missing submenu
missing submenu
I've loaded the RealThunder version:
Version: 2022.111.28429 (Git)
Branch: LinkStage3
Hash: ec814c42d02f15171f9dbb7f650400c9943abfe0
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
and I'm missing the buttons that correspond to the keyboard shortcuts 1,2,3 etc, to alter the views of objects. Because the keyboard shortcuts work, I can manage but it's a bit worrying.
I've been searching for an answer/explanation but with no luck.
Branch: LinkStage3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- thomas-neemann
Re: missing submenu
steveKimpton wrote: ↑Fri Jan 14, 2022 5:55 pm
and I'm missing the buttons that correspond to the keyboard shortcuts 1,2,3 etc,..
it should be possible to display them again using customize tools
Re: missing submenu
Thanks for this Thomas,
I had found exactly the place you show but couldn't see the method by which I could transfer them into a toolbar. In fact, I can't really see the purpose of the panel. All I can see is "Help" (which doesn't work) and Close. Am I missing something obvious?
Re: missing submenu
Just toggle it on (view>toolbars>view):
Re: missing submenu
All my boxes are already ticked there and I have gone through unticking, restarting, reticking and so on. I've also clicked reset on the preferences panel all to no avail. However your suggestion has made me realise that I have got the view toolbar but it is missing the various options available with the keyboard shortcut. It does have the 'Fit all', 'Fit Selection', 'As is' and one other icon (not sure what it is). See screen shot.
Maybe I should mention that I get " 1.250861 <asm3.main> init_gui.py(14): no solver backend found" on startup but this seems to be something encountered by so many people that I don't think it can be related to this.
Re: missing submenu
no it is not related, but you shouldn't have this message.steveKimpton wrote: ↑Sat Jan 15, 2022 11:32 am ...Maybe I should mention that I get " 1.250861 <asm3.main> init_gui.py(14): no solver backend found" on startup but this seems to be something encountered by so many people that I don't think it can be related to this.
best place to report problems with assembly3 is:
https://github.com/realthunder/FreeCAD_assembly3/issues
Re: missing submenu
Moved the topic.
Re: missing submenu
Hi Chris,
Do you mean:
You have moved the topic? (Where to?)
I should move the topic? (Where to?)
By mentioning the solver issue, I have moved off topic?
I'm not trying to be awkward, just not sure if I have to sit tight in case someone has an answer or if I should be taking some action.
Do you mean:
- thomas-neemann
Re: missing submenu
is that helpful?steveKimpton wrote: ↑Sat Jan 15, 2022 11:32 am ViewMenuIcons.pngThanks for your suggestion.
All my boxes are already ticked there ...
https://www.youtube.com/watch?v=QbA4GC3hENM
Re: missing submenu
steveKimpton wrote: ↑Sat Jan 15, 2022 2:59 pm Hi Chris,
Do you mean:
no, you don't have to do anything
chrisb moved it into assembly subforum, because you are using Link branch of FreeCAD
in the absence of dedicated section and in an attempt to avoid confusion with "master" branch
all questions by people using Link branch are dumped here...
(simply because Realthunder created both Link branch and Assembly 3)
