Can't rotate body in Assembly
Re: Can't rotate body in Assembly
03 https://1drv.ms/u/s!ArMxdUYEh9fKwCq_BdW ... i?e=2xmaaO
01 https://1drv.ms/u/s!ArMxdUYEh9fKwCstEwm ... u?e=EN8ums
Sorry about all the run-around
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
- thomas-neemann
now I'm getting one step further, but I get these messages when I refresh
08:36:39 Line Group File: /tmp/.mount_28751-emNeB3/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv is not readable
08:37:09 Sketcher constraint number 1 is malformed!
08:37:09 Sketcher constraint number 2 is malformed!
08:37:09 Sketch Sketch024 has malformed constraints!
08:37:09 Recompute failed! Please check report view.
I have an idea of what might have mucked things up. I'll have a good look at it in the morning.
I'll let you know.
Thanks for your patience.
I'll let you know.
Joseph Kimble
Joseph Kimble
You messed it up. The numbered extensions are backup files created on every saving. So you somehow have deleted your FreeCAD file and now you have reset it to a previously saved state.
Doesn't appear so at this end
- 220426 PR Files.png (124.82 KiB) Viewed 1021 times
Joseph Kimble
Joseph Kimble
What do you mean? *.FCStd1 files are no backup files on your system?
No. I meant that I had not deleted my *.FCStd files.
Joseph Kimble
Joseph Kimble
I wish you thread title specified which assembly workbench you are talking about....
I listed it in the Original Past just after the FC version details.
Joseph Kimble
Joseph Kimble
no, I mean thread title
eg
Assembly 4, Can't rotate body (not Can't rotate body in Assembly)
See how (almost) everybody else is doing it
With this sub-forum serving three different assembly workbenches, it makes it easier to attract right kind of help....
