I've translated some other pages without problem at the same time.Échec de la publication de la traduction : This page is locked because the translatable page is currently being moved.
Part Module page issue with recording
only with this page Part_Module today, when I want to record the translation, here is the message:
Re: Part Module page issue with recording
Last year several attempts were made to move the Part_Module page. None succeeded. This issue is related.
These problems have been reported before, but were never fixed. Probably because nobody on the FreeCAD team has enough knowledge.
Instead of moving the Part_Module page we may need to create a new Part_Workbench page.
Can you give the numbers of the translation units involved?
we are talking about 3 items
Sorry, what I meant was the tags of the translation units involved. These were last edited:
<!--T:87-->
<!--T:89-->
<!--T:90-->
These translation units are indeed locked.
I have removed the tags of the following translation units that were locked. The numbers after the arrows are for the new translation units.
The Wiki should be able to find 100% translations for most new units.
But you can also retrieve the old translations with:
Note that (re)translating the page title is currently not possible, because the Page_display_title translation unit is also locked:
87 -> 121
88 -> 124
89 -> 122
90 -> 123
91 -> 125
92 -> 126
93 -> 127
94 -> 128
95 -> 129
96 -> 130
97 -> 131
98 -> 132
99 -> 133
https://wiki.freecadweb.org/index.php?title=Translations:Part_Module/87/fr&action=edit
https://wiki.freecadweb.org/index.php?title=Translations:Part_Module/88/fr&action=edit
etc.
https://wiki.freecadweb.org/index.php?title=Translations:Part_Workbench/Page_display_title/fr&action=edit
fixed Roy, thank you
