Major update from 0.16 to 0.19: Migrating problems
Made the big step to V0.19 and A2plus. Previous setting was V0.16 and assemblies produced with assembly2.
What I most feared happened: the migration of assemblies and parts is not going well (slight panic).
Reinstalling V0.16 in combination with assembly2 no longer works. Assembly2 no longer accepts the previously produced constraints and creating new constraints no longer works (greater panic). So V0.19 is, as I see it, the only way to go.
So I tried this (after reading a lot of information):
A2plus migration
1. Migrate in A2plus + save + reload: parts are converted, constraints are unchanged;
2. Repair treeview: constraints are now 'inside' the parts, but still 'grey';
3. Activate Constraint + 'Highlight both constrained parts': the surfaces are displayed (apparently there is a link);
4. Change constraint data (eg 'offset') + click 'Solve constraints': does nothing;
Conclusion: migrating fails, so I have to create all constraints again from scratch?
Migration part
5. From A2plus 'Edit an imported part': part is opened (part was created with V0.16);
6. 'Migrate': part is changed in such a way that positions in the physical drawing change and the migration therefore fails;
Conclusion: make part again?
General conclusion possibilities
a. My work can still be opened, but migration fails completely in my case (panic everywhere);
b. There is no reason to panic. I'm not doing it the right way;
I really do need help with this. What is the best method?
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Dutch/Belgium (nl_BE)
A2plus migration
Migration part
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Re: Major update from 0.16 to 0.19: Migrating problems
And it is getting worse...
Opening a part from A2plus... Then migrate the part, adapt it (making a hole in or something like that). And saved it (different name). Then back to A2plus.
Then in property >> source file >> adapted path and name to the new filename of the part.
Then 'update parts' >> Nothing happens. I get the follow message in Report view:
Then 'update parts' with lightning bolt through it >> Nothing happens. I get the follow message in Report view:
The 2nd Report view-dump... Could it be that special characters are not allowed? (....Z:\\R&D\\Engineering....)
Running the Python command 'a2p_updateImportedParts' failed:
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\A2plus\a2p_importpart.py", line 919, in Activated
updateImportedParts(doc)
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\A2plus\a2p_importpart.py", line 861, in updateImportedParts
importPartFromFile(
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\A2plus\a2p_importpart.py", line 341, in importPartFromFile
relativePath = prefix+os.path.relpath(absPath, assemblyPath)
File "C:\Program Files\FreeCAD 0.19\bin\lib\ntpath.py", line 703, in relpath
raise ValueError("path is on mount %r, start on mount %r" % (
path is on mount 'C:', start on mount '\\\\someserver\\bedrijfsbestanden'
createUpdateFileList importPath = //someserver/bedrijfsbestanden/R&D/Engineering/FreeCAD/FreeCAD_Tekeningen/Beugels/Beugel_verkoopmodellen/Beugel_verkoopmodel_YawPitchRoll/019SAM_Beugel_verkoopmodel_YPR_Boutverbinding3a.FCStd
13:30:10 Running the Python command 'a2p_recursiveUpdateImportedPartsCommand' failed:
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\A2plus\a2p_recursiveUpdatePlanner.py", line 150, in Activated
subAsmNeedsUpdate, filesToUpdate = createUpdateFileList(
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\A2plus\a2p_recursiveUpdatePlanner.py", line 91, in createUpdateFileList
mtime = os.path.getmtime(objFileNameInProject)
File "C:\Program Files\FreeCAD 0.19\bin\lib\genericpath.py", line 55, in getmtime
return os.stat(filename).st_mtime
[WinError 3] Het systeem kan het opgegeven pad niet vinden: 'Z:\\R&D\\Engineering\\FreeCAD\\FreeCAD_Tekeningen\\Beugels\\Beugel_verkoopmodellen\\Beugel_verkoopmodel_YawPitchRoll\\SAM_Beugel_verkoopmodel_YPR_Voet_boutverbinding3a.FCStd'
There are indeed some issues fixed. You can try to switch to the English version meanwhile - or use 0.20.
From the english error message, maybe there are some problem with some path.
Probably the os is not returning correct path or, most probably there are some error in path name, or in some access library to the path, in 0.19.
Take in account that Python has evolved so maybe what is correct for 0.16 maybe is deprecated or not supported in 0.19 due to Python management of Path between versions, FreeCAD 0.16 use a version and FreeCAD 0.19 for sure use a more recent version of the python interpreter..
Or simply could be that some file that was referenced in the FreeCAD file is not accessible for the user due to some user permissions or directory permissions, or even the file is not here anymore.
see:
https://stackoverflow.com/questions/404 ... grations-i
Sadly the other error message is in a language that I don't know, I coudl guess that is referencing some file, but this part:
resemble a problem with character set or unicode as it is translating the & with his HTML equivalent &, this could be related to some change in the OS default character encoding, and some Python notes warn about this behaviour, in path.
see:
For such a big jump in versions it is probably best to restart with a plain vanilla config; see https://wiki.freecadweb.org/Frequently_ ... rt_anymore .
onekk wrote: ↑Wed Jan 19, 2022 4:51 pm ...
resemble a problem with character set or unicode as it is translating the & with his HTML equivalent &, this could be related to some change in the OS default character encoding, and some Python notes warn about this behaviour, in path.Code: Select all
Translation (from Dutch): "[WinError 3] The system cannot find the specified path:"
The thing is that when I try to open a part from an assembly using the 'Edit an imported part'-button the specific part opens. No problem.
But when the part is saved and I want to update the part in the assembly with the 'Update parts'-button, nothing happens and I get the Report View message. Weird...
Maybe I even have a bigger problem now: all my work is inside this path.... Z:\R&D\Engineering\FreeCAD\FreeCAD_Tekeningen\etc...
I actually use the English version, it's easier if you want to find and compare information on the internet (which is 99% in English language).
Erm... From 0.19 to 0.20... Again migrating 'thingies' or....?
I tried this already. Also I made a backup of the older config, expecting everything would be 'normal' again if anything went wrong. Assembly2 became completely inoperable whatever I tried, so I am now stuck with V0.19 or higher.chrisb wrote: ↑Wed Jan 19, 2022 6:13 pm For such a big jump in versions it is probably best to restart with a plain vanilla config; see https://wiki.freecadweb.org/Frequently_ ... rt_anymore .
I must say: FreeCAD V0.19 and A2plus software works perfect. Big compliments for all hard work, no doubt. It is definately impressive that this is possible in an opensource environment. But migrating is apparently not a click-and-done process...
I wrote this in the fipo:
Check #3: this gives me the feeling of 'being almost there' having the perfect migration of assembly2 to (kbwbe's brilliant) A2plus...A2plus migration
Still fighting with migrating A2Plus or Part Design.
99% fails. I have no idea why. It is a time consuming monster.
Every time I try to import using A2Plus I get the "a2p_SketchReference.svg" icon in the combo view combined with the filename, but the actual file does not appear.
- Tried to import (using A2Plus) the file attached. "Slotbout M10x80" is the original V0.16 file. Failed
- Migrated the file. Then tried to import . Failed
- Closed and opened the A2Plus file. Import failed
- Closed and opened FreeCAD. (works sometimes for whatever reason...) Import failed
- Restarted PC. Import failed
- Created the whole file completely new again ("019_Slotbout M10x80"). Import failed.
- Started a brandnew file, started A2Plus. Import worked!!!
- Saved the "019_IMPRESSION_Viaduct constructie1.FCStd" under a new name "019_IMPRESSION_Viaduct constructie2.FCStd". Import failed.
This happens so much.... Pffffff
Files inside the attachements
Report view (changed personal thingies in 'jadajada')
14:46:45 Running the Python command 'a2p_ImportPart' failed:
File "C:\Users\jadajada\AppData\Roaming\FreeCAD\Mod\A2plus\a2p_importpart.py", line 732, in Activated
importedObject = importPartFromFile(doc, filename)
File "C:\Users\jadajada\AppData\Roaming\FreeCAD\Mod\A2plus\a2p_importpart.py", line 341, in importPartFromFile
path is on mount '\\\\jadajadaserver\\jadajadabestanden', start on mount 'Z:'
- 019_IMPRESSION_Viaduct constructie2.FCStd
- (116.8 KiB) Downloaded 22 times
- a2p_SketchReference.svg
- (8.65 KiB) Downloaded 21 times
- 019_Slotbout M10x80.FCStd
- (36.15 KiB) Downloaded 21 times
- Slotbout M10x80.FCStd
- (21.67 KiB) Downloaded 21 times
