Face.Surface : memory leak ?
cristian.a73
Post by cristian.a73 »
Hi FreeCAD Forumer
In my model, about 6000 faces from step my code is something like this :
for f in Shape.faces:
 sf = f.Surface
 del sf
The FreeCADCmd run until all 4gb of free Ram was used (aprox 20kb per second), than crash with message about no memory available
How could access to Face.Surface class without cause a memory leak ?
Thank you
Cristian
OS: Windows 7
Word size of FreeCAD: 32-bit
Version: 0.18.15527 (Git)
Hash: 70aaf3e95fe2a3f17d43e95a1afe7d903d91b8ae
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
Locale: Italian/Italy (it_IT)
wandererfan
Re: Face.Surface : memory leak ?
Post by wandererfan »
cristian.a73 wrote: Thu Jan 10, 2019 8:52 pm
 sf = f.Surface
 del sf
Maybe you need to force garbage collection? del isn't guaranteed to free up memory immediately.
import gc
gc.collect()
cristian.a73
wandererfan wrote: Fri Jan 11, 2019 3:44 am Maybe you need to force garbage collection? del isn't guaranteed to free up memory immediately.
import gc
gc.collect()
Unfortunally gc has no effect :cry:
DeepSOIC
Post by DeepSOIC »
I think I can confirm.
0. install Lattice2
1. create polar array
2. set Count property to 10000
-> memory usage is 190 MB
3. paste this to console, multiple times:
sh = App.ActiveDocument.ActiveObject.Shape
for f in sh.Faces:
 sf = f.Surface
 del sf
after 10 runs, memory usage is 500 MB
same will probably work with a Draft Array of boxes, but it consumes 1G of memory just by itself, so it's harder to notice.
OS: Windows 10
Version: 0.18.15518 (Git)
Hash: e83c44200ab428b753a1e08a2e4d95e03236e481
Python version: 3.6.6
Qt version: 5.6.2
DeepSOIC
Post by DeepSOIC »
DeepSOIC
Post by DeepSOIC »
This might be an OCC leak... If I just use Surface attribute many many times, memory use doesn't grow.
import Part
cub = Part.makeBox(10,10,10)
f = cub.Faces[0]
for i in range(10000000):
    sf = f.Surface
DeepSOIC
Post by DeepSOIC »
And this leaks:
import Part
f = cub.Faces[0]
    sf = cub.Faces[0].Surface
It's a problem of the Python wrappers that create some cyclic dependencies. This causes the ref counter never to become zero and thus the memory is not freed.
cristian.a73
:idea: ... a possible workaround :
sfArr = []
for f in sh.Faces:
 sfArr.append(f.Surface)
for i in range(0,1000000):
 for sf in sfArr:
  print "sf:"+str(sf)
