Problem with linear assemble of identical bodies
Vagulus
Re: Problem with linear assemble of identical bodies
Post by Vagulus »
I have had a play with a totally different part and that worked just fine! :D
It seems likely that the bogus property is the cause of the problem but I don't know what it is, how I came to set it or how to unset it. I am reluctant to start re-creating the body unless I know all those things - I'd most likely just do it again! :oops:
I'll really appreciate your help here.
"It is much harder to simplify than to complicate."
Joseph Kimble
jonasb
Post by jonasb »
Zolko wrote: Mon Jan 17, 2022 9:20 am ... the Body you're using has the AttacherExtension property set (MapMode) which introduces its own AttachmentOffset which interfers with Asm4's AttachmentOffset (this was the bug introduced in 0.11.5).
How did you get that property set ? The other Bodies in the file don't have it.
Just use Part's Edit Attachment. (No idea how get rid of it again, though)
Maybe somewhat related is this thread: PartDesign, why is there no Attachment Offset in the Body?.
Vagulus
Post by Vagulus »
jonasb wrote: Mon Jan 17, 2022 7:50 pm Just use Part's Edit Attachment. (No idea how get rid of it again, though)
Hmmm! :roll: Some study to do.
Thanks
Joseph Kimble
Vagulus
Post by Vagulus »
You have me totally confused!
(1) Your image clearly shows Property View --> Attachment --> Map Mode as 'Deactivated'. How then can it be set?
(2) My FC version
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
has a different Property View from yours (this image refers to the body in question)
220118 Property View.png (79.57 KiB) Viewed 1563 times
I had a look at the Wiki [wiki]https://wiki.freecadweb.org/Property_editor[/wiki] and I can't find anything in my settings which would cause a problem.
(3) A search if the Wiki [wiki]https://wiki.freecadweb.org/Part_Part2DObject/en[/wiki] for anything related to 'Attachment Offset' gives me neither joy nor even satisfaction. This tells ME nothing,
DataAttachment Offset (Placement): the position of the object in the 3D view, with respect to the attachment object's placement. The placement is defined by a Base point (vector), and a Rotation (axis and angle).
(3) I cannot find any explanation of your phrase, '... the Body you're using has the AttacherExtension property set ...'.
Joseph Kimble
kisolre
Post by kisolre »
Vagulus wrote: Tue Jan 18, 2022 1:49 am different Property View from yours
It is in the Data tab of the properties - look under them, now you are in the View tab.
Vagulus wrote: Tue Jan 18, 2022 1:49 am shows Property View --> Attachment --> Map Mode as 'Deactivated'. How then can it be set?
In that Data tab.
Vagulus
Post by Vagulus »
kisolre wrote: Tue Jan 18, 2022 6:59 am In that Data tab.
In the Data Tab Map Mode is Deactivated.
220118 Attachment.png (65.01 KiB) Viewed 1504 times
The Attachment Dialog shows an Offset of -70 in the X direction (Yes, I have modified my Document.)
but that is greyed out, inactive, unattached. To my way of thinking it should have no effect.
Joseph Kimble
Zolko
Post by Zolko »
Vagulus wrote: Tue Jan 18, 2022 7:59 am In the Data Tab Map Mode is Deactivated.
but it's there. Look at the other Bodies in your file, MapMode isn't there at all.
Vagulus
Post by Vagulus »
Thanks, Zolko. That was it.
All is well -- see https://1drv.ms/v/s!ArMxdUYEh9fKwBk5vpN ... F?e=21PgVy
Joseph Kimble
