def boolean_cut(base_body, sub_body1, sub_body2):
partdesign_body_basename = base_body.split('__')[0]
Gui.Selection.clearSelection()
Gui.Selection.addSelection(App.ActiveDocument.Label,base_body)
Gui.ActiveDocument.ActiveView.setActiveObject('pdbody',App.ActiveDocument.getObject(base_body))
Gui.Selection.addSelection(App.ActiveDocument.Label,sub_body1)
Gui.Selection.addSelection(App.ActiveDocument.Label,sub_body2)
App.ActiveDocument.getObject(base_body).newObject('PartDesign::Boolean','Boolean')
App.ActiveDocument.getObject('Boolean').addObjects([App.ActiveDocument.getObject(sub_body1),App.ActiveDocument.getObject(sub_body2),])
App.ActiveDocument.getObject('Boolean').ViewObject.ShapeColor=getattr(App.ActiveDocument.getObject(partdesign_body_basename + '__Pocket').getLinkedObject(True).ViewObject,'ShapeColor',App.ActiveDocument.getObject('Boolean').ViewObject.ShapeColor)
App.ActiveDocument.getObject('Boolean').ViewObject.LineColor=getattr(App.ActiveDocument.getObject(partdesign_body_basename + '__Pocket').getLinkedObject(True).ViewObject,'LineColor',App.ActiveDocument.getObject('Boolean').ViewObject.LineColor)
App.ActiveDocument.getObject('Boolean').ViewObject.PointColor=getattr(App.ActiveDocument.getObject(partdesign_body_basename + '__Pocket').getLinkedObject(True).ViewObject,'PointColor',App.ActiveDocument.getObject('Boolean').ViewObject.PointColor)
App.ActiveDocument.getObject('Boolean').ViewObject.Transparency=getattr(App.ActiveDocument.getObject(partdesign_body_basename + '__Pocket').getLinkedObject(True).ViewObject,'Transparency',App.ActiveDocument.getObject('Boolean').ViewObject.Transparency)
App.ActiveDocument.getObject('Boolean').ViewObject.DisplayMode=getattr(App.ActiveDocument.getObject(partdesign_body_basename + '__Pocket').getLinkedObject(True).ViewObject,'DisplayMode',App.ActiveDocument.getObject('Boolean').ViewObject.DisplayMode)
Gui.ActiveDocument.setEdit(App.ActiveDocument.getObject(base_body),0,'Boolean.')
App.ActiveDocument.getObject('Boolean').setObjects( [App.ActiveDocument.getObject(sub_body1),App.ActiveDocument.getObject(sub_body2),])
App.ActiveDocument.getObject('Boolean').Type = 1
Gui.activeDocument().resetEdit()
base_body
sub_body1
sub_body2
I want to cut sub_body1 and sub_body2 out of base_body.
So the above code works, but only once. I need to be able to run it multiple times, so all the object references will need to be abstracted to variables, eg the Boolean object that it creates), and also this part:
... App.ActiveDocument.getObject('Boolean').ViewObject.ShapeColor=getattr(App.ActiveDocument.getObject(partdesign_body_basename + '__Pocket').getLinkedObject(True).ViewObject,'ShapeColor',App.ActiveDocument.getObject('Boolean').ViewObject.ShapeColor)
I tried replacing "partdesign_body_basename + '__Pocket'" with "App.ActiveDocument.getObject(base_body).Tip.Name" but that doesn't seem to work - it returns "a type of <class 'NoneType'>", although it had worked in the console when I was trying to figure out what to use.
My question is, is there a more concise way of doing this?
OS: openSUSE Leap 15.2 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.22670 (Git) AppImage
Hash: 12155f4aab09047c5697db0c1b3cf93b02edda03
Python version: 3.8.6
Qt version: 5.12.9
