Translations for the FC interface
johanthomas12
Re: Translations for the FC interface
Post by johanthomas12 »
Is it different on Linux?
johanthomas12 wrote: Wed Mar 10, 2021 4:31 pm Is it different on Linux?
It shouldn't be.
johanthomas12
ook thanks
Continuing to work on this. Need to see what's left. Did i make a checklist for this?
kaktus
Post by kaktus »
This is good information. :mrgreen:
In the latest string import for translation, I saw several items from my list.
However, there is still no way to test the quality of the translations.
Changes in the translations are not included in the new (test) FC releases.
Kunda1 wrote: Fri May 21, 2021 12:34 pm Did i make a checklist for this?
I don't know anything about that.
My screens are still available. ;)
kaktus wrote: Fri May 21, 2021 12:50 pm This is good information. :mrgreen:
Can you use the latest FC dev version to check translations from now on? It's the most accurate.
For example, I see the strings available in crowdin for https://imgur.com/ds0ghBL
edit:
https://crowdin.com/translate/freecad/7 ... =2#6589286
https://crowdin.com/translate/freecad/7 ... =2#6589298
edit2:
2 pending PRs to fix some translation + add tooltip
https://github.com/FreeCAD/FreeCAD/pull/4804
https://github.com/FreeCAD/FreeCAD/pull/4805
kaktus
Post by kaktus »
I hawe:
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Version: 0.20.24847 (Git) AppImage
Hash: 20e756306d9aa624fcbf465f0345d721673ce720
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: Polish/Poland (pl_PL)
there is also a newer ... I'm already downloading it
kaktus
Post by kaktus »
okay, okay :D
but in the program there is still no way to verify the new changes. :roll:
The examples you posted were edited by the Polish translation team.
We look forward to implementing the new translations.
IIRC there is a way to bypass default translations by installing them in your FreeCAD config directory.
I need to confirm this but it may have been moving the .ts file (which you can download from crowdin yourself) and moving it in to .~/FreeCAD/translations/ (on Linux) and then restarting FreeCAD. But I'm not sure is that is 100% correct
