"PyCXX: Error" when completing FeaturePyton Objects-tutorial
brambo90
Post by brambo90 »
Dear
This isn't really a bug, but it isn't really clear where to report 'mistakes' coming from the Wiki.
So I followed this tutorial: https://www.freecadweb.org/wiki/Creatin ... x,_Part_II
and I get an error in FreeCAD: "<unknown exception traceback><class 'TypeError'>: PyCXX: Error creating object of type class Py::SeqBase<class Py::Object> from None"
When reading this thread: https://forum.freecadweb.org/viewtopic.php?t=12966
I changed this part of the code (as presented on the wiki tutorial):
   def getDisplayModes(self,obj):
       Return a list of display modes.
       return None
to this :
       return [color=#FF0000][][/color]
and the error vanished. Probably this is something that slipped through with the newer releases, no biggie. Could someone correct the wiki?
Cheers!
Re: "PyCXX: Error" when completing FeaturePyton Objects-tutorial
Thanks for reporting, I moved it to the Wiki forum.
If someone can confirm, I can change the wiki.
Aleks
Post by Aleks »
This issue is still present. I just followed this tutorial. The tutorial is good in general, but I dont understand the meaning of this error message.
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
Roy_043
Post by Roy_043 »
You need to give more details. With the full code (at the bottom of the page) I do not experience issues with:
from fpo.box import box
mybox = box.create('my_box')
Aleks
Post by Aleks »
This is the error I get:
15:58:38  Traceback (most recent call last):
  File "C:/Users/Aleksander/AppData/Roaming/FreeCAD/Macro\fpo\box\box.py", line 90, in onChanged
    App.Console.PrintMessage("Change property: " + str(prop) + "\n")
This is the code to execute the code:
mybox = box.create('mybox')
This is the class and the object creation code:
import FreeCAD as App
import Part
def create(obj_name):
    Object creation method
    obj = App.ActiveDocument.addObject('Part::FeaturePython', obj_name)
    box(obj)
    ViewProviderBox(obj.ViewObject)
    return obj
class box():
    def __init__(self, obj):
        Default constructor
        self.Type = 'box'
        obj.Proxy = self
        obj.addProperty('App::PropertyString', 'Description', 'Base', 'Box description').Description = ""
        obj.addProperty('App::PropertyLength', 'Length', 'Dimensions', 'Box length').Length = 10.0
        obj.addProperty('App::PropertyLength', 'Width', 'Dimensions', 'Box width').Width = '10 mm'
        obj.addProperty('App::PropertyLength', 'Height', 'Dimensions', 'Box height').Height = '1 cm'
    def execute(self, obj):
        Called on document recompute
        obj.Shape = Part.makeBox(obj.Length, obj.Width, obj.Height)
class ViewProviderBox:
        Set this object to the proxy object of the actual view provider
        obj.Proxy = self
    def attach(self, obj):
        Setup the scene sub-graph of the view provider, this method is mandatory
        return
    def updateData(self, fp, prop):
        If a property of the handled feature has changed we have the chance to handle this here
        return
        return []
    def getDefaultDisplayMode(self):
        Return the name of the default display mode. It must be defined in getDisplayModes.
        return "Flat Lines"
    def setDisplayMode(self,mode):
        Map the display mode defined in attach with those defined in getDisplayModes.
        Since they have the same names nothing needs to be done.
        This method is optional.
        return mode
    def onChanged(self, vp, prop):
        Print the name of the property that has changed
    def getIcon(self):
        Return the icon in XMP format which will appear in the tree view. This method is optional and if not defined a default icon is shown.
        return """
            /* XPM */
            static const char * ViewProviderBox_xpm[] = {
            "16 16 6 1",
            "    c None",
            ".   c #141010",
            "+   c #615BD2",
            "@   c #C39D55",
            "#   c #000000",
            "$   c #57C355",
    def __getstate__(self):
        Called during document saving.
        return None
    def __setstate__(self,state):
        Called during document restore.
        return None
    def claimChildren(self):
        Return a list of objects which will appear as children in the tree view.
        return None
Roy_043
Post by Roy_043 »
The claimChildren method causes the issue. It was added later to one of the steps, but not to the "Complete code" paragraph. It should not return None. You can remove it, or change it to:
        return []
Aleks
Post by Aleks »
Thank you!
Changing the claimChildren method got rid of the error.
New method:
    return []
