Hi everyone,
I am an engineer using FreeCAD in our workplace. I design the parts and complete the assembly in A2Plus. But whenever i try to put fractional distance between two parts the ''Constraint Properties Window'' doesn't allow me to insert a fractional number. It only allows to insert exact numbers. For an example if i text +3 mm or -3 mm there will be not any problem. But if i text -3.2 mm or +3.2 mm the number after the point doesnt appear on the text line. If i text -3,2 or +3,2 this time the fractional numbers appear on the line but when i click the accept button, the part goes -32 or +32 mm, not -3.2 or +3.2. Is there any solution that may help to fix the problem. I think may be i should use the Part tool to add the relations with paramatrical methods. But i dont know how to use Part tool and i dont like to get simple things that complicated. Is there anybody can help me about the issue, please ? Wish you all the best and thank you so much for your attention.
Best Regards.
C.Ornek.
FreeCAD Offset Fail In A2Plus
Re: FreeCAD Offset Fail In A2Plus
Moved from Help forum.
You should add your full FreeCAD infos and the version number of A2Plus.
CC @dan-miel (do you mind taking a look at this?dan-miel wrote: pinged by pinger macro
Hi Ceemberk,
I think I see what you are seeing. If I enter a number to the left of the decimal point the text box shows it, but to get a number to show to the right I have to put the cursor in the text, delete some digits and then type the fractional.
Is this what is happening?
Dan Miel
