster converging secant method (which is a essentially Newton's method using a numerical derivative) is that the iterates can wander outside the bracket - Brent fixes this. It's a favorite.
However, in a simple problem like how does volume change with some dimension (where the function is monotonic and there is guaranteed to be only one root), just about any method will work - but some require more iterations than others.
Not that I'm not interested in, but my spare time is limited and scipy is capable. Will put effort in something else.edwilliams16 wrote: ↑Sun Jan 24, 2021 9:28 pm @openbrain If you want to tweak this further, once you have found brackets for the root, you can use Brent's method to find it.
Chiming in because this is something I've tried (and failed) a couple of weeks ago
I had tried to make a similar optimization macro, my goal was to tweak multiple parameters so that some 2D shapes fill a rectangle without overlapping, optimizing e.g. for the scale of the shapes.
I used an App::FeaturePython object, which describes some tweakable parameters with their ranges, the first parameter is the goal (to minimize or maximize), and the Mapping field tells it how to assign tweakable parameters to the position, rotation, scale of the objects. This allows to bind the same scale to two objects. In retrospect, I should have used simple properties, and used expressions in the objects-to-be-moved to copy these properties.
My approach was to use a genetic algorithm. This was probably not the best idea, as combining the rotation of one solution with the position of another is unlikely to give a valid result, when the rectangle is getting cramped.
Another problem is that I didn't implement a good fitness function for the tweakable parameters, so the algorithm is just groping in the dark really.
So the code below requires a valid starting position otherwise it takes forever to find one, and even with that it converges at a horrendously slow speed. Please file this in the "failed experiments" folder
I'll probably revive this in the future and use some insights from this thread (use Scipy, make sure the fitness function has a smooth gradient close to the optimum), and give the algorithm a hand:
* instead of fitting in a fixed rectangle, it makes sense rotate the group of shapes as a whole a few times until its bounding box is the smallest, and use that as a metric
* instead of maximizing the scale (which adds an extra parameter) I should minimize the delta between the best bounding box's aspect ratio and the target aspect ratio; it's easy to scale to get the desired size once the aspect ratio is optimal
* minimize the number of parameters: since the bounding box should be measured, the absolute position doesn't matter, only the relative positions of the objects, so one object can be fixed in (0,0), the same applies to the rotation.
* rotate objects around their centre of mass instead of rotating around an arbitrary object origin
* try to find a way to "fix" an invalid solution instead of discarding it (e.g. if the shapes intersect, shift one until they don't anymore)
Surely these problem-specific tricks can be generalized to have decent guidelines for an optimization problem, I'll have to think about this.
# TODO:
# fitness: distance to other shapes
# compute rotated bounding box witù minimum area and rotate the page to fit (+portrait or landscape)
from functools import cmp_to_key
import random
def applyConfiguration(configuration, mapping, objects):
for i,o in enumerate(objects):
x,y,angle,scale = mapping[i]
o.Placement.Base.x = configuration[x][1]
o.Placement.Base.y = configuration[y][1]
o.Placement.Rotation.Angle = configuration[angle][1]
o.Scale = configuration[scale][1]
def isValid(page, configuration, mapping, objects):
for object in objects:
if object.Shape.cut(page.Shape).Area > 0:
return False
for other in objects:
if object != other and object.Shape.common(other.Shape).Area > 0:
return False
return True
def compare(configuration1, configuration2, tolerance):
if configuration2 is None:
return True
if configuration1 is None:
return False
"""True if configuration1 is better than configuration2. This is not a proper rder because of the tolerance"""
for ((name, vx, min, max, goal),(_, vy, _, _, _)) in zip(configuration1,configuration2):
if goal == 'max':
v1, v2 = vx, vy
elif goal == 'min':
v1, v2 = vy,vx
elif goal == '':
break # uncomparable
else:
raise ValueError("Optimize2D: Invalid goal:" + str(goal) + " in configuration " + str(configuration1) + ". Expected 'min' or 'max'.")
if v1 > v2 + tolerance:
return 1
elif v1 < v2 - tolerance:
return -1
else:
continue
return 0
def evolve(configuration, best, population, generation, tolerance):
configuration = list(configuration) # copy to prevent mutation
r = random.random()
if r < 0.05:
# completely random starting point
for i in range(len(configuration)):
name, v, min, max, goal = configuration[i]
v = random.uniform(min, max)
configuration[i] = (name, v, min, max, goal)
elif r < 0.3:
# completely randomize a gene trying to improve the best case
for attempt in range(50):
i = random.randrange(len(configuration))
if compare(configuration, best, tolerance)> 0:
break
elif r < 0.5:
# slightly randomize all genes
delta = (max-min)*(1.0/(generation+1))
v = v + random.uniform(-delta,delta)
if v < min: v = min
if v > max: v = max
elif r < 0.7:
# mix with other from population
other = random.randrange(len(population))
name, v1, min, max, goal = configuration[i]
_, v2, _, _, _= population[other][i]
if random.random() < 0.5:
v = v1
else:
v = v2
else:
# slightly randomize a gene
if v < min: v = min
if v > max: v = max
return configuration
def auto(page, initialConfiguration, min, max, mapping, objects, tolerance, maxPopulation, promote, generations):
#random.uniform(min, max)
population = [initialConfiguration]
prevbest = initialConfiguration
for generation in range(generations):
prevbest = best
best = population[0]
print("score=" + str(best[0][1])+', pop=' + str(len(population)), ', better?' + str(compare(best, prevbest, tolerance)) + "prev=" + str(prevbest[0][1]))
offsprings = [evolve(configuration, best, population, generation, tolerance) for configuration in population]
offsprings = [configuration for configuration in offsprings if isValid(page, configuration, mapping, objects)]
random.shuffle(population)
population = population + offsprings + [initialConfiguration]
population = sorted(population, reverse = True, key = cmp_to_key(lambda x,y: compare(x,y,tolerance)))
population = population[:promote] + random.choices(population = population, k = maxPopulation-promote)
return population[0]
def line(name, v, min, max, goal = ''):
return (name, float(v), float(min), float(max), goal)
def main(o):
configuration = [line(*l.strip().split()) for l in o.Configuration if l.strip()]
mapping = [tuple(l.strip().split()) for l in o.Mapping if l.strip()]
page = o.Page
objects = o.Objects
tolerance = o.Tolerance
maxPopulation = o.MaxPopulation
promote = o.Promote
generations = o.Generations
configuration_indices = dict((name, i) for i, (name,_,_,_,_) in enumerate(configuration))
mapping = [tuple(configuration_indices[ref] for ref in m) for m in mapping]
best = auto(page, configuration, min, max, mapping, objects, tolerance, maxPopulation, promote, generations)
if best:
applyConfiguration(best, mapping, objects)
o.Configuration = [' '.join([str(x) for x in c]) for c in best]
else:
raise ValueError("Couldn't find a suitable configuration (not a ValueError)")
def mk():
o = App.ActiveDocument.addObject('App::FeaturePython', 'Optimize2D')
o.addProperty("App::PropertyStringList", "Configuration")
o.Configuration = """scale 0.1 0.1 5 max
rot1 0 0 0
x1 120 0 300
y1 60 0 400
rot2 0 0 90
x2 90 0 300
y2 190 0 400""".split('\n')
o.addProperty("App::PropertyStringList", "Mapping")
o.Mapping = """x1 y1 rot1 scale
x2 y2 rot2 scale""".split('\n')
o.addProperty("App::PropertyLinkList", "Objects")
o.Objects = [App.ActiveDocument.Link, App.ActiveDocument.Link001]
o.addProperty("App::PropertyFloat", "Tolerance")
o.Tolerance = 0.00001
o.addProperty("App::PropertyLink", "Page")
o.Page = App.ActiveDocument.Binder
o.addProperty("App::PropertyInteger", "MaxPopulation", "Genetic algorithm")
o.MaxPopulation = 30
o.addProperty("App::PropertyInteger", "Promote", "Genetic algorithm")
o.Promote = 10
o.addProperty("App::PropertyInteger", "Generations", "Genetic algorithm")
o.Generations = 20
if not hasattr(App.ActiveDocument, 'Optimize2D'):
mk()
main(App.ActiveDocument.Optimize2D)
Version: 0.19.23756 (Git) AppImage
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
- screenshot-2D-pack.png (135.3 KiB) Viewed 2006 times
- autoscale_macro.FCStd
- (292.81 KiB) Downloaded 55 times
Could somebody advice why is this happening? I tried to start the macro with recent build and get this:
Is this caused by some upgrade of SciPy or Shiboken?
This result is from this FreeCAD version (latest local build):
Version: 0.20.25026 (Git)
Hash: 85f37a1dbcb757efad32b7598ac0f99af021af8f
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Bulgarian/Bulgaria (bg_BG)
the macro from my last post and the attached file as an example.
22:11:23 Traceback (most recent call last):
File "C:/Users/Wivern/AppData/Roaming/FreeCAD/Macro/_GoalSeek.FCMacro", line 18, in <module>
from scipy.optimize import minimize
File "E:\FC_DevVMBuild\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
File "E:\FC_DevVMBuild\bin\lib\site-packages\scipy\optimize\__init__.py", line 387, in <module>
from .optimize import *
File "E:\FC_DevVMBuild\bin\lib\site-packages\scipy\optimize\optimize.py", line 36, in <module>
from ._numdiff import approx_derivative
File "E:\FC_DevVMBuild\bin\lib\site-packages\scipy\optimize\_numdiff.py", line 6, in <module>
from scipy.sparse.linalg import LinearOperator
File "E:\FC_DevVMBuild\bin\lib\site-packages\scipy\sparse\__init__.py", line 227, in <module>
from .base import *
File "E:\FC_DevVMBuild\bin\lib\site-packages\scipy\sparse\base.py", line 4, in <module>
from .sputils import (isdense, isscalarlike, isintlike,
File "E:\FC_DevVMBuild\bin\lib\site-packages\scipy\sparse\sputils.py", line 8, in <module>
from scipy._lib._util import prod
File "E:\F<class 'SyntaxError'>: invalid syntax (process.py, line 262)
22:11:44 Save AutoRecovery file: Needed time: 0ms
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- GoalSeekTest002.FCStd
- (581.28 KiB) Downloaded 51 times
It works fine here :
Maybe your FC package doesn't include scipy anymore ?
Do you get an error when typing this in the python console ? :
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.25001 (Git)
Hash: ff26df0a6d21c6c6a397e5f11d7857d3f63841cc
Python version: 3.9.5
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
from .base import *
File "E:\FC_DevVMBuild\bin\lib\site-packages\scipy\_lib\_util.py", line 7, in <module>
from multiprocessing import Pool
File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\retr3d\multiprocessing\__init__.py", line 64, in <module>
from multiprocessing.process import Process, current_process, active_children
File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\retr3d\multiprocessing\process.py", line 262
except SystemExit, e:
SyntaxError: invalid syntax
Good catch. I removed retr3d WB, restarted FreeCAD and now the import works ok and the macro also works.edwilliams16 wrote: ↑Mon Jun 07, 2021 10:20 pm Says there is a syntax error in your retr3d workbench.
But why should (unmantained? and probably broken) another workbench mess with the work of an unrelated macro? Is it possible that there is some deeper problem that just gets exposed with the combination of mods i have here?
retr3d contains its own copy of the multiprocessing module, but this copy is for Python 2 and uses syntax that's not valid in Python 3. This explains the what part of the error.
As to why this happens, in Retr3d/utilityFunctions.py there's this weird piece of code:
import sys
sys.path.append(os.path.dirname(os.path.abspath(__file__)))
import logging
This adds the directory containing retr3d to the module loading path which I'm guessing, when combined with customized module loading used in FreeCAD, allows the copy to be found and imported over the one from the python distribution.
As to should this happen, I'm unsure. The Python documentation for sys.path offers little guidance, simply saying: "A program is free to modify this list for its own purposes." So this could be a bug, but it being a feature wouldn't surprise me either.
probably with a method of same name it utilize the "last" found in sys.path.
As in pythin you could "rewrite" methods this is a "feature", once you know the mechanics.
Sometimes it will became a "problem", probably some "warning" that coulb be activated in python interpreter about "redefining functions" will be s good way.
or simply the import statement is importing using
that is considered "bad practice" most of the times.
from something import *
