[Solved] Help for using the Assembly 4 "Configurations" tool
Hello, this is the first time I have needed to use Asembly 4 "Configurations" tool to make an exploded view of a complex assembly. To understand how the tool works, I tried to use it with the simple assembly visible below:
I did the following steps:
1) I opened the "Configuration panel";
2) I pressed the "New" button;
3) in the window "Create a new assembly configuration" I wrote "default_cfg" in the field "Enter configuration name" and then I pressed OK;
4) I modified the Placement of Part_B by setting "Z Translation=+25.00mm" as visible in the following image:
5) I repeated steps 1),2),3) creating a new configuration called "exploded_cfg";
6) I opened the "Configuration panel", I selected in "Available configurations:" the configuration default_cfg, I pressed the "Apply" button but the configuration was not applied and the report view displays 5 messages "No data for object" as visible in the following image:
the spreadsheet "default_cfg" contains this data:
the spreadsheet "exploded_cfg" contains this data:
Where am I wrong in the above procedure?
My configuration is:
Assembly4 workbench (v0.11.5)
OS: Linux Mint 20.2 (MATE/mate)
Version: 0.20.26683 (Git) AppImage
Branch: (HEAD detached at 0388fbc)
Hash: 0388fbc98d49d874fb341b9037a743bc691d501f
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
Thanks in advance for the help.
Qt version: 5.12.9
OCC version: 7.5.3
Re: Help for using the Assembly 4 "Configurations" tool
Here the files:
- Part_B.FCStd
- (12.29 KiB) Downloaded 92 times
- Part_A.FCStd
- (11.81 KiB) Downloaded 86 times
- Assembly.FCStd
- (6.93 KiB) Downloaded 90 times
This is not the intended workflow. Try the following: adjust your assembly to the state where you want it to be (offsets, visibility ...). When done, create a configuration. Then change the state of the assembly, and create a configuration: Now, you can recall each configuration state and it will apply the parts as they ere defined.FCuser2019 wrote: ↑Mon Dec 20, 2021 2:06 pm Hello, this is the first time I have needed to use Asembly 4 "Configurations" tool to make an exploded view of a complex assembly.
You can also edit the AttachmentOffsets of each part directly in the configuration spreadsheet. Please report if you have problems
Hello Zolko, thanks for your reply.
This is the first time I've tried to use the "Configurations" tool and maybe there is something fundamental I didn't understand because I seem to have followed the workflow you mentioned.
An important question: are the data in the rows of the Asm4::ConfigurationTable spreadsheets automatically generated by the "Configurations" tool when creating a new configuration or do I have to create them manually?
As you can see in the pictures in the first post, the "Configurations" tool creates Asm4::ConfigurationTable spreadsheets that are almost empty; is this normal?
I did another test starting with the same assembly as in the first post:
1) I hide Part_B by pressing the spacebar:
2) I created a new configuration table called "hide_Part_B_cfg":
3) the automatically created spreadsheet of the configuration table "hide_Part_B_cfg" is:
4) I made Part_B visible by pressing the spacebar;
5) I opened the "Configuration panel", selected in "Available configurations:" the configuration hide_Part_B_cfg, pressed the "Apply" button and Part_B was hidden but in the report view error messages are displayed:
I attach the new file Assembly.FCStd (the files Part_A.FCStd and Part_B.FCStd are the same as in the first post).
- Assembly.FCStd
- (6.86 KiB) Downloaded 94 times
Hello Zolko, happy new year
Is there any news about the problems described above?
Have the same problem in my assembly project, doesn't work and give same errors
Help us please
Help us please
I didn't code that function, and I don't know what happened, but I'm looking into it.
I've released a new version (0.11.9) that fixes this I think. Could-you please update and test ?
