wiki Main page - sidebar
david69
Post by david69 »
how do we reach the left side of the Main_Page?
I want to modify it.
Capture du 2021-12-19 13-37-44.png (51.54 KiB) Viewed 6686 times
I think I have seen a post about it but can not find it. I don't know the name of this part.
edit: change title by "sidebar"
kaktus
Re: wiki Main page - left side
Post by kaktus »
Sidebar
Only the site administrator can modify this section :?
So the problem is not just you.
edit:
https://wiki.freecadweb.org/Localisation_Sidebar
this page does not solve the problem
david69
Post by david69 »
Sidebar, need to remember.
Thank you Kaktus for sharing the info.
If an admin is around, he can pm me and I'll share new text.
kaktus
Post by kaktus »
At one time Renatorivo was helping me with this.
Since he is not present nothing can be done about it, Yorik has no time. :roll:
https://wiki.freecadweb.org/index.php?t ... on=history
yorik
Post by yorik »
Sorry all, missed this topic...
Basically indeed the Localisation_Sidebar page seems outdated. As far as I can see:
- the sidebar at [wiki]MediaWiki:Sidebar[/wiki] seems correctly formatted. All items are inside an {{int:}} template.
- For each sidebar item, we have a https://wiki.freecadweb.org/MediaWiki:<sidebar-item> so for example, to translate the item "Workbenches", in Localisation_Sidebar we see that the item is sidebar-workbenches. So the corresponding page is https://wiki.freecadweb.org/index.php?t ... orkbenches . So far so good.
- By https://forum.freecadweb.org/viewtopic. ... =10#p80441 the page https://wiki.freecadweb.org/MediaWiki:Sidebar-messages needs to be updated with all the items in the sidebar. Indeed sidebar-workbenches is missing there. As a test, I just added sidebar-workbenches at the bottom now.
- Now is the problem, we should now go to http://www.freecadweb.org/wiki/index.ph ... ki-sidebar and normally we should be able to translate our new item, but I don't see anything?
david69
Post by david69 »
I came to the same page that you are pointing at the end your answer but I see all translations awaiting for update or to be made...not the sidebar. it's like a dead end or mis-routing (can I say that?).
yorik
Post by yorik »
Yes... But some former items have been successfully translated already. This is weird. Most probably something has changed in recent mediawiki versions and the https://www.mediawiki.org/wiki/Help:Ext ... r_tutorial tutorial doesn't work anymore...
We need to find updated info, but I'm googling now and find nothing :/
Roy_043
Re: wiki Main page - sidebar
Post by Roy_043 »
yorik
Post by yorik »
Aah interesting...
That means, for example, https://wiki.freecadweb.org/index.php?t ... benches/fr must be created manually... Let's try!
david69
Post by david69 »
does it mean admins must manually create a page for each language and they need to receive a translation from a user for that page?
