under Special:LanguageStats
david69
Post by david69 »
https://wiki.freecadweb.org/Special:LanguageStats
if you choose for the language code "en" then you have 2 pages. how do we explain that?
here is what I see:
Capture du 2022-01-22 18-35-44.png (25.12 KiB) Viewed 1315 times
Re: under Special:LanguageStats
The /en version has additional stuff in the links at the bottom:
https://wiki.freecadweb.org/Import_Export_Preferences
Bildschirmfoto 2022-01-22 um 19.42.37.png (26.2 KiB) Viewed 1293 times
https://wiki.freecadweb.org/Import_Expo ... erences/en
Bildschirmfoto 2022-01-22 um 19.42.15.png (27.38 KiB) Viewed 1293 times
Roy_043
Post by Roy_043 »
After a 'dummy' edit the issue seems to be fixed.
david69
Post by david69 »
confirmed, thank you.
