[Solved] Python object with OriginGroupExtension
carlopav
Re: Python object with OriginGroupExtension
Post by carlopav »
I just love this fantastic piece of software and this community!
wall experiment.gif (345.5 KiB) Viewed 846 times
Here is a very raw (i'm a real noob) implementation of what i wanted.
The wall can move every children accordingly, and they are always represented "in place".
Long road before this could become usable, but... why not working on it?
class MyWall(object):
    def __init__(self, obj=None):
        #self.Type = 'wall'
        if obj:
            obj.Proxy = self
            self.Object = obj
            self.attach(obj)
    def __getstate__(self):
        return
    def __setstate__(self,_state):
        return
    def execute(self,obj):
        print("running Execute")
        "builds the wall shape"
        import Part
        if hasattr(obj,"Length") and hasattr(obj,"Width") and hasattr(obj,"Height"):
            wall_shape = Part.makeBox(obj.Length,obj.Width, obj.Height)
            obj.Shape = wall_shape
            children_shapes= []
            for child in obj.Group:
                if hasattr(child, "Shape"):
                    children_shapes.append(child.Shape)
            children_shapes.append(wall_shape)
            obj.Shape = Part.Compound(children_shapes)
    def attach(self,obj):
        print("running obj attach method")
        obj.addExtension('App::OriginGroupExtensionPython', None)
        obj.Origin = FreeCAD.ActiveDocument.addObject('App::Origin','Origin')
    def onDocumentRestored(self, obj):
        self.Object = obj
class ViewProviderMyWall(object):
    def __init__(self,vobj=None):
        if vobj:
            vobj.Proxy = self
            self.attach(vobj)
        else:
            self.ViewObject = None
    def updateData(self, obj, prop):
        return
    def attach(self,vobj):
        print("running vobj attach method")
        vobj.addExtension('Gui::ViewProviderOriginGroupExtensionPython', None)
        self.ViewObject = vobj
        return None
    def __setstate__(self, _state):
        return None
    def getDefaultDisplayMode(self):
        Return the name of the default display mode. It must be defined in getDisplayModes.
        return "Flat Lines"
obj = App.ActiveDocument.addObject('Part::FeaturePython', 'Wall', MyWall(), ViewProviderMyWall(), True)
obj.addProperty('App::PropertyString', 'Description', 'Base', 'Box description').Description = ""
obj.addProperty('App::PropertyLength', 'Length', 'Dimensions', 'Box length').Length = 10.0
obj.addProperty('App::PropertyLength', 'Width', 'Dimensions', 'Box width').Width = '2 mm'
obj.addProperty('App::PropertyLength', 'Height', 'Dimensions', 'Box height').Height = '1 cm'
obj.addProperty('App::PropertyAngle', 'FirstAngle', 'Dimensions', 'Box height').FirstAngle = '90 deg'
obj.addProperty('App::PropertyAngle', 'LastAngle', 'Dimensions', 'Box height').LastAngle = '90 deg'
paullee
Post by paullee »
Looks good ! :)
Wound the base object of Window / Wall move together ?
Thanks.
carlopav
Post by carlopav »
realthunder wrote: Sun Apr 05, 2020 8:34 am Note that you want to write your own Python class only if you decide to write your own workbench, because others will have to install your workbench before they can open document containing your object. You can probably achieve what you want using existing objects.
I'm very happy with the solution you provided, but what did you mean when you wrote I can achieve the result with existing objects? Did you have something particular in mind?
No hurry to respond :)
realthunder
Post by realthunder »
carlopav wrote: Mon Apr 06, 2020 10:19 am I'm very happy with the solution you provided, but what did you mean when you wrote I can achieve the result with existing objects? Did you have something particular in mind?
Not anything in particular. It really depends on your intention. If it is just a one time thing, or the custom logic is simple, then maybe writing a macro is enough. You can use script to install (ViewProvider)OriginGroupExtension to an existing object. But if you intend this to be a reusable parametric object with some not so simple logic, then writing your own class is the right way.
vocx
Post by vocx »
realthunder wrote: Mon Apr 06, 2020 9:48 pm ...But if you intend this to be a reusable parametric object with some not so simple logic, then writing your own class is the right way.
Carlo's idea is not a one time use. This could be the future Arch Wall object in the Arch Workbench. There are several objects in this workbench which act like groups (Arch BuildingPart, for example), so moving all objects inside of it makes sense. The issue is understanding the best way of doing it. If we introduce this new object in Arch, we also need to verify that it works correctly with other commands in the workbench in a way that is intuitive for the user.
carlopav
Post by carlopav »
realthunder wrote: Mon Apr 06, 2020 9:48 pm But if you intend this to be a reusable parametric object with some not so simple logic, then writing your own class is the right way.
Yes, @vocx is right! My final goal is that :twisted:: rewriting several Arch tools to behave in an "assembly way". In the end FreeCAD is a lot focused on mechanical modelling (Parts and way to Assemble them), and architectural modelling can also be considered a way of assembly component, just the components are often simpler and they don't need a solver (at least not at the beginning). This could also make the Arch module more FreeCADish i think.
But I'm far from thinking that I'm somehow near it. I will still have to bother you all a lot I think :)
Yes I know, this will be a difficult thing, but I already started to bring an initial support for App::Part to the most basic tools.
EDIT: Reference to the topic disscussing further implementation of the new wall object
carlopav
Post by carlopav »
realthunder wrote: Mon Apr 06, 2020 9:48 pm ping
Here I am asking again for help.
I went quite far with the prototype of Bim Assembly concept, and it works nicely, but trying to reduce the objects in the document (BIM models can be really huge), I need to have just one object for a wall.
At the moment it's like this:
Wall container
-> Origin
-> WallSegment object
-> Window
-> Wall additions
-> Wall subtractions
And I want to get rid of the WallSegment object.
Is there a way for the Wall container object to have at the same time the Display Mode set to Group and to for example Flat Lines?
So it can show its own shape and also the children objects at the same time?
Hope I was clear enough :)
thanks for any hint you could give :)
realthunder
carlopav wrote: Thu Apr 30, 2020 7:46 pm Is there a way for the Wall container object to have at the same time the Display Mode set to Group and to for example Flat Lines?
This is a bit more complicated, specifically, to get the selection work. The attached script builds on my last MyGroup demo. It adds a new display mode 'ShapeGroup' which groups the 'Group' mode and the 'Flat Lines' mode. The trick to get selection right is done in two important functions 'getElementPicked()' and 'getDetailPath()'.
group.py
(3.43 KiB) Downloaded 50 times
carlopav
Post by carlopav »
realthunder wrote: Fri May 01, 2020 4:11 am The attached script builds on my last MyGroup demo.
My god, this is just coooool! that's exactly what we need :D
thanks so much :)
I'll try to adapt it to our wall prototype NOW!
carlopav
Post by carlopav »
Sorry, but I can't help asking another question.
Is it possible to override existing DisplayModes with the new "ShapeGroup"?
The goal is to have the ShapeGroup behaviour with FlatLines, Wireframe or Shaded, where Grouped objects are shown, and the main object gets the visual style of the selected DisplayMode. (So when an user use Std_DrawStyle the objects are correctly formatted)
