If you have other issues with the Std_AddonMgr command you should maybe start a new topic.
Plug-in for AUTODESK Inventor files
Re: Plug-in for AUTODESK Inventor files
https://forum.freecadweb.org/viewtopic.php?f=4&t=46569Roy_043 wrote: ↑Wed May 20, 2020 2:04 pmIf you have other issues with the Std_AddonMgr command you should maybe start a new topic.
Back from vacation without any computerRoy_043 wrote: ↑Wed May 20, 2020 1:59 pm Another test file: Primitives_test.dxf.
Error:
File "C:\Users\<username>\AppData\Roaming\FreeCAD\Mod\InventorLoader\Acis.py", line 2704, in setSubtype
self.vrange, i = getInterval(chunks, i, MIN_INF, MAX_INF, getScale())
<class 'IndexError'>: list index out of range
The error should be fixed now.
There still remains a common problem with the transformation information of a body. The info is currently ignored because I don't know a way to attach placement information to a shell in STEP.
Whenever opening the preferences one gets a long list of SVG files that couldn't be found. A typical warning looks like:
There are two reasons for the issue:Cannot open file '/home/username/Projects/Mod/InventorLoader/Resources/icons/Constraint_Length.svg', because: No such file or directory
- The path names inside PrefsInventorLoader.ui are all wrong. They are of the form:
but instead should be
../Mod/InventorLoader/Resources/icons/Constraint_Length.svg
After fixing this then when loading the file into the Qt Designer you can see the icons.Code: Select all
../icons/Constraint_Length.svg
- To make it working for FreeCAD an additional change is required. This is fixed with git commit fa7ae69da
Thank you for the hint with the corrupted ICON paths. Should be fixed now - but no possibility to check it out.
I have checked out the new version and I can confirm that it works now. Thanks!
- thomas-neemann
a customer of mine would like to switch from inventor to freecad. is it possible to import inventor data and continue working on the sketch level?
You better ask jmplonka directly as I don't know how complete the Inventor support is.thomas-neemann wrote: ↑Thu Jun 04, 2020 8:50 pm
- thomas-neemann
thank you. freecad is sensationalwmayer wrote: ↑Fri Jun 05, 2020 5:58 amYou better ask jmplonka directly as I don't know how complete the Inventor support is.thomas-neemann wrote: ↑Thu Jun 04, 2020 8:50 pm
