Wire is not closed (file attached)
exsolvespacer
Post by exsolvespacer »
I am trying to do a revolution but it keeps saying "Wire is not closed". I have deleted all constraints and made sure that the end points are all coincident but no joy. Anyone know what is going on here? Looks like a bug to me. Thanks.
Problem.FCStd
(26.67 KiB) Downloaded 24 times
Version: 2021.1015.24301 +3962 (Git) AppImage
Branch: LinkStage3
Hash: c6cb39697eb439caf7e5bd0208ca3082a7820547
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
totalcad
Re: Wire is not closed (file attached)
Post by totalcad »
Hi! May be my test can help in some kind of...
I use official version FC 0.19, Ubuntu 20.04 and revolution works well with your file:
(There's some warning in the report view - but I'm not a programmer, so I don't understand - does it have any relation to your file or not)
user1234
Post by user1234 »
two lines overlap
Greetings
user1234
exsolvespacer
user1234 wrote: Wed Jan 26, 2022 6:19 pm two lines overlapoverlap.png
Greetings
user1234
You're right! Thanks. I will have to improve my mouse-hovering skills over those unresizable dialogs. And thanks again.
totalcad
Post by totalcad »
Greetings
user1234
Strange: I've deleted one constraint and pushed apart a sketch - I've got no any problem. I've got: one line of "external geometry" (violet color), one line of "help-construction mode" (light blue color) & other geometry (dark blue color) - there's no overlap///in my case.
GeneFC
Post by GeneFC »
Look at the bottom of the Sketcher Task Panel, at the Elements section. Edge8 and Edge9 are identical and overlap.
You can hover over the elements to see them light up.
Gene
totalcad
Post by totalcad »
GeneFC wrote: Wed Jan 26, 2022 7:16 pm Look at the bottom of the Sketcher Task Panel, at the Elements section. Edge8 and Edge9 are identical and overlap.
Gene
Thanks! You're right. But another interesting thing is coming: why the revolution works with the initial file in my case? (FC 0.19, Ubuntu 20.04) It must not work and give a warning.
