[Solved] Help firing AboutDialog::on_copyButton_clicked() wanted by n00b
Re: [Solved] Help firing AboutDialog::on_copyButton_clicked() wanted by n00b
I know which one you mean. I can vaguely remember that it was not in the topic's title. What a big help!
Re: Help firing AboutDialog::on_copyButton_clicked() wanted by n00b
wmayer wrote: Sun Aug 20, 2017 9:11 pm FYI, in Qt any sub-class of QObject can re-implement the (in C++ virtual) method eventFilter() and can be installed to any other QObject-dervied instance to observe or filter the events it gets.
In C++ the class name of the About dialog including name spaces is called Gui::Dialog::AboutDialog and the class name of a QObject can be determined by its meta object. So, the event filter only looks for About dialogs and as event it uses the polish event which is called before the dialog is shown.
The name of the method of the dialog that is invoked when pressing the Copy button is called on_copyButton_clicked() and is marked as a slot function (for more information refer to the Qt docs to see what a slot function exactly is) and this allows it to allow to call it over its meta object.
By calling on_copyButton_clicked all the needed information is copied to the clipboard and the dialog can be closed again. Thus, a close event is posted to the dialog class.
The four lines at the end are needed to install the event filter to the global application object, invoke the Std_About command which internally creates the About dialog and removing the event filter again.
@wmayer
can this function be accessible without the GUI enabled (aka 'headless')?
No!
I have created a macro and have placed in my globals toolbar.
I can run the macro from the macro dialog by selecting and executing it.
However, if I run it from the toolbar I get an error message:
  File "/Users/cb/panhard/coupe/sanssoupapes/copyToClipboard.FCMacro", line 2, in <module>
    from PySide import QtOpenGL
<class 'ImportError'>: cannot import name 'QtOpenGL' from 'PySide' (/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Ext/PySide/__init__.py)
I can run other macros in the same way without problems. Any ideas?
You may have to add the file QtOpenGL.py inside FreeCAD's Ext\PySide directory with the content:
from PySide2.QtOpenGL import *
chrisb wrote: Thu Nov 14, 2019 12:52 am I have created a macro and have placed in my globals toolbar.
Any progress on this?
wmayer wrote: Thu Nov 14, 2019 12:22 pm
Sorry for being late: It works! Thank you.
wmayer wrote: Sun Aug 20, 2017 2:00 pm
from PySide import QtCore
from PySide import QtGui
class AboutInfo(QtCore.QObject):
  def eventFilter(self, obj, ev):
    if obj.metaObject().className() == "Gui::Dialog::AboutDialog":
      if ev.type() == ev.ChildPolished:
        print(obj.metaObject().className())
        mo = obj.metaObject()
        index = mo.indexOfMethod("on_copyButton_clicked()")
        if index > 0:
          mo.invokeMethod(obj, "on_copyButton_clicked")
          QtGui.qApp.postEvent(obj, QtGui.QCloseEvent())
    return False
ai=AboutInfo()
QtGui.qApp.installEventFilter(ai)
Gui.runCommand("Std_About")
QtGui.qApp.removeEventFilter(ai)
@wmayer how can I get this same output but using freecad --console ?
Not at all. Or how do you think to open the About dialog in CLI mode?
dprojects
Post by dprojects »
        if index > 0:
    return False
ai=AboutInfo()
Oh Man !!! This is what I was looking for. I added "Std_About" to the woodworking workbench because I didn't know how to grab the info content. Can I use your code? for example to add some info that the details has been already copied or something like that.
Thanks
Darek
github.com/dprojects
