A2plus : Reusing parts and constraints
thebruuu
Post by thebruuu »
Hello
Let's suppose I need to build a car in A2plus. I am now in the phase of assembling the shock absorbers
STEP 1. Let's simplify and let's say that this shock absorber is simply a pipe made of 2 parts, 2 coaxial tubes with of course some constraints between those parts (axial & same plan constraints): in this way the 2 pipes can move and simulate the shock absorber movement
Now, I want to go for the second wheel and I want to reuse the shock absorber I built in step 1. So how can I clone it? I don't manage to clone parts and constraints. I am only able to clone parts...
I tried to create a asm file of the shock absorber but the point is that then If I import it into another assembly project, it gets static
As I am a rookie, I hope to have been clear enough
Thank You
Re: A2plus : Reusing parts and constraints
Moved from Help forum.
dan-miel
Post by dan-miel »
thebruuu wrote: Wed Sep 21, 2022 2:18 pm Now, I want to go for the second wheel and I want to reuse the shock absorber I built in step 1. So how can I clone it? I don't manage to clone parts and constraints. I am only able to clone parts...
You’re right on everything in you posted. I do not believe you can import an assembly and have the constraints work in it, you need to have the constraints in the top level. You cannot copy the constraints but you can copy the parts without opening the files again by using the "Create duplicate of a part” button.
I hope this helps.
Dan
