Blender-like grid
looo
Re: Blender-like grid
Post by looo »
You can get the intersection of a screen-position (px, py) with a plane in 3d-space with this code:
I am not sure, but I think (px, py) is in the range of (0, 1) where 0 is left/upper and 1 is right/lower. But could be also the other way.
from pivy import coin
render_manager = Gui.ActiveView.getViewer().getSoRenderManager()
cam = render_manager.getCamera()
vol = pCam.getViewVolume()
line = coin.SbLine(*vol.projectPointToLine(coin.SbVec2f(pX,pY)))
plane = coin.SbPlane(normal, point)
point = plane.intersect(line)
Doing this for all 4 corner points of the screen and choosing the max/min values should give you the span to draw the grid. This could be updated again with a callbackNode which triggers at zooming or maybe also with a Sensor.
Blender also updates the grid spaces on zooming, another nice feature... ;)
yorik
Post by yorik »
Yes, I don't think the Blender grid is really infinite. I think it gets redrawn everytime the camera moves. That's how all openGL tutorials out there tell you to do it...
About the macro / .py thing: It was just a way of saying, it is not totally necessary to create a full FreeCAD module, if you have all the code inside one python file, it can live in the Macros folder too.
Chris_G
Post by Chris_G »
looo wrote:Doing this for all 4 corner points of the screen and choosing the max/min values should give you the span to draw the grid. This could be updated again with a callbackNode which triggers at zooming or maybe also with a Sensor.
Thanks looo.
I'll just stay away from the sensors for now :lol:
looo wrote:Blender also updates the grid spaces on zooming, another nice feature... ;)
I saw this. I'll look to see if it is difficult to do or not.
yorik wrote:Yes, I don't think the Blender grid is really infinite. I think it gets redrawn everytime the camera moves. That's how all openGL tutorials out there tell you to do it...
Thanks Yorik.
In case it can be useful to someone, here is an example of a custom SoSwitch that reacts to view direction :
class orthoViewSwitch(coin.SoSwitch):
    def __init__(self, cam = None):
        super(orthoViewSwitch, self).__init__()
        self.vec = coin.SoTransformVec3f()
        self.vec.vector = coin.SbVec3f(0,0,-1)
        self.calc = coin.SoCalculator()
        self.calc.A.connectFrom(self.vec.direction)
        self.calc.expression.set1Value(0, "ta=0.00001") # tolerance
        self.calc.expression.set1Value(1, "tA=vec3f(0,0,1)") # XY plane normal
        self.calc.expression.set1Value(2, "tB=vec3f(0,1,0)") # XZ plane normal
        self.calc.expression.set1Value(3, "tC=vec3f(1,0,0)") # YZ plane normal
        self.calc.expression.set1Value(4, "oa=fabs(dot(A,tA))") # XY value
        self.calc.expression.set1Value(5, "ob=fabs(dot(A,tB))") # XZ value
        self.calc.expression.set1Value(6, "oc=fabs(dot(A,tC))") # YZ value
        self.calc.expression.set1Value(7, "tb=(oa>ob)?oa:ob")
        self.calc.expression.set1Value(8, "tc=(tb>oc)?tb:oc") # winning value
        self.calc.expression.set1Value(9, "tf=(oa==tc)&&((oa+ta)>1)?1:0")
        self.calc.expression.set1Value(10,"tg=(ob==tc)&&((ob+ta)>1)?2:0")
        self.calc.expression.set1Value(11,"th=(oc==tc)&&((oc+ta)>1)?3:0")
        self.calc.expression.set1Value(12,"od=tf+tg+th") # switch value
        if cam:
            self.connectCamera(cam)
        else:
            self.whichChild = 0
    def connectCamera(self, cam):
        self.vec.matrix.connectFrom(cam.orientation)
        self.whichChild.connectFrom(self.calc.od)
    def disconnect(self):
        self.whichChild = 0
    def setTolerance(self, tol):
        self.calc.expression.set1Value(0,"ta=%f"%tol)
trans = coin.SoTranslation()
trans.translation = (2.0,0,0)
color = coin.SoBaseColor()
color.rgb = (0,0,0)
cube = coin.SoCube()
# One text node in each child of the Switch
no = coin.SoText2()
no.string = "View is not orthogonal to any plane"
xy = coin.SoText2()
xy.string = "View is orthogonal to XY plane"
xz = coin.SoText2()
xz.string = "View is orthogonal to XZ plane"
yz = coin.SoText2()
yz.string = "View is orthogonal to YZ plane"
orthoSwitch = orthoViewSwitch()
orthoSwitch.addChild(no)
orthoSwitch.addChild(xy)
orthoSwitch.addChild(xz)
orthoSwitch.addChild(yz)
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
sg.addChild(cube)
sg.addChild(color)
sg.addChild(trans)
sg.addChild(orthoSwitch)
cam = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
# Connect the switch to the camera
orthoSwitch.connectCamera(cam)
# adjust the detection tolerance
orthoSwitch.setTolerance(0.001)
mario52
Post by mario52 »
hi Chris_G
good project is it possible to replace the axis or include a cube with the axis existant ?
example:
Or include one shape in the cube like here for visualise easily the view
mario
Chris_G
Post by Chris_G »
@Mario,
I'll put this on the TODO list.
I have experimented with auto-scale ( grid sub-divisions that gradually appear / disappear when zooming in / out ).
Test code below ( with Pablogil's color ;) )
Currently, it only works when zooming in around origin. The grid disappears if zooming on a point away from origin.
But that's a step forward ...
import FreeCAD
import FreeCADGui
import math
class gridNode(coin.SoSeparator):
    def __init__(self):
        super(gridNode, self).__init__()
        #self.vec.matrix.connectFrom(cam.orientation)
        self.calc.expression.set1Value(0,"ta=0.5") # maxviz
        self.calc.expression.set1Value(1,"tb=20.0") # factor
        self.calc.expression.set1Value(2,"tA=vec3f(1,0,0)") # plane normal
        self.calc.expression.set1Value(3,"tc=dot(A,tA)")
        self.calc.expression.set1Value(4,"td=fabs(tc)")
        self.calc.expression.set1Value(5,"oa=1.0-ta*pow(td,tb)")
        self.calc.expression.set1Value(6,"oA=vec3f(oa,0,0)")
        self.scaleEngine = coin.SoCalculator()
        #self.scaleEngine.a.connectFrom(cam.height)
        self.scaleEngine.expression.set1Value(0,"ta=floor(log10(a/10))")
        self.scaleEngine.expression.set1Value(1,"tb=pow(10,ta)")
        self.scaleEngine.expression.set1Value(2,"oA=vec3f(tb,tb,tb)")
        self.scaleEngine.expression.set1Value(3,"oa=0.01*a/tb")
        self.calc2 = coin.SoCalculator()
        self.calc2.a.connectFrom(self.scaleEngine.oa)
        self.calc2.b.connectFrom(self.calc.oa)
        self.calc2.expression.set1Value(0,"ta=pow(a,0.3)")
        self.calc2.expression.set1Value(1,"oa=(b>ta)?b:ta")
        self.material1 = coin.SoMaterial()
        self.material2 = coin.SoMaterial()
        self.material3 = coin.SoMaterial()
        self.material4 = coin.SoMaterial()
        self.coord = coin.SoCoordinate3()
        self.coord2= coin.SoCoordinate3()
        self.line1 = coin.SoIndexedLineSet()
        self.line2 = coin.SoIndexedLineSet()
        self.lineSet = coin.SoIndexedLineSet()
        self.lineSet2= coin.SoIndexedLineSet()
        self.miniscale = coin.SoScale()
        self.miniscale.scaleFactor = coin.SbVec3f(0.1,0.1,0.1)
        self.mainscale = coin.SoScale()
        self.mainscale.scaleFactor.connectFrom(self.scaleEngine.oA)
        self.addChild(self.mainscale)
        self.addChild(self.coord)
        self.addChild(self.material1)
        self.addChild(self.line1)
        self.addChild(self.material2)
        self.addChild(self.line2)
        self.addChild(self.material3)
        self.addChild(self.lineSet)
        self.addChild(self.miniscale)
        self.addChild(self.material4)
        self.addChild(self.coord2)
        self.addChild(self.lineSet2)
        self._vector1 = coin.SbVec3f(1,0,0)
        self._vector2 = coin.SbVec3f(0,1,0)
        self.normal = self._vector1.cross(self._vector2)
        self._mainDim = 100
        self._subDim = 10
        self._maxviz = 1.0
        self._factor = 1.0
        self._numGridLines = 4
        self.material1.diffuseColor = coin.SbColor(1,0,0)
        self.material2.diffuseColor = coin.SbColor(0,1,0)
        self.material3.diffuseColor = coin.SbColor(0.5,0.5,0.5)
        self.material4.diffuseColor = coin.SbColor(0.5,0.5,0.5)
        self.material3.transparency.connectFrom(self.calc.oa)
        self.material4.transparency.connectFrom(self.calc2.oa)
    @property
    def transparency(self):
        return self.material3.transparency.getValues()[0]
    @transparency.setter
    def transparency(self, tr):
#        self.material3.transparency = tr
#        self.material2.transparency = tr
    @property
    def vector1color(self):
        return self.material1.diffuseColor.getValues()[0].getValue()
    @vector1color.setter
    def vector1color(self, color):
        self.material1.diffuseColor = (color[0], color[1], color[2])
    @property
    def vector2color(self):
        return self.material2.diffuseColor.getValues()[0].getValue()
    @vector2color.setter
    def vector2color(self, color):
        self.material2.diffuseColor = (color[0], color[1], color[2])
    @property
    def gridcolor(self):
        return self.material3.diffuseColor.getValues()[0].getValue()
    @gridcolor.setter
    def gridcolor(self, color):
        self.material3.diffuseColor = (color[0], color[1], color[2])
        self.material4.diffuseColor = (color[0], color[1], color[2])
    @property
    def vector1dir(self):
        return self._vector1.getValue()
    @vector1dir.setter
    def vector1dir(self, vec):
        self._vector1 = coin.SbVec3f(vec)
        self.calc.expression.set1Value(2,"tA=vec3f(%f,%f,%f)"%(self.normal.getValue()[0],self.normal.getValue()[1],self.normal.getValue()[2]))
        self.buildGrid()
    @property
    def vector2dir(self):
        return self._vector2.getValue()
    @vector2dir.setter
    def vector2dir(self, vec):
        self._vector2 = coin.SbVec3f(vec)
        self.buildGrid()
    @property
    def mainDim(self):
        return self._mainDim
    @mainDim.setter
    def mainDim(self, n):
        self._mainDim = n
        self.buildGrid()
    @property
    def subDim(self):
        return self._subDim
    @subDim.setter
    def subDim(self, n):
        self._subDim = n
        self.buildGrid()
    @property
    def maxviz(self):
        return self._maxviz
    @maxviz.setter
    def maxviz(self, n):
        self._maxviz = n
        self.calc.expression.set1Value(0,"ta=%f"%n) # maxviz
    @property
    def factor(self):
        return self._factor
    @factor.setter
    def factor(self, n):
        self._factor = n
        self.calc.expression.set1Value(1,"tb=%f"%n) # factor
    def linkTo(self, cam):
    def updateTransformedNormal(self):
#          // First get hold of an SoPath through the scenegraph down to the
#          // node ("mynode") you want to query about its current world space
#          // transformation(s).
#          SoSearchAction * searchaction = new SoSearchAction;
#          searchaction->setNode(mynode);
#          searchaction->apply(myscenegraphroot);
#          SoPath * path = searchaction->getPath();
#          assert(path != NULL);
#          // Then apply the SoGetMatrixAction to get the full transformation
#          // matrix from world space.
#          const SbViewportRegion vpr = myviewer->getViewportRegion();
#          SoGetMatrixAction * getmatrixaction = new SoGetMatrixAction(vpr);
#          getmatrixaction->apply(path);
#          SbMatrix transformation = getmatrixaction->getMatrix();
#          // And if you want to access the individual transformation
#          // components of the matrix:
#          SbVec3f translation;
#          SbRotation rotation;
#          SbVec3f scalevector;
#          SbRotation scaleorientation;
#          transformation.getTransform(translation, rotation, scalevector, scaleorientation);
        searchaction = coin.SoSearchAction()
        searchaction.setNode(self)
        searchaction.apply(FreeCADGui.ActiveDocument.ActiveView.getSceneGraph())
        path = searchaction.getPath()
        vpr = FreeCADGui.ActiveDocument.ActiveView.getViewer().getViewportRegion()
        getmatrixaction = coin.SoGetMatrixAction(vpr)
        getmatrixaction.apply(path)
        transformation = getmatrixaction.getMatrix()
        self.transformedNormal = transformation.multVecMatrix(self.normal)
        self.calc.expression.set1Value(2,"tA=vec3f(%f,%f,%f)"%(self.transformedNormal.getValue()[0],self.transformedNormal.getValue()[1],self.transformedNormal.getValue()[2]))
        return()
    def gridPts(self, t, s):
        n = t*s
        r = []
        nr = []
        for i in range(1,n):
            r.append(  1.0 * self._subDim * i)
            nr.append(-1.0 * self._subDim * i)
        r.append(  self._mainDim)
        nr.append(-self._mainDim)
        nr.reverse()
        fullRange = nr + r
        pts = []
        for i in fullRange:
            pts.append(1*i * self._vector2 - s*self._mainDim * self._vector1)
            pts.append(1*i * self._vector2 + s*self._mainDim * self._vector1)
            pts.append(1*i * self._vector1 - s*self._mainDim * self._vector2)
            pts.append(1*i * self._vector1 + s*self._mainDim * self._vector2)
        return(pts)
    def buildGrid(self):
        n = int(1.0 * self._mainDim / self._subDim)
        pts = []
        pts.append(-self._mainDim * self._vector1)
        pts.append( self._mainDim * self._vector1)
        pts.append(-self._mainDim * self._vector2)
        pts.append( self._mainDim * self._vector2)
        pts += self.gridPts(n,1)
        self.coord.point.setValues(0,len(pts),pts)
        self._numGridLines = len(pts) / 2.0
        pts2 = self.gridPts(n,10)
        self.coord2.point.setValues(0,len(pts2),pts2)
        #self._numGridLines = len(pts) / 2.0
        a = []
        l = len(pts)-4
        for i in range(l/2):
            a.append(2*i + 4)
            a.append(2*i + 5)
            a.append(-1)
        self.line1.coordIndex.setValue(0)
        self.line1.coordIndex.setValues(0, 3, [0,1,-1])
        self.line2.coordIndex.setValue(0)
        self.line2.coordIndex.setValues(0, 3, [2,3,-1])
        self.lineSet.coordIndex.setValue(0)
        self.lineSet.coordIndex.setValues(0, len(a), a)
        a2 = []
        l = len(pts2)
            a2.append(2*i)
            a2.append(2*i + 1)
            a2.append(-1)
        self.lineSet2.coordIndex.setValue(0)
        self.lineSet2.coordIndex.setValues(0, len(a2), a2)
class gridObject:
    def __init__(self, obj):
        obj.Proxy = self
        obj.addProperty("App::PropertyPlacement",  "Placement",   "Base",   "Placement")
    def execute(self, obj):
        return()
    def onChanged(self, fp, prop):
        if prop == 'Placement':
            FreeCAD.Console.PrintMessage('Placement udpate\n')
            tr = fp.Placement.Base
            ro = fp.Placement.Rotation.Q
            fp.ViewObject.Proxy.trans.translation = coin.SbVec3f(tr.x,tr.y,tr.z)
            fp.ViewObject.Proxy.trans.rotation = coin.SbRotation(ro[0],ro[1],ro[2],ro[3])
class gridVP:
    def __init__(self, obj ):
        obj.addProperty("App::PropertyDistance",  "Total",         "Size",   "Size of a grid quadrant").Total = '100mm'
        obj.addProperty("App::PropertyDistance",  "Subdivision",   "Size",   "Size of subdivisions").Subdivision = '10mm'
        obj.addProperty("App::PropertyFloat",     "XY_Attenuation", "View",   "XY plane attenuation").XY_Attenuation = 2.0
        obj.addProperty("App::PropertyFloat",     "XZ_Attenuation", "View",   "XZ plane attenuation").XZ_Attenuation = 50.0
        obj.addProperty("App::PropertyFloat",     "YZ_Attenuation", "View",   "YZ plane attenuation").YZ_Attenuation = 50.0
        obj.addProperty("App::PropertyFloat",     "XY_Visibility",  "View",   "XY plane max visibility").XY_Visibility = 1.0
        obj.addProperty("App::PropertyFloat",     "XZ_Visibility",  "View",   "XZ plane max visibility").XZ_Visibility = 0.5
        obj.addProperty("App::PropertyFloat",     "YZ_Visibility",  "View",   "YZ plane max visibility").YZ_Visibility = 0.5
        obj.addProperty("App::PropertyColor",     "GridColor",     "Color",  "Grid Color").GridColor = (0.5,0.5,0.5)
        obj.Proxy = self
    def attach(self, obj):
        self.trans = coin.SoTransform()
        self.xy = gridNode()
        self.xy.vector1dir = (1,0,0)
        self.xy.vector1color = (0.827,0.149,0.149) # red (X)
        self.xy.vector2dir = (0,1,0)
        self.xy.vector2color = (0.400,0.590,0.200) # green (Y)
        self.xy.mainDim = 100
        self.xy.subDim = 10
        self.xy.maxviz = 1.0
        self.xz = gridNode()
        self.xz.vector1dir = (1,0,0)
        self.xz.vector1color = (0.827,0.149,0.149) # red (X)
        self.xz.vector2dir = (0,0,1)
        self.xz.vector2color = (0.133,0.490,0.882) # blue (Z)
        self.xz.mainDim = 100
        self.xz.subDim = 10
        self.xz.maxviz = 0.5
        self.yz = gridNode()
        self.yz.vector1dir = (0,1,0)
        self.yz.vector1color = (0.400,0.590,0.200) # green (Y)
        self.yz.vector2dir = (0,0,1)
        self.yz.vector2color = (0.133,0.490,0.882) # blue (Z)
        self.yz.mainDim = 100
        self.yz.subDim = 10
        self.yz.maxviz = 0.5
        self.sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
        self.cam = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
        self.xy.linkTo(self.cam)
        self.xy.factor = 1.
        self.xz.linkTo(self.cam)
        self.xz.factor = 50.
        self.yz.linkTo(self.cam)
        self.yz.factor = 50.
        self.grid = coin.SoGroup()
        self.grid.addChild(self.trans)
        self.grid.addChild(self.xy)
        self.grid.addChild(self.xz)
        self.grid.addChild(self.yz)
        obj.addDisplayMode(self.grid,"Wireframe")
        self.ViewObject = obj
        self.Object = obj.Object
#    def updateCam(self):
#        self.cam = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
#        self.xy.linkTo(self.cam)
#        self.xz.linkTo(self.cam)
#        self.yz.linkTo(self.cam)
    def getIcon(self):
        return (":/icons/Draft_Grid.svg")
    def getDisplayModes(self,obj):
         "Return a list of display modes."
         modes=[]
         modes.append("Wireframe")
         return modes
    def getDefaultDisplayMode(self):
         "Return the name of the default display mode. It must be defined in getDisplayModes."
         return "Wireframe"
    def setDisplayMode(self,mode):
         return mode
    def onChanged(self, vp, prop):
        self.updateCam()
        if prop == 'Total':
            if float(vp.Total) >= float(vp.Subdivision):
                self.xy.mainDim = float(vp.Total)
                self.xz.mainDim = float(vp.Total)
                self.yz.mainDim = float(vp.Total)
            else:
                vp.Total = vp.Subdivision
        if prop == 'Subdivision':
                self.xy.subDim = float(vp.Subdivision)
                self.xz.subDim = float(vp.Subdivision)
                self.yz.subDim = float(vp.Subdivision)
            else:
                vp.Subdivision = vp.Total
        if prop == 'XY_Attenuation':
            if vp.XY_Attenuation < 0.1:
                vp.XY_Attenuation = 0.1
            elif vp.XY_Attenuation > 100:
                vp.XY_Attenuation = 100
            self.xy.factor = vp.XY_Attenuation
        if prop == 'XZ_Attenuation':
            if vp.XZ_Attenuation < 0.1:
                vp.XZ_Attenuation = 0.1
            elif vp.XZ_Attenuation > 100:
                vp.XZ_Attenuation = 100
            self.xz.factor = vp.XZ_Attenuation
        if prop == 'YZ_Attenuation':
            if vp.YZ_Attenuation < 0.1:
                vp.YZ_Attenuation = 0.1
            elif vp.YZ_Attenuation > 100:
                vp.YZ_Attenuation = 100
            self.yz.factor = vp.YZ_Attenuation
        if prop == 'XY_Visibility':
            if vp.XY_Visibility < 0.0:
                vp.XY_Visibility = 0.0
            elif vp.XY_Visibility > 1.0:
                vp.XY_Visibility = 1.0
            self.xy.maxviz = vp.XY_Visibility
        if prop == 'XZ_Visibility':
            if vp.XZ_Visibility < 0.0:
                vp.XZ_Visibility = 0.0
            elif vp.XZ_Visibility > 1.0:
                vp.XZ_Visibility = 1.0
            self.xz.maxviz = vp.XZ_Visibility
        if prop == 'YZ_Visibility':
            if vp.YZ_Visibility < 0.0:
                vp.YZ_Visibility = 0.0
            elif vp.YZ_Visibility > 1.0:
                vp.YZ_Visibility = 1.0
            self.yz.maxviz = vp.YZ_Visibility
        if prop == 'GridColor':
            self.xy.gridcolor = vp.GridColor
            self.xz.gridcolor = vp.GridColor
            self.yz.gridcolor = vp.GridColor
            tr = vp.Object.Placement.Base
            ro = vp.Object.Placement.Rotation.Q
            self.trans.translation = coin.SbVec3f(tr.x,tr.y,tr.z)
            self.trans.rotation = coin.SbRotation(ro[0],ro[1],ro[2],ro[3])
            self.xy.updateTransformedNormal()
            self.xz.updateTransformedNormal()
            self.yz.updateTransformedNormal()
    def onDelete(self, feature, subelements):
        self.sg.removeChild(self.grid)
        return(True)
def main():
    obj=FreeCAD.ActiveDocument.addObject("App::FeaturePython","Grid")
    gridObject(obj)
    gridVP(obj.ViewObject)
if __name__ == '__main__':
    main()
mario52
Post by mario52 »
hi
Chris_G wrote:@Mario,
thanks
Chris_G wrote:Currently, it only works when zooming in around origin. The grid disappears if zooming on a point away from origin.
I think that the cause is the axes infinite then the Image zoom remote remote ....
mario
pablogil
Post by pablogil »
Working fine here, it's a nice update.
One thing I have seen (that also happens with regular Draft grid) and annoys me: is there a possibility that "zoom all" tool filters the grid so that it doesn't calculate it as part of the project geometry?
Thanks!
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Chris_G
Post by Chris_G »
mario52 wrote:I think that the cause is the axes infinite then the Image zoom remote remote ....
pablogil wrote:One thing I have seen (that also happens with regular Draft grid) and annoys me: is there a possibility that "zoom all" tool filters the grid so that it doesn't calculate it as part of the project geometry?
Both problems are similar.
Unfortunately, currently, I don't see any easy way to fix this. The "ViewFitAll" action is done directly with coin, on the whole scenegraph. So all visible objects in the 3D view are used for the computation.
I am facing a contradiction here :
- ViewFitAll computes the general bounding box of 3DView objects and modifies the camera so that it's own ViewVolume contains the bounding box.
- the "infinite" grid, on the other hand, gets the camera viewvolume, and expand itself to be bigger than this viewVolume.
It is the snake biting its own tail ( a commonly used french sentence, I don't know of it is used in other countries ? )
Chris
triplus
Post by triplus »
Having an option to set grid size and above that size for the grid to expand to available geometry size? Could that be implemented? And could Draft Snap functionality be made to work with your grid? For some interactive and not just visual use cases.
P.S. To be honest i am not sure if infinite grid is all that useful. As you work in finite space anyway and there is where you need the grid.
mnesarco
Post by mnesarco »
Chris_G wrote: Thu May 11, 2017 4:19 pm @Mario,
import FreeCAD
import FreeCADGui
import math
    def __init__(self):
        self._mainDim = 100
        self._subDim = 10
        self._maxviz = 1.0
        self._factor = 1.0
    @property
    @property
    @property
    @property
    @gridcolor.setter
    @property
    @vector1dir.setter
        self.buildGrid()
    @property
    @vector2dir.setter
        self.buildGrid()
    @property
    def mainDim(self):
    @mainDim.setter
        self._mainDim = n
        self.buildGrid()
    @property
    def subDim(self):
        return self._subDim
    @subDim.setter
        self._subDim = n
        self.buildGrid()
    @property
    def maxviz(self):
        return self._maxviz
    @maxviz.setter
        self._maxviz = n
    @property
    def factor(self):
        return self._factor
    @factor.setter
        self._factor = n
        return()
        n = t*s
        r = []
        nr = []
        nr.reverse()
        fullRange = nr + r
        pts = []
        for i in fullRange:
        return(pts)
        pts = []
        a = []
        l = len(pts)-4
            a.append(2*i + 4)
            a.append(2*i + 5)
            a.append(-1)
        a2 = []
        l = len(pts2)
            a2.append(2*i)
            a2.append(2*i + 1)
            a2.append(-1)
class gridObject:
        obj.Proxy = self
        return()
class gridVP:
        obj.Proxy = self
        self.xy.subDim = 10
        self.xz.subDim = 10
        self.yz.subDim = 10
        self.xy.factor = 1.
    def getIcon(self):
         modes=[]
         return modes
         return "Wireframe"
         return mode
        self.updateCam()
        if prop == 'Total':
            else:
            else:
        return(True)
def main():
    gridObject(obj)
    main()
Hi Chris_G, I have tried this with FreeCAD 0.19 (git 21125) and i get this error:
  File "/home/mnesarco/.FreeCAD/Macro/Grid.FCMacro", line 316, in attach
  File "/tmp/.mount_FreeCAymu2jP/usr/lib/python3.8/site-packages/pivy/coin.py", line 4000, in __setattr__
    return SoBase.__setattr__(self, name, value)
  File "/home/mnesarco/.FreeCAD/Macro/Grid.FCMacro", line 130, in vector1dir
    self.buildGrid()
  File "/home/mnesarco/.FreeCAD/Macro/Grid.FCMacro", line 263, in buildGrid
<class 'TypeError'>: 'float' object cannot be interpreted as an integer
  File "/home/mnesarco/.FreeCAD/Macro/Grid.FCMacro", line 392, in onChanged
    self.updateCam()
  File "/home/mnesarco/.FreeCAD/Macro/Grid.FCMacro", line 388, in updateCam
<class 'AttributeError'>: 'gridVP' object has no attribute 'xz'
    self.updateCam()
    self.updateCam()
I see this thread is old, is there a new version somewhere else that works with 0.19?
Cheers.
