Translate "Run" in FEM.TS [ru, uk, eu]
vm4dim
Post by vm4dim »
Translate word "Run" (it use in Fem SolverCalculiX Task Dialog)
has changed in the last month in several languages.
In Russian Fem_ru.ts:
Before: 28,795 commits May 5, 2022
https://github.com/FreeCAD/FreeCAD/blob ... _ru.ts#L47
      <source>Run</source>
      <translation>Запустить</translation>
After: 28,935 commits May 27, 2022
https://github.com/FreeCAD/FreeCAD/blob ... _ru.ts#L52
      <translation>зазор</translation>
Запустить - Correct translation.
зазор - Incorrect, it means (gap, clearance)
Ukrainian and Basque also look wrong.
https://github.com/FreeCAD/FreeCAD/blob ... _uk.ts#L47
      <translation>Запустити</translation>
https://github.com/FreeCAD/FreeCAD/blob ... _uk.ts#L52
      <translation>Відстань між стіною і коньковою обшивкою.</translation>
https://github.com/FreeCAD/FreeCAD/blob ... _eu.ts#L47
      <translation>Exekutatu</translation>
https://github.com/FreeCAD/FreeCAD/blob ... _eu.ts#L52
      <translation>distantzia</translation>
It's actual for current master/HEAD. 28,984 commits
kaktus
Re: Translate "Run" in FEM.TS [ru, uk, eu]
Post by kaktus »
Hi.
Do you have an active account with Crowdin :?:
vm4dim
Post by vm4dim »
kaktus wrote: Wed Jun 01, 2022 2:31 pm Hi.
https://crowdin.com/profile/vm4dim
active? It new account
kaktus
Post by kaktus »
cool
See the string below and the search settings in the attached image.
The link leads to three occurrences of this string.
However, not all may be available to you.
Several of them have the "hidden" attribute.
I have corrected the translation to the one recommended by you.
It now looks like this
https://crowdin.com/translate/freecad/a ... ue=0#q=Run
kaktus
Post by kaktus »
Hi.
@vm4dim
Did you test the translation after the changes were made :?:
Is everything to your liking?
See also this guide:
https://github.com/FreeCAD/FreeCAD-translations#testing
regards
vm4dim
Post by vm4dim »
Hi.
kaktus wrote: Thu Jun 02, 2022 5:25 am Did you test the translation after the changes were made :?:
No, but I think it will work right when it's copied to Git, I don't see a problem.
Thanks.
