[FC 0.21 31155 win-conda build - Assembly 3]: no solver found
Piero69
Post by Piero69 »
when running FC 0.21 31155 win-conda build i got the following warning for ASM3
07:56:04 3.790806 <asm3.main> init_gui.py(14): no solver backend found
@realthunder
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
Python 3.8.15, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Italian/Italy (it_IT)
  * 3DfindIT 1.2.0
  * A2plus 0.4.54b
  * Assembly3 0.11.4
  * Assembly4 0.11.8
  * Behave-Dark-Colors 0.1.1
  * BOLTSFC
  * CurvedShapes 1.0.4
  * Curves 0.6.4
  * dxf_library
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners
  * FCGear
  * freecad.gears 1.0.0
  * ImportNURBS
  * InventorLoader 1.3.0
  * InventorLoader.backup1663313199.3655012
  * invgears 0.1.2
  * lattice2
  * nurbs
  * Render 2022.1.0
  * sheetmetal 0.2.59
  * sheetmetal.backup1663313192.0420823
  * Silk -1137327656.0.0
  * symbols_library
Re: [FC 0.21 31155 win-conda build - Assembly 3]: no solver found
it is known that asm3 requires installation of the solvespace py_slvs python module, see instructions at https://github.com/realthunder/FreeCAD_ ... stallation
another probably better option is to open the addon manager, uninstall the WB and then install again, it should then offer you to install this dependency for you.
