Assembly challenges
thomas-neemann
Assembly challenges
Post by thomas-neemann »
parametric is not required. all possibilities of freecad and freecad addons can be used. here is my suggestion in about 4 minutes (out of the box)
the center distance is 478.74 mm
https://www.youtube.com/watch?v=szA6GLk_MuE
phpBB [video]
base.step
(585.72 KiB) Downloaded 37 times
motor.FCStd
(978.91 KiB) Downloaded 36 times
scheibe-motor.step
(47.41 KiB) Downloaded 35 times
scheibe-kompressor.step
(800.65 KiB) Downloaded 33 times
Last edited by thomas-neemann on Thu Aug 11, 2022 3:49 pm, edited 1 time in total.
thomas-neemann
Re: Assembly challenge
I was able to assemble this in about 6 minutes with on-board resources. is it faster with addons or something else?
start11aug.FCStd
(275.87 KiB) Downloaded 33 times
teil4.FCStd
(84.19 KiB) Downloaded 32 times
https://www.youtube.com/watch?v=bBfam_m3bP8
phpBB [video]
manos
Re: Assembly challenges
Post by manos »
Hello
thomas-neemann wrote: Thu Aug 11, 2022 3:45 pm I was able to assemble this in about 6 minutes with on-board resources. ...
start11aug.FCStd
Is it possible to fix the parts of start11Aug together, so it will be impossible to move them relative to each other, with transform or attachment or placement ?
Something with link maybe ?
Thanks for your post.
thomas-neemann
manos wrote: Mon Aug 29, 2022 7:56 am ...
I would do that
1010.FCStd
(672.63 KiB) Downloaded 30 times
manos
Post by manos »
thomas-neemann wrote: Mon Aug 29, 2022 8:11 am
I would do that
Thomas thanks for your prompt response but still I can move the Compound001 relatively to Compound just using the transform tool.
I am looking for a way to make them fixed to each other even if using transform, Placement, Attachment. I think it is called Assembly constraint.
Maybe the MakeLink could help ?
Zolko
Post by Zolko »
thomas-neemann wrote: Mon Aug 29, 2022 8:11 am I would do that
But would that be parametric, as in: "FreeCAD, your own 3D parametric modeler " ? To be honest, I think you're giving FreeCAD a disservice by promoting your way of doing "assemblies". You're method is fast only because you're not really doing a parametric assembly, but you always "forget" to mention this aspect.
thomas-neemann
Zolko wrote: Mon Aug 29, 2022 9:52 am ...
I will make sure to always mention it in the future. in my environment, speed is more important than parametric
edit
manos
Post by manos »
But would that be parametric, ...
I am not intended to do parametric modelling at least at present. I am just looking for a way to "FIX" together two points which belong to two different bodies. E.g. a vertex from a cube and one vertex from a prism. For example how can I fix 'Body.Prism.Vertex2' with ''Body001.Box.Vertex2'.Fixing means that Tranforming, Placement, Attachment will not separate those two points. Of course the two bodies will be free to rotate but the rotation axis must pass throu those two points.
Fixing Points1.FCStd
(13.83 KiB) Downloaded 38 times
I am wandering if MakeLink could do this.
thomas-neemann wrote: Mon Aug 29, 2022 10:09 am in my environment, speed is more important than parametric
I have heard this argument ever so often. And at the end of the day it was every single time more or even much more expensive to do things quick and dirty.
manos wrote: Mon Aug 29, 2022 10:21 am For example how can I fix 'Body.Prism.Vertex2' with ''Body001.Box.Vertex2'.Fixing means that Tranforming, Placement, Attachment will not separate those two points.
- Make a Union of the two
- create a SimpleCopy of the Union
- delete the Union and its constituents.
This will fix the two inseparable to each other.
