[Solved] Getting a vertical pipe in a code block
chennes
Post by chennes »
I'm trying to document a new feature and to do so I need to display a vertical pipe ("|") inside a block of code, like this:
{{Code|code=
obj=FreeCAD.ActiveDocument.addObject("App::FeaturePython","InternalObjectName")
obj.Label = "User-friendly label"
obj.addProperty('App::PropertyEnumeration', 'ThePropertyName', 'Subsection', 'Description for tooltip')
obj.ThePropertyName = ["Group 1 | Item A", "Group 1 | Item B", "Group 2 | Another item", "Group 2 | Last item"]  // set allowed items
obj.ThePropertyName = "Group 1 | Item A"                  // choose single item
That code doesn't work, the pipe gets interpreted by MediaWiki, and I can't figure out how to stop it. How do I get a | in a code block?
Chris Hennes
Pioneer Library System
openBrain
Re: Getting a vertical pipe in a code block
Post by openBrain »
Does '{{|}}' or '|' work?
chennes
Post by chennes »
Nope -- they both show up literally.
Chris Hennes
Roy_043
Post by Roy_043 »
There are two options:
A
Enclose the piping character in nowiki tags:
<nowiki>|</nowiki>
B
Use <syntaxhighlight> tags instead of the {{Code}} template. See https://wiki.freecadweb.org/Help:Editing.
You can also use <pre> tags, but that would mean no syntax highlighting.
BTW
Since PEP8 seems to be quite important in the case of PRs, it would be a good idea if any code samples that are added to the Wiki are also PEP8 compliant. :twisted:
Roy_043
Post by Roy_043 »
Is // a valid way to start a Python comment?
chennes
Post by chennes »
lol, no, I was just going to write about that -- I fixed it in the code I was editing, but this is copy-and-paste-ware, so it's elsewhere on the page, too.
https://wiki.freecadweb.org/FeaturePyth ... Properties
Chris Hennes
