access denied
Footz wrote: ↑Sun Nov 21, 2021 6:10 pm ...I've attached your assembly prior to subshapebinder creation adding a bit of a twist...
and there is your problem...
If you toggle active a link in the assembly it actually activates original body.
Any attempts to create sub-shape binder in these circumstances leads to cyclic references - or to put crudely FreeCAD gets it's nickers in a twist
I did create sub-shapebinder in the parent bodies, but I didn't "move" anything.
When I created a "link" to parent body and used this link in assembly it carried with itself all the stuff created in the parent body.
Footz wrote: ↑Sun Nov 21, 2021 6:10 pm ...I have transformed the bar in the parent file a bit so it's moved in realation to the origin...
Compare the placement of the original/parent body and the placement of the link in assembly.
You will see that the "link" placement is that of the original body not the transformed body....
you can also download ... and try it
here
excellent Assembly3 tutorials
here
