Challenge assembling 2 step Parts.
- thomas-neemann
I don't know how I can bring this ball into its position on the plane shown.
I see this as a challenge of the different assembly workbenches or other functions of freecad, additional wbs or macros...
what works, of course, is manual draft move, but that's not sufficient for such a high-precision part
it is also easier to remodel the sphere in the desired position. but then it's no longer a challenge.
Re: Challenge assembling 2 step Parts.
WPProxy
What is? (and how was it created?)
- thomas-neemann
this is how i created it. it is the level in which the balls lie. the position of the draft working plane is probably not saved in fcstd
Thank you,
no wonder I didn't know what it is... I lead a simple life without draft workbench
One more question/comment, please.
Clearly assembling a single ball is not the whole story?
We are talking (looking at your second picture in particular) about a number of caged balls,
all of them in a single plane, that should be assembled as a sub-assembly,
with an angle of this plane as a dynamic value depending on the deflection of the joint?
- thomas-neemann
if all the balls can be positioned at the same time with a parametric angle of the joint, that would of course be optimal. but that's probably too much work for here
Can you provide the Inner Race without geometry errors?
It's not a question of "too much work" (and probably it isn't ?)
just that the approach and solution would be different...
- thomas-neemann
here is the source. there are also iges variants contained. it might be more useful
https://grabcad.com/library/rzeppa-joint-2
- thomas-neemann
we could make a part A and a part B out of it
