Creating a new workbench for photovoltaic
JavierBrana
Re: Creating a new workbench for photovoltaic
Post by JavierBrana »
HakanSeven12 wrote: Sun Aug 01, 2021 7:20 am Still you didn't send me a test file :)
https://mega.nz/file/KvpGSarI#H0mAi_DxJ ... FpnJJVirvc
HakanSeven12 wrote: Sun Aug 01, 2021 7:20 am if you want to save them to object you need to add a string property to object. Then you can create a dictionary to save your settings and convert it to string and add it to your new property. When you want to set this color again use 'eval' to convert it to dictionary.
Good idea. I will think about that.
HakanSeven12
Post by HakanSeven12 »
I made some improvement for pads. Take a look: http://forum.freecadweb.org/viewtopic.p ... &start=570
ebrahim raeyat
Post by ebrahim raeyat »
HakanSeven12 wrote: Sun Aug 01, 2021 7:20 am Still you didn't send me a test file :) if you want to save them to object you need to add a string property to object. Then you can create a dictionary to save your settings and convert it to string and add it to your new property. When you want to set this color again use 'eval' to convert it to dictionary.
for storing a dictionary in an object, you can use "App::PropertyMap" properties.
HakanSeven12
I didn't know that. Thank for trick :) I will try.
HakanSeven12
My dictionary has dictionaries in it. So that property dont works for me :)
JavierBrana
Nice work NakanSeven12!! I am checking your code when I have a moment.
For my side, I stopped this part and I am focus on the electrical and mechanical parts. For now, them are a little more urgent than civil. But soon I will come back to this part too.
My progress:
  • better construction of trackers
  • faster positioning of frames
  • positioning of frames aligned or following the shape of the boundaries of the land
  • Striming configuration and drawing
  • working on cable and wiring
  • reports of the mechanical part and export them to xmlx
HakanSeven12
JavierBrana
Any alternative option to "makeParallelProjection"?. It is very expensive talking about time. It takes arround 3 second one operation and in some commands "makeParallelProjection" is called more than 1.000 times so you can guess it takes a long of time. I tried with extrude and (cut or common) but it is the same time more or less.
HakanSeven12
Why are you using this? What is the process?
JavierBrana
There are serveral processes:
In this function y adjust a frame to the terrain. The solution I found was get the extreme points and project a line to the terrain. Thanks to this porjection I get a line from the first point to the last point. At the same time I get the base and angle:
    def adjustToTerrain(self, cols, width):
        dist = 2000
        terrain = PVPlantSite.get().Terrain.Shape
        placements = []
        for col in cols:
            groups = []
            groups.append([col[0]])
            for i in range(1, len(col) - 1):
                group = groups[-1]
                l = (col[i].sub(group[-1])).Length
                l -= width
                if l <= dist:
                    group.append(col[i])
                else:
                    groups.append([col[i]])
            for group in groups:
                points = []
                vec1 = FreeCAD.Vector(self.Dir)
                vec1.Length = width / 2
                if len(group) == 1:
                    points.append(group[0].sub(vec1))
                    points.append(group[0].add(vec1))
                elif len(group) > 1:
                    for ind in range(0, len(group) - 1):
                        points.append((group[ind].add(vec1) + group[ind + 1].sub(vec1)) / 2)
                    points.append(group[-1].add(vec1))
                points3D = []
                for ind in range(len(points) - 1):
                    line = Part.LineSegment(points[ind], points[ind + 1])
                    [b]tmp = terrain.makeParallelProjection(line.toShape(), FreeCAD.Vector(0, 0, 1))[/b]
                    if len(tmp.Vertexes) > 0:
                        if ind == 0:
                            points3D.append(tmp.Vertexes[0].Point)
                        points3D.append(tmp.Vertexes[-1].Point)
                Draft.makeWire(points3D)
                for ind in range(0, len(points3D) - 1):
                    pl = FreeCAD.Placement()
                    vec = points3D[ind] - points3D[ind + 1]
                    pl.Base = FreeCAD.Vector(group[ind])
                    p = (points3D[ind] + points3D[ind + 1]) / 2
                    pl.Base.z = p.z
                    pl.Rotation = FreeCAD.Rotation(FreeCAD.Vector(-1, 0, 0), vec)
                    placements.append(pl)
        return placements
Other is this, where I calcule the eartwork. Once the frame is adjust to the terrain, I project the axis and I compare this profile with the axis:
def calculateEarthWorks(trackerPath, Terrain, offsetup=200, offsetdown=200):
    Cuts = None
    Fills = None
    newPath = None
    limitTop = makeOffset(trackerPath, offsetup)
    limitBottom = makeOffset(trackerPath, -offsetdown)
    points3D = []
    [b]tmp_pts = Terrain.Shape.makeParallelProjection(trackerPath.Shape.Wires[0], FreeCAD.Vector(0, 0, 1))[/b]
    points3D = [ver.Point for ver in tmp_pts.Vertexes]
    points3D = sorted(points3D, key=lambda k: k.y, reverse=True)
    terrainProfile = Part.makePolygon(points3D)
    #Part.show(terrainProfile)
    sectionTop = terrainProfile.section(limitTop)
    crossTopPoints = VertexesToPoints(sectionTop.Vertexes)
    cutPoints, PointList = getCuts(crossTopPoints, points3D)
    Cuts = []
    for i in cutPoints:
        Cuts.extend(i)
    sectionBottom = terrainProfile.section(limitBottom)
    crossBottomPoints = VertexesToPoints(sectionBottom.Vertexes)
    fillPoints, PointList = getCuts(crossBottomPoints, PointList)
    Fills = []
    for i in fillPoints:
        Fills.extend(i)
    PointList = sorted(PointList, key=lambda k: k.y, reverse=(trackerPath.Shape.Vertexes[-1].Point.y <
                                                              trackerPath.Shape.Vertexes[0].Point.y))
    #newPath = Draft.makeWire(PointList, closed=False, face=None)
    #newPath.Label = trackerPath.Label + "_NewPath"
    return Cuts, Fills, newPath
