About "Elements" of "Assembly3" used in "XYZ_Plane", please help!
- xsuper9988
When I use "XY_Plane, XZ_Plane, YZ_Plane" in "Elements"
"Assembly3" seems to be all identified as "XY_Plane"?
- ASM3_XYZ_PLANE.png (113.77 KiB) Viewed 1586 times
- ASM3_XYZ_PLANE.FCStd
- (21.1 KiB) Downloaded 37 times
Re: About "Elements" of "Assembly3" used in "XYZ_Plane", please help!
What are you trying to do?
It doesn't make sense to me...?
Can you, please explain better/in more detail
- xsuper9988
when i use XYZ_Plane when alignment condition
in some cases
It is more convenient to calculate the distance from the center to the center
Picture 1 is
Body locked at (0,0,0)
Body001 at (100,100,100)
Picture 2 is
Body and Body001 use YZ_Plane as aligned Elements
After slove alignment
Body001 result should be (0,100,100)
But it's result...
Body001 at (100,100,0)
- ASM3_XYZ_PLANE001.png (146.05 KiB) Viewed 1567 times
- ASM3_XYZ_PLANE002.png (135.3 KiB) Viewed 1567 times
Why do you need or want to use body origin planes as elements???
- xsuper9988
In asymmetric Parts
Sometimes you need to use the center to align
Or use the center to calculate the relative distance
is more convenient
Anyway, XZ_Plane, YZ_Plane result is equivalent to XY_Plane
This should be a bug, right?
You are doing it all wrong I am afraid
and, no there is no bug...
Explain to me what is the end result meant to be,
and I will modify your file.
- xsuper9988
I edited my last reply to make it more detailed
Picture 1 is
Picture 2 is
But it's result...
PS:
Picture011 is
Use XY_Plane to align results
Picture012 is
Use "_Element" and "_Element001" to align results
I think under this sample
Align with XY_Plane
The result should be the same as Picture012,right?
- ASM3_XYZ_PLANE011.png (112.95 KiB) Viewed 1425 times
- ASM3_XYZ_PLANE012.png (123.55 KiB) Viewed 1425 times
- (27.3 KiB) Downloaded 26 times
- ASM3_XYZ_PLANE1.FCStd
- (28.63 KiB) Downloaded 27 times
with some of my comments in red, below
I suggest you do a (lot of) reading on this excellent page:
http://help-freecad-jpg87.fr/02_ass_ind.php
I am running out of time to help you (about to depart on a trip where I will not have access to FreeCAD), sorryxsuper9988 wrote: ↑Tue May 03, 2022 2:12 pm I edited my last reply to make it more detailed
Picture 1 is
Body locked at (0,0,0) - locked constraint does not lock assembly part in a "postion" it locks it in relation to other parts of assembly
Body001 at (100,100,100) - doesn't matter where this part is, if the only constraint you use is PlaneAlignment, it can still be moved...
Picture 2 is
After solve? alignment - there are still three degrees of freedom left....
Body001 result should be (0,100,100) - see above
But it's result...
Body001 at (100,100,0) - try using assembly mover and you will see that this is not true
- xsuper9988
"three degrees of freedom" is not important
if you care
I upload these two samples
Can you tell me why using XY_Plane is wrong?
X distance 0mm
Y distance -100mm
Z distance -100mm
Shouldn't the results for the two samples be the same?
- ASM3_XYZ_PLANE020.png (141.04 KiB) Viewed 1396 times
- ASM3_XYZ_PLANE021.png (174.66 KiB) Viewed 1396 times
- ASM3_XYZ_PLANE20.FCStd
- (32.35 KiB) Downloaded 25 times
- ASM3_XYZ_PLANE21.FCStd
- (35.08 KiB) Downloaded 26 times
- xsuper9988
The point I am confused about is
Why are all XYZ_PLANE displayed on XY_PLANE?
- XY_PLANE.png (141.59 KiB) Viewed 1394 times
- XZ_PLANE.png (140.6 KiB) Viewed 1394 times
- YZ_PLANE.png (140.25 KiB) Viewed 1394 times
