[Solved] Space after VersionMinus template?
Discussions about the wiki documentation of FreeCAD and its translation.
Roy_043
Post by Roy_043 »
The VersionMinus template ({{VersionMinus|0.18}}) ends in a space (padding/margin). The Version template ({{Version|0.19}}) does not have this. The extra space looks ugly when VersionMinus is included in a sentence.
Reason: Changed to [SOLVED]
Re: Space after VersionMinus template?
Roy_043 wrote: Sun Feb 23, 2020 6:21 pm The VersionMinus template ({{VersionMinus|0.18}}) ends in a space (padding/margin). The Version template ({{Version|0.19}}) does not have this. The extra space looks ugly when VersionMinus is included in a sentence.
Yea, I noticed this before and it is distracting.
I've removed the padding for both {{VersionMinus}} & {{VersionPlus}}
Roy_043
Post by Roy_043 »
Thank you.
david69
Re: [Solved] Space after VersionMinus template?
Post by david69 »
back on this topic, it seems we have again the extra space at the end.
on this translation, we have a space at the end of VersionMinus but not in English
https://wiki.freecadweb.org/Draft_Snap_ ... #Remarques
if I look at the translation of the template, I don't see the space
https://wiki.freecadweb.org/index.php?t ... ction=edit
Roy_043
Post by Roy_043 »
Should be fixed now.
david69
Post by david69 »
yes, thank you Roy_043.
where was the issue?
Roy_043
Post by Roy_043 »
The fr version of the template still had padding.
david69
Post by david69 »
the padding, now I see with your changes.
I didn't catch the info in the thread.
edit: and I see you have modified in the same way the other similar templates. Thanks a lot.
