Volunteers: Unfinished Wiki pages for Part Workbench
Re: Volunteers: Unfinished Wiki pages for Part Workbench
I inserted a couple of tested scripting examples and found some interesting things.
Sometimes the counting variable names are not equal. Angle1, Angle2 or Angle0 and so on. Is there a rule of thumb for coding (always start at a counter of 0) oder what else?
Some of the Parameters do not have tool tip texts or identical tool tip text, which is not helpful in my opinion.
Can I make a Github PR to fill in this, or should this be discussed in the developer forum first?
And the question is, should I make a screenshot of the scripting result after the scripting section?
I suggest to open a new forum thread in the developer discussion forum and x-post the link back to here.
Please insert Part Prism to your list. I marked it as incomplete.Kunda1 wrote: ↑Mon Jan 31, 2022 3:38 pm Per https://wiki.freecadweb.org/index.php?t ... nishedDocu
the following Part WB wiki pages are marked incomplete:
Part BoxSelection
Part Wedge
Reason: correct wiki link
Done, thanks!
Please insert Part_Tube to your list.
The scripting sections contains the following not workin line of code.
I tried this in the 0.20 version
OS: macOS 10.16
Version: 0.20.27319 (Git)
Python version: 3.9.10
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
And the result is
I try to find it out and got some questions.
Both code examples occurs after pressing a button in the toolbar.
What is the difference between the following two code lines?
Starts a macro or code?
tube = FreeCAD.ActiveDocument.addObject("Part::Tube", "myTube")
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
And the result is
TypeError: 'Part::Tube' is not a document object type
Gui.runCommand('Part_Tube',0)
App.ActiveDocument.addObject("Part::Cone","Cone")
The first starts a GUI command and cannot be used in a macro.
Looking at CommandShapes.py this is how you can add a tube:
from BasicShapes import Shapes
from BasicShapes import ViewProviderShapes
tube = FreeCAD.ActiveDocument.addObject("Part::FeaturePython", "Tube")
Shapes.TubeFeature(tube)
ViewProviderShapes.ViewProviderTube(tube.ViewObject)
I have updated Part_Box#Properties to how it should look.C4e wrote: ↑Sun Feb 06, 2022 1:33 pm Is the Properties section of the Part Box wiki page a good example?
Nice!
Thanks for the hint to the CommandShapes.py. I should take a look into it. The meaning of GUI command and the difference will become now clear.
I will add the script into the wiki.
Thanks. I will come back to it later.
