asm3 spamming report window when dragging a Part to Assy [SOLVED]
freman
Post by freman »
just came back to asm3 on master and dragging a Part into the Assembly object in comboview is spamming console and reportview with traceback errors.
It seems that every time the drap op passes over a target where it cannot drop , instead of just changing the cursor it is making a mess.
Someone may need to look at this.
Cheers.
  File "~/.FreeCAD/Mod/FreeCAD_assembly3/freecad/asm3/assembly.py", line 4605, in canDropObjectEx
    return partGroup.canDropObject(obj,owner,subname)
<class 'TypeError'>: argument 2 must be App.DocumentObject, not None
OS: Fedora Linux 35 (Thirty Five) (LXQt//usr/share/xsessions/lxqt)
Version: 0.21.30265 (Git)
Hash: c35244e74f326a04c5bcab31e984742db582ac78
Python 3.10.6, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.3, OCC 7.5.0
  * FreeCAD_Assembly4 0.11.10
  * FreeCAD_assembly3
[EDIT] solution was to update asm3 in ~/.FreeCAD/MOD to use asm3 master. This issue was fixed in March by RealThunder but apparently PRs to FreeCAD have not yet been applied.
Re: asm3 spamming report window when dragging a Part to Assy
freman wrote: Tue Sep 20, 2022 6:52 am ...
Probably posting in the dedicated thread you will receive more "focused answers".
https://forum.freecadweb.org/viewforum.php?f=44
EDIT: This affirmation is wrong, for asm3 related problem the right place to post question is HERE
freman
Post by freman »
Looks like my asm3 was about 6mo old. I've updated.
marioalexis
Post by marioalexis »
There are two pull request to fix this waiting to be merged in FreeCAD-0-20 and master, respectively
freman
Post by freman »
Thanks for the info. So where is the FreeCAD version of this ? I don't see it in the master tree. Does the addons manager pull it in from somewhere else but not the upto date asm3 master?
thx
Re: asm3 spamming report window when dragging a Part to Assy [SOLVED]
the addon manager pulls from asm3 source: https://github.com/realthunder/FreeCAD_assembly3
it is not integrated in master branch and it is not expected to be integrated due to license conflict
freman
Post by freman »
marioalexis wrote: Tue Sep 20, 2022 4:10 pm There are two pull request to fix this waiting to be merged in FreeCAD-0-20 and master, respectively
I don't understand this comment. If FreeCAD pulls in from assembly3 master, why does FC need a patch at all?
Can you provide a PR number or a link?
Thanks.
marioalexis
The error is due to a regression in the master branch.
This pull request fixes the error in FreeCAD-0.20: 7507.
And this in current master 7236
freman
Post by freman »
Thanks for rebasing, hopefully it will get merged this time. That affected a ton of files. Thanks for the effort.
