Coordinating Documentation and Translations before v0.20 release
Re: Coordinating Documentation and Translations before v0.20 release
Probably last thing before we make the official release. There is a windows libpack packaging/3rd-party dependency issue that is blocking release ATM.
uwestoehr
Post by uwestoehr »
kaktus wrote: Sun May 15, 2022 11:07 am When is this supposed to happen?
The release should definitely happen this month. Here is a first test release: https://forum.freecadweb.org/viewtopic.php?f=9&t=68705
(your todays' changes are not included in this)
@uwestoehr can we ask the devs, testers, and power-users to move their attention to documentation and solving open translations issues?
If each dev could help make a list of open/pending documentation needs (for their respective workbenches) since not all features or 'known issues' for certain functions/tools get updated in the wiki even though they've been fixed or modified. In other words, Sketcher folks can divy up the Sketcher workbench wiki pages, check for accuracy, make a list and help orient documentation writers (or they could do it themselves) what needs modifying.
Also, continuing with the Sketcher workbench as an example, if a dev could log in to the crowdin and look at all the open issues that translators have flagged for Sketcher related translations.
Crowdin UI showing an 'Unresolved' issue.
Log in to crowdin via https://crowdin.com/project/freecad
kaktus
Post by kaktus »
Regarding the workbench sketcher and the Crowdin environment
there is one unsolved issue:
https://github.com/FreeCAD/FreeCAD-tran ... 1120170593
uwestoehr
Post by uwestoehr »
Kunda1 wrote: Sun May 15, 2022 5:39 pm @uwestoehr can we ask the devs, testers, and power-users to move their attention to documentation and solving open translations issues?
Sure. Just post in this thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=66407
If there are issues they should be reported to our main issue tracker. This way they will be fixed quickly.
pmlee
Post by pmlee »
This is a good suggestion. Actually, I've modified some old translations which I think are Inappropriate. I'll leave comments in the open issue as a remark.
david69
Post by david69 »
checking the GUI, notice we don't find the original text for:
- Inspection wb
- Surface wb
note also: https://forum.freecadweb.org/viewtopic.php?f=18&t=68729
I can not find neither the original text corresponding to
Capture du 2022-05-16 10-54-53.png (67.37 KiB) Viewed 3336 times
they need fixes
M4x
Post by M4x »
Regarding the wiki: Is this page up-to-date (enough)? https://wiki.freecad.org/index.php?titl ... nishedDocu
Roy_043
Post by Roy_043 »
M4x wrote: Sun May 29, 2022 9:23 am Regarding the wiki: Is this page up-to-date (enough)? https://wiki.freecad.org/index.php?titl ... nishedDocu
Probably not. There are pages in that list that I would consider finished and, on the other hand, unfinished pages that are not included. Also keep in mind that a 'finished' page can be out of date.
M4x
Post by M4x »
Therefore I shouldn't use this as an orientation and check look through the workbenches "I know" instead?
