How to assign Material in FreeCAD python script ?
student007007
Post by student007007 »
How can I assign a material to the code? For example Concrete.
Code:
import FreeCADGui as Gui
import FreeCAD as App
document_name = "bla bla"
file_name = "PATH/{}.FCStd".format(document_name)
Gui.showMainWindow()
doc = App.newDocument(document_name)
App.setActiveDocument(document_name)
doc = App.ActiveDocument
doc.addObject("Part::Cylinder","myCylinder")
doc.myCylinder.Radius = 12
doc.myCylinder.Height = 5
doc.myCylinder.ViewObject.Visibility = True
doc.recompute()
Gui.exec_loop()
Reason: Updated thread title to be less generic
Re: Material
Please edit your post and put the code in code tags using the button </>. That makes the post easier to read. It is not so important here, but in other cases it shows immediately if there are indentations or not.
student007007
Re: Material
I will do it next time.
But do you know the answer to the problem?
Re: Material
We should definately have a section in Material to answer this question
Roy_043
Re: Material
Post by Roy_043 »
obj.ViewObject.ShapeMaterial.set("Bronze")
BTW: This and the Material page are unrelated.
