Page 1 of 1
Assembly 4 Workbench issues
Posted: Fri Nov 18, 2022 7:05 pm
by WS222
Hi Gents,
finally I decide to use Assembly Workbench 4 to check my parts before I order lasercut.
Beginning was promising until a modification in one of the parts (center frame side) and now all parts become invisible.
- Unbenannt.JPG (128.43 KiB) Viewed 1037 times
Project can be found here:
https://www.dropbox.com/scl/fo/mc724wqb ... 0ib0cqvsyp
Thanks in advance
Winfried
System: Win10
Assembly4: v0.12.4
Re: Assembly 4 Workbench issues
Posted: Fri Nov 18, 2022 8:56 pm
by ladis
Indeed. Is there anything to prevent you from using newer version? Your model seems to be fine in 0.20.1. Assembly4 workbench v0.12.4 used for both Freecad 0.19.1 and 0.20.1
Posted: Mon Nov 21, 2022 2:35 pm
by Zolko
WS222 wrote: ↑Fri Nov 18, 2022 7:05 pm
it's a 2.10m wingspan Horten. What aerodynamical design (airfoils, sweep and twist) do you use for it ?
- Horten.png (416.97 KiB) Viewed 905 times
It opens correctly in v0.21, but not with v0.19. More importantly, you have a circular reference somewhere (
Document::getDependentDocuments: The graph must be a DAG), and apparently v0.21 can handle it even though there is an error, while v0.19 can't. You should nook where this circular dependency comes from (Part A depending on Part B depending in Part C depending on Part A)
Also, you don't have to wrap each PartDesign Body (blue icon) into a Std_Part (yellow icon), you can – and should – use the PartDedign Bodies directly.
