Bug or I am just a noob?
thebruuu
Post by thebruuu »
Hello
This occurs in A2plus, using python on selected part and constraints.
So First.
I have a group containing 3 imported Parts.
Those parts have constraints between themselves
I select all the parts and constraints in the group, as per picture
Image 002.png (22.75 KiB) Viewed 957 times
Then I create a copy of the selected elements (copy and paste od "Duplicate Selection" command in the Edit Menu)
Image 013.png (37.92 KiB) Viewed 957 times
The copied parts have wrong constraints : the constraints point to the original elements in the group Group
To try to have the constraint correcly repluged to the right parts I tried to run this code:
obj1=FreeCADGui.Selection.getSelection()[0]
obj2=FreeCADGui.Selection.getSelection()[1]
obj1.Object1=obj1.ParentTreeObject.Name
obj1.Object2=obj2.Name
where first I select the constraint and then I select the 2nd part it should refer to, as the first part is directly obtained from the object tree
Unfortunately this code does not work as expected:
Yes, i am able to replug the constraint correctly
BUT randomly, some of the original constraints are modified too
In the below example, I selected the constraint axisCoincident_001__tubo_MEDIO_Corrente_002 and the part tubo_MEDIO_Corrente_002
And as per picture, the constraint axisCoincident_001__tubo_BASSO_Corrente_001 has been modified too
Image 004.png (43.23 KiB) Viewed 957 times
Any explanation will be welcome, on why the code does not work
Thank You
Re: Bug or I am just a noob?
Don't crosspost in parallel to different subforums.
thebruuu
Post by thebruuu »
Hello
Sorry,
After having posted in the python forum, I got no answer... this is why i tried the coding forum.
Feel free to delete my post If you think it's not in the right place.
On my side I will stop cross posting of course
The developer forum was definitely the wrong place. I will move it to Assembly.
dan-miel
Post by dan-miel »
thebruuu wrote: Wed Sep 21, 2022 7:31 pm Any explanation will be welcome, on why the code does not work
Thank You
Just a fast observation: You have two constraints named axisCoincident_001.
Which one did you change, and which one is the solver reading?
Dan
