statuts of Techdraw API pages
Discussions about the wiki documentation of FreeCAD and its translation.
david69
Re: statuts of Techdraw API pages
Post by david69 »
fixed thank you Roy.
pretty weird because it is not proposed under https://wiki.freecadweb.org/Special:LanguageStats with fr selected.
but as soon as I came to the section you pointed, the wiki suggested me there was an awaiting update.
that's the case for all the Techdraw modified pages.
FBXL5
Post by FBXL5 »
david69 wrote: Sat Nov 19, 2022 1:11 pm @FBXL5 where did you receive the info?
I got an e-mail. There are two check boxes beneath the coment line. The first marks minor edits and the second is for receiving mails whenever the page is updated (Diese Seite beobachten, in German). The second one is checked by default when I use the editor for original pages. I wouldn't uncheck it, because it is nice to know when Fuzzybot or Roy has finished and I can update the translation.
david69
Post by david69 »
sorry, FBXL5, you are refering to what?
FBXL5 wrote: Sat Nov 19, 2022 9:17 pm There are two check boxes beneath the coment line.
is your profile under the wiki?
FBXL5
Post by FBXL5 »
I was refering to the wiki editor:
david69 wrote: Mon Nov 21, 2022 9:46 pm is your profile under the wiki?
:?: If you mean that I use FBXL5 for wiki edits as well, then yes.
david69
Post by david69 »
it took me some times to find where are these options: it is when you want to follow a page.
I never do that so normal I didn't receive any notice.
FBXL5
Post by FBXL5 »
david69 wrote: Tue Nov 22, 2022 9:59 pm it took me some times to find where are these options: it is when you want to follow a page.
Sorry, but I didn't find where to switch to English. :roll: (I found out in the meantime...)
david69
Post by david69 »
don't worry, as long as I have found.
