Assembly 4 strange behavior when creating binder from LCS
GeographySub
Post by GeographySub »
I want to use this subassembly in a larger project. So, i'm trying to duplicate the top LCS from the EyePiece components (the dark grey cylinders) under the ScopeHead root.
However, when I simply select either of the LCSes and use the assembly4 shape binder feature, I get a plane in the position shown, not where the LCS actualy is.
Further, when I then create a LCS on this new location it appears at a different, also wrong location, as shown below.
Why is this happening?
I have attached all files used in the project in the zip below...
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
  * Assembly4 0.11.10
  * CfdOF 1.9.5
  * Curves 0.3.0
  * fasteners
  * parts_library
  * Plot
  * Pyramids-and-Polyhedrons
  * Rocket
  * sheetmetal 0.2.49
NetEyePiece.zip
(816.73 KiB) Downloaded 33 times
Re: Assembly 4 strange behavior when creating binder from LCS
Moved from Help forum.
Zolko
Post by Zolko »
GeographySub wrote: Mon Sep 19, 2022 2:39 am However, when I simply select either of the LCSes and use the assembly4 shape binder feature
I don't think that a ShapeBinder on an LCS is the correct use of ShapeBinders. An LCS is a virtual object that doesn't really have a "shape"
