Std_Placement & Placement
kaktus
Post by kaktus »
The Wiki contains two pages with a description of the Placement tool. Are both necessary :?:
https://wiki.freecadweb.org/Std_Placement
https://wiki.freecadweb.org/Placement
:idea:
Re: Std_Placement & Placement
kaktus wrote: Wed Mar 30, 2022 4:27 am The Wiki contains two pages with a description of the Placement tool. Are both necessary :?:
I prefer how the first one starts with the Placement dialog and no Python console. The second is of course the more exhaustive - and I had made a small contribution to it :mrgreen: .
NewJoker
Post by NewJoker »
If I understand it correctly, the first one is just about the Std Placement command while the second one is about a concept of placement in general. So it makes sense to keep both. They even refer to each other at some point.
NewJoker wrote: Wed Mar 30, 2022 12:44 pm So it makes sense to keep both.
The contents should not be discarded; they can well be placed on a single page though.
kaktus
Post by kaktus »
Such a solution seems reasonable to me.
Roy_043
Post by Roy_043 »
NewJoker wrote: Wed Mar 30, 2022 12:44 pm the first one is just about the Std Placement command while the second one is about a concept of placement in general. So it makes sense to keep both. They even refer to each other at some point.
This is how I see the pages as well. There are other command reference pages that could benefit from the same approach. F.e. Std_LinkMake.
